Ns125F '88 Project
BradRapheal
PostPosted: 17:01 - 04 May 2017    Post subject: Ns125F '88 Project Reply with quote
Hi There, new to the forum!
Basically, i bought the Honda NS 125 (2 stroke!! Very Happy), and was thinking of tuning it and making it maybe like an on road track bike/streetfighter style, although there are a few queries with it... so i have a few questions, any help will be appreciated Smile
1. apparently the engines can be made very powerful for a 125, (40BHP i was told, i am sceptical) can anybody clarify or give an estimate/ there opinion? (i know tuning 2strokes to the back b*llocks makes them quite unreliable, but i only want this as my weekend/fun bike, and will be looked after so should be okay lol)
2. Wheels. The rear wheel is too thin in my opinion, it makes the whole bike look really thin and doing over 70mph on it worries me :') , so my original thought was to just change the back wheel, but there is only a few mil each side of the tire to the swingarm...
So i thought about changing it to an Aprillia RS125 swingarm + back wheel as the wheel is much wider.
does anybody know where to get dimensions for said swingarm? as google didn't give me any answers, or any other rear ends that may work the same?
Also i plan to also change the front end of the bike as well, but that will be less of a ball ache.
I understand people will probably tell me to keep it original and i would agree, although the bike wasn't in the condition i thought it was in when i bought it, basically been gypo'd together will cable ties and it was my second bike, so didn't know much better than to check things like that lol.
Always wanted one of these bikes since i was a kid, so one way or another i will make this bike awesome. just gathering the data before the hard work starts lol
Sorry for the essay and once again, any help / knowledge thrown my way will be greatly appreciated Thumbs Up thanks for reading!
redeem ouzzer
PostPosted: 17:13 - 04 May 2017    Post subject: Reply with quote
Fireblade front and rear end fits.
Engine isn't that tuneable (or strong).
Note that putting wider tyres on will just show up the lack of frame stiffness.
Be a REAL MAN!
V2
PostPosted: 17:53 - 04 May 2017    Post subject: Reply with quote
I had one of those! After getting it running it made about 18bhp on the back wheel, The previous owner had fitted a bigger carb and a custom tuned exhaust with spanny chamber (40bhp Laughing ) I think the Honda RS125r only stuck out just over 40bhp so I suppose its doable but probably not on the average mans budget
BradRapheal
PostPosted: 18:17 - 04 May 2017    Post subject: Reply with quote
well i was looking at my bike on google and they come out the factory with 22bhp, restricted. so i know it will go higher than that...
mine has a allspeed one piece exhaust on it, i don't know if been jetted to fit tho, runs nicely though.
the fire blade front/back end sounds fun lol, ill look in to that
and budget wise, like i say i plan on keeping it for as long as possible, so i have no time limit for what i plan to do, so hopefully that makes saving money for it easier lol
Hahadumball
PostPosted: 18:27 - 04 May 2017    Post subject: Reply with quote
i also had one
it also went through 2 bottom ends and 3 top ends and many rebuilds
20bhp or so tops and not that tuneable
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
V2
PostPosted: 18:33 - 04 May 2017    Post subject: Reply with quote
Fair enough! Mine was pretty good for a 125 running at 18hp! however I just has a look at the rs125r and that makes 45hp, a quote from the interweb:
The other reason I love it so much is because, much like a newborn infant, it demands the utmost care and attention. Carburation, via the gaping 38mm HRC powerjet carb, needs constant adjustment depending on atmospheric conditions and circuit type. Halfway through each meeting the cylinder is removed and the piston checked for any ring problems or excessive detonation. That piston generally lasts 300 miles before I chuck it, the ring and small-end bearing, in the bin. Running past 300 miles not only reduces power as the ring’s sharp edge blunts against the cylinder, but also increases the chances of the piston shattering through fatigue. Not good.
An insanely tall first gear means the wet clutch gets an absolute hammering at race starts and slow hairpins, this means I religiously renew the gearbox oil after every meeting, and most of the clutch plates and steels every third meeting.
You wont be saving much money at those power levels!
stevo as b4
PostPosted: 22:42 - 04 May 2017    Post subject: Reply with quote
Not so sure it's worth radically modifying an 80's classic 125 to make it a special or track day bike IMO.
I'd look at simple mods and just getting the suspension and brakes working well and use decent tyres in the original sizes or close to them.
Style wise I'd keep all std bodywork as you'll never make a nice but dated spindly old 125 look like an RS125 or ride like one.
I'd forget Aprilia RS swing arms etc. If you want to change wheels or forks, you'd probably have alot more luck and less hassle looking for NSR125 bits.
Motor wise, they are ok IMO. You'll get a bit more power probably 25-26bhp with a good/custom pipe and a programmable ignition.
If you really want to play with a engine, then I'd get a crank rebuilt with an uprated big end and or rod, and then fit a Malossi 190cc big bore kit. You'll need a custom pipe to make the big bore work to its potential.
The more you tune the less reliable it'll be or the more often rebuilds will be needed. If possible I'd look out for a spare engine or bottom end that you can strip and rebuild at your leisure, so if it does go bang you'll have the bits to change engines or top ends to get it running again asap.
I've got 3 KMX engines near enough in bits, but could use a spare bottom end so I can build a 125, a 200 and have a spares engine to raid for bits if one goes bang.
PostPosted: 23:15 - 04 May 2017    Post subject: Reply with quote
Will be mega crap as a track bike. The frame is steel tube, just because it has a box cross section doesn't mean it's a good frame. The wheels being thin makes no difference to how fast you can or cannot travel, or how dangerous travelling at those speeds is.
What makes travelling at those speeds dangerous is the flexible frame that induces weave at about 80mph. The reason I know this is because my very first bike was an NS125R.
Mine was tuned by an expert mechanic who also happened to be the previous owner. I'd be surprised if it made more than 20bhp with a Micron exhaust and other mods.
I have bikes that I used to own that I'd love to own again, but my very first bike, the NS is not one of them. It just wasn't all that. It did me as a 19 year old but I can't really see any reason why anyone would want one now other than for nostalgia reasons. The Alcast NSR125 or the later foxeye NSR yes, but not the NS, and especially not the spindly naked 125F which you can see so much light through the frame that you might as well be looking at a bicycle.
Don't modify it, ride it for what it is, or sell it. Or ignore us, I'm not sure I give a sh*t enough to worry either way actually. It's just that shit a bike.
BradRapheal
PostPosted: 14:04 - 05 May 2017    Post subject: Reply with quote
The only reason i wanted to put a different swing arm on the NS was to have a thicker back wheel, i don't really plan on making it ride or look like the RS125, just the back wheel has more stability. The shoulder of the tire on the NS is about 1cm thick, there isn't much tire on the ground.
as for the body work i wanted to keep it looking as the bike it is, not trying to make it into anything else, as i say i just think it will ride bit nicer with thicker tyres
and tbf, i guess i worded myself wrong, not a track bike, but a nice quick bike, the looks nice lol. it isn't an ugly bike IMO, but i just want to make it my own
i have been looking for bigger cylinder kits/big bore kits for them, but couldn't find any... is there anywhere i could be shown that sell them?
although as the bike goes, its not slow. it doesn't NEED to to any faster than it already does, i more just want to make it ride nice so i can have some fun.
PostPosted: 14:07 - 05 May 2017    Post subject: Reply with quote
Show me something that says a narrower tyre is less stable. Find a citation on the internet for this.
BradRapheal
PostPosted: 14:17 - 05 May 2017    Post subject: Reply with quote
*shrugs shoulders*
if your doing 80mph, would you rather your tire be roughly 5cm touching the ground, or 10? (not exact figures but you get where I'm coming from)
so your saying that if it has wheels, no matter how thick, that it doesn't matter? would you do 80mph on a motor bike with bicycle wheels?
PostPosted: 14:46 - 05 May 2017    Post subject: Reply with quote
BradRapheal wrote:
*shrugs shoulders*
I would do 80mph on my motorcycle with motorcycle wheels with extremely narrow tyres assuming the tyres are correctly rated for the speed I'm doing. Bikes in the 1930s could go faster than your NS125F on narrower tyres, with lower technology wheels with much much poorer tyre technology. You're imagining problems that don't exist.
The bike was designed with those wheels and tyres for a reason. Don't change them you'll only ruin the handling, and you are unlikely to gain any grip, and certainly unlikely to gain stability, if that is what you're after (which is nonsense in itself, but I can't be bothered to go into why).
This was capable of 100mph on cross ply tyres which were probably not speed rated in any way...
https://metrouk2.files.wordpress.com/2014/12/ad_153334825.jpg?w=748&h=555&crop=1
Hahadumball
PostPosted: 18:09 - 05 May 2017    Post subject: Reply with quote
https://cdn.velonews.com/wp-content/uploads/2014/07/5_20140727_%C2%A9BrakeThrough-Media__KRC4999.jpg
your theory explains why tour de france riders who go fast and corner fairly sharp use super mega fat tyr.... nvm
PostPosted: 21:55 - 05 May 2017    Post subject: Reply with quote
The UK restricted ones made 12hp. 20hp at the back wheel sounds about right for one properly derestricted and well set up.
Wider tyres won't really help, and the difference in contact patch will be tiny. I used to have an MBX125 many years ago which had narrower tyres and I did a hell of a lot of miles on that cruising at about 80mph indicated. No problems there at all.
Aprilia RS125 swinging arm will be useless for it. Chain is on the wrong side, hence the chain would need to go though the 'banana' part of the swinging arm.
Katy
PostPosted: 13:53 - 06 May 2017    Post subject: Reply with quote
I assume we've either convinced the OP not to change his wheels for wider ones... either that or we've convinced him to not come back on the forum.
I can't even begin to explain how I feel about "Wider tyres must be more stable". Jeez, I'm turning into Sickpup... Sick
ZX-7R This post is not being displayed because the poster is banned. Unhide this post / all posts.
stevo as b4
PostPosted: 00:21 - 08 May 2017    Post subject: Reply with quote
Not wanting to be too autistic here,
But a full power 22bhp NS125 with working ATAC will be unlikely to be a true 20bhp at the back wheel or more, though this depends on the dyno massively, and if your one of them people that believe that all manufacturers under/overstate crankshaft bhp figures.
Also someone said allspeed or could for that matter be an off the shelf 25-30yr old design of aftermarket pipe, being likely to increase power. Its not often many off the shelf pipes do much to increase power alone, and if the mid is good it'll be crap at the top and vice versa.
Secondly a 22bhp NS would be fun enough to ride, and have an interesting power delivery and be a genuine 85mph bike too.
Lastly looking at shit sites like bikez, bike pics etc and magazines are all full of shit, and only quoted specs by the manufacturer I personally believe in.
PostPosted: 19:30 - 08 May 2017    Post subject: Reply with quote
Big plus point back then is that they were used to replace restricted UK spec standard pipes. And tended to make a hell of a difference. Stock NS pipe derestricted had a good reputation.
Bikez specs are often complete garbage! Manufacturers advertising claims might well be more accurate than the random figures on there
Katy
BradRapheal
PostPosted: 22:36 - 09 May 2017    Post subject: Reply with quote
Yes it was Bike specs i was using, and i quoted it wrong it says 25bhp, (link to that page at bottom of paragraph) apologies for using what i didn't realise was an unreliable source.
https://www.motorcyclespecs.co.za/model/Honda/honda_ns125f%2083.htm
"I assume we've either convinced the OP not to change his wheels for wider ones... either that or we've convinced him to not come back on the forum"
No, didn't convince me not to come back, just showed me the types of people on here, and on my first thread. As i said this is my second bike, and the first one i plan on playing with. I come to the forum asking for opinions and guidance and you speak down to me, taking the piss. you could have gotten your point across with out being an arse Thumbs Up
"Secondly a 22bhp NS would be fun enough to ride, and have an interesting power delivery and be a genuine 85mph bike too"
i have had not much over 85mph out of mine, got up there quite quick tbf aswell (in my own opinion, then again its the only 2stoke 125 I've ridden so maybe thats why i think that...) but it was slightly shaky, hence why i thought thicker tyres may help. I'm sure there 110 thickness on the rear wheel.
i do thank people who are putting opinions and facts eat and not being what i feel is rude to me. these are the type of comments i came here for.
Also i didn't realise the RS chain would be on the other side, thank you for pointing it out
Either way, I'm customising this bike, wether every idea i have for it is a good one or not, doesn't mean that every idea i have will end up on the bike, doesn't mean its a disaster from the get-go.
there's a couple pics 's of the NS incase anyones interested. lol
V2
PostPosted: 00:05 - 10 May 2017    Post subject: Reply with quote
This was my one! Thumbs Up
https://cdn.bcf.44bytes.net/files/img_3021.jpg
PostPosted: 08:30 - 10 May 2017    Post subject: Reply with quote
Wow, you're in for a rude awakening if you think I was being an arse. You wait until you meet some of the more... colourful members of the forum.
Any time a relatively rare and old motorcycle is destroyed in this way, it kind of is a disaster. I'm not against resto-modding per se, but your ideas so far haven't really given me much cause to believe that you'll be successful. Forgive me for making assumptions, but being that you're equating stability of the motorcycle with tyre width, I'd say you don't really have much idea of how the dynamics of the motorcycle work. It's your bike, do what you want to it, but expect people on the forum to disagree, or point out why you're wrong. It's the nature of the internet I'm afraid.
PostPosted: 09:51 - 10 May 2017    Post subject: Reply with quote
Which might be the original Honda claimed power for a full power (not UK spec) bike. But will be quite a bit higher than even a full power one would manage to produce.
From memory from many years ago the speedo wasn't that accurate, and I would expect a derestricted one to be able to indicate close to 100mph (probably a true 90 or so).
I wouldn't worry about the tyre sizes. They are perfectly adequate (assuming they are a reasonable make, not some cheap nasty things, and in reasonable condition). However looking at your bottom piccy the front tyre doesn't look like any reasonable one I recognise.
But other things will make it unstable. Play in the suspension linkage, work steering head bearings, shock on its last legs, worn forks / for bushes, clapped out wheel bearings, tyres out of balance, etc. Even chain alignment out (don't trust the markings on the swinging arm). Some of these are very cheap and easy to fix.
Katy
PostPosted: 11:00 - 10 May 2017    Post subject: Reply with quote
Mine was owned by a motorcycle mechanic before I bought it, and it still weaved at 80mph. I think the frame was just not very stiff, the forks were cheap, the rear shock was cheap... The whole bike is just not all that good.
The last post was made 9 years, 87 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 1.46 - MySQL Queries: 13 - Page Size: 143.99 Kb
