Can a rusty spacer be treated?
Commuter_Tim
PostPosted: 21:27 - 06 May 2017    Post subject: Can a rusty spacer be treated? Reply with quote
I keep having to remove my rear spacer to scrub it, but it goes orange with rust about every 2 weeks outside, the spacer other side is fine.
I even tried coating it in acf50 and drying, then fitting, it helped only a little.
Is there a cure or do spacers just need replacing when they corrode?
I ride a Bandit 600... badly.
PostPosted: 21:41 - 06 May 2017    Post subject: Reply with quote
You could get it replated. Although probably only makes sense as part of a batch of bits to get done
Katy
PostPosted: 21:46 - 06 May 2017    Post subject: Reply with quote
Heat it up and quench it in oil it should give it some protection.
Nobby the Bastard
Harley Gaydar
PostPosted: 22:01 - 06 May 2017    Post subject: Reply with quote
What bike and year? Probably costs about £3 to replace.
Triumph Sprint ST 1050
ADSrox0r
PostPosted: 22:33 - 06 May 2017    Post subject: Reply with quote
You could be a flash git and get a titanium replacement.
Ed Case
PostPosted: 22:42 - 06 May 2017    Post subject: Reply with quote
'Emery paper' the corrosion off then spray can it if it bothers you that much.
PostPosted: 22:43 - 06 May 2017    Post subject: Reply with quote
600 Bandit I suspect, so £17.75:-
https://www.robinsonsfoundry.co.uk/shop/online-store/suzuki-parts-finder/gsf-bandit/gsf600/s-x-1995-1999-mk1-naked-and-faired.htm?vehicle_id=19#!gsf600mk1rearwheel
Katy
Suntan Sid
PostPosted: 22:54 - 06 May 2017    Post subject: Reply with quote
Smear a bit of grease on it!
Do you grease the axle at all?
Every spacer I've ever had, had a good coating of caked on grease on it!
Commuter_Tim
PostPosted: 23:01 - 06 May 2017    Post subject: Reply with quote
Aesthetics rarely bother me with bikes, but I assumed at minimum it would probably eat at the seals?
That being said, at the cost I may just purchase a spare set of dust seals.
I did think of painting it too, but I assumed that with the small amount of space between it and the seal, the paint would bind it?
andym
PostPosted: 23:02 - 06 May 2017    Post subject: Reply with quote
What he said....
I've never noticed any of my spacers being rusty because on the odd occasions I take the wheel off everything gets a smear of grease
Once rusty again, treat with Kurust (or any chromic acid based rust treatment). It works by turning the iron oxide into a hard, impervious [black] layer which prevents further corrosion. You can buy it in Halfords, I've had a tub in my garage for at least 15 years and it still works fine.
Commuter_Tim
PostPosted: 23:12 - 06 May 2017    Post subject: Reply with quote
I do grease the spindle, but I didn't think of greasing the outside of the spacer, with it being so close to the disc.
Just general purpose grease or copper?
andym
PostPosted: 00:56 - 07 May 2017    Post subject: Reply with quote
I rarely use copper grease (cause I don't have any)..... if you're worried about spreading grease everywhere.... use a cotton bud or similar
dydey90
PostPosted: 08:00 - 07 May 2017    Post subject: Reply with quote
I use zinc spray whenever I'm doing something in mild steel that I won't get a chance to paint.
Suntan Sid
PostPosted: 12:45 - 07 May 2017    Post subject: Reply with quote
Take spacer off, clean it, put a blob of grease on it, (any grease will do), work the grease around with your hand, wipe off excess, replace.
The thin layer you apply will not fling off.
Can't believe some of the replies in this thread, spray it with this, coat it with that, buy a new one, FFS, talk about overthinking a very minor problem.
Apart from anything else a coating of grease in that particular area, will help prevent assorted crud finding its way into the bearings.
PostPosted: 17:47 - 07 May 2017    Post subject: Reply with quote
Grease it with lithium grease. That said. It's probably not doing any harm apart from looking unsightly. If it was rubbing against anything, it wouldn't be going rusty!
Don't worry about getting grease on your rear disc by the way. even if you cake that spacer in grease it's not going to find it's way onto the disc unless you put it there.
PostPosted: 18:36 - 07 May 2017    Post subject: Reply with quote
Exactly Thumbs Up
Triumph Trophy Launch Edition
weasley
PostPosted: 18:44 - 07 May 2017    Post subject: Reply with quote
I'm pretty sure it's phosphoric acid, rather than chromic, so forms the passivated iron (III) phosphate layer.
But a smear of grease is cheaper, given that you probably have some lying about.
PostPosted: 22:44 - 07 May 2017    Post subject: Reply with quote
I suspect the reason my CB250RS only got a rosette at a classic show was because I used grease on my spacer.
Commuter_Tim
PostPosted: 20:04 - 08 May 2017    Post subject: Reply with quote
Cheers all, greased her up good and proper today.
I meant to do it earlier but got distracted by an orange brake piston, arguably more deathly. Shocked
ackack
PostPosted: 09:12 - 09 May 2017    Post subject: Reply with quote
If you ever take it off again and don't mind waiting a couple of days I'll replate it for you.
"fli hi mi angle"
Commuter_Tim
PostPosted: 22:02 - 09 May 2017    Post subject: Reply with quote
Really cool offer, and I may have to try messaging you in future asking to replate more important stuff (for monies ofc) cheers. Smile
However it's my daily ride and I can't bring myself to stoop to peasant transport. (travel sickness makes me puke for starters)
My main concern was if it would destroy my seals anyway, and the BCF concensus appears to be that I'm overly worrying, so all good.
Chalk another one up to the BCF GREAT SUCCESS column. Thumbs Up
ackack
PostPosted: 22:12 - 09 May 2017    Post subject: Reply with quote
No problem, I can normally get it done the same day if you're desperate for the bits back.
"fli hi mi angle"
The last post was made 8 years, 331 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 124.63 Kb
