back end cornering confidence
White Noise
Mr Dudwee
PostPosted: 18:38 - 06 Mar 2005    Post subject: back end cornering confidence Reply with quote
Hi all,
After my crash on monday with the backend disappearing on me, i have a major lack of confidence in my cornering. i went for a ride with Davo today to boxhill (Cheers davo for taking it slowly!!!) and i was all over the place as i have no confidence in my my riding to keep the backend staying stuck to tarmac! coming into corners my lines where all wrong and i was only leaning over about a degree and was very rigid!! on the way back it got a little better but still there is a lot of unsureness! this was not helped by me coming to a tight slip road from the A23 to the A27 just out side brighton and going over a white left turn arrow on the road and feeling the back slide! not sure if i am just imagining it or it actually happened.
So my question is what are peoples experiences for geting there confidence back after an off, and and suggestions for corning (apart from not going over painted white lines!)
Cheeers
WN
mrchips
PostPosted: 18:48 - 06 Mar 2005    Post subject: Reply with quote
Take it slowly and don't rush it, confidence will come back in time. Possibly think about changing your tyres too if that's what you have no faith in. I used to have no faith riding in the wet cause I thought my tyres gave no grip. I'm still far from fast but I can lean over about 10 degrees now. Laughing
Northern Irish? www.nibikers.com
NickD
PostPosted: 18:49 - 06 Mar 2005    Post subject: Reply with quote
Just ride, there's no miracle cure. In my experience it happens after every spill, something doesn't feel quite right and it's hard to tell if it's the bike, the conditions, or you......... it's usually you. It'll pass, just keep riding and give it time. Thumbs Up
I was only doing what it said on my licence officer....
Tear along the dotted line!
tony532
PostPosted: 18:54 - 06 Mar 2005    Post subject: Reply with quote
i havent had an off
but i have had the bike slide out round a corner on diesel and then grip again
and had the back wheel slide out on a roundabout a few times
and the front slide out a bit
you have to try and put it out of your mind
try and look out for where it might happen
and then take it slow
nothing wrong with riding slowly round roundabouts in the wet
your confidence will build up again in a while
kwaka
PostPosted: 19:16 - 06 Mar 2005    Post subject: Reply with quote
Came off twice last year.I don't know why it happened the first time but i do know why it happened the second. You can learn from your mistakes if you know why you made them but its a bit of a bastard when you don't.
Saying that, the confidence comes back anyway sooner or later as long as you don't rush into it. Sounds like you've got a good mate who obviously realises what you're going through and willing to give you the time to find your limits again. Good luck!
Bendy
Mrs Sensible
PostPosted: 19:23 - 06 Mar 2005    Post subject: Reply with quote
Once it gets dryer and warmer and the roads are cleaner, I bet you'll feel better about the whole thing.
scottiel
PostPosted: 20:41 - 06 Mar 2005    Post subject: Reply with quote
Just keep knocking up the mileage, and one day it will all fall back into place.
mario
PostPosted: 20:59 - 06 Mar 2005    Post subject: Reply with quote
I had the same position as you late last year and it did the exact same to me! I was so annoyed and frustrated at why i could no longer ride properly Evil or Very Mad
I continued to go out and take things easy in all conditions until eventually i started to feel more confident in my ability. Imo if you put in the miles you will get back your confidence and also i think weather can affect you too. My crash was in wet so was poor in wet however the dry weather made me feel safer and more confident.
Hope you get it all sorted Thumbs Up
Mark
jjonth
PostPosted: 21:48 - 06 Mar 2005    Post subject: Reply with quote
its funny that, I have come off 4 times in last 5 months lol. All on the racetrack loosing the front in the wet. The more I crash it the less time it takes to get the confidence back. The shock from crashing wears off after a couple of times. I just think about the ammount of grip the tyres give and then Im right to go again. I seem to have no problem with the back, in fact I like to have it sliding about abit lol, tells you when you are reaching the tyres limit. Wink And it feels cool to have the back end weaving about. Haven't mastered it in the dry though, with those Bridgstone slicks I use, if the tyre does loose grip... your off as you have to be pushing it so hard to loose grip then you have no chance to correct it. Although Ive never come off in the dry. You could try hanging off a bit in the wet on the road, keeps the bike that bit more upright and gives you a bit more confidence.
Gti
Bendy Groupie
PostPosted: 22:19 - 06 Mar 2005    Post subject: Reply with quote
Get the tyre pressures done.
Felt the exact same way about my bike and I didn't know whether it was the bike or my imagination. For awhile I was blaming on myself thinking I must be a shit rider, got the pressures done and it sorted everything out.
[M]
White Noise
Mr Dudwee
PostPosted: 22:27 - 06 Mar 2005    Post subject: Reply with quote
tyre pressure was at the haynes manuals reccomended pressure!
doh! think that more road under my wheels is needed! hopefully the confidence will get back in time, its a XJ600s so its not meant to be really cranked over but anymore that 5 degrees i keep thinking the back is going to go! any tips on getting heat into the tyres quickly, is weaving the best way?
WN
Gti
Bendy Groupie
PostPosted: 22:38 - 06 Mar 2005    Post subject: Reply with quote
Do you have the standard tyres on though?
[M]
White Noise
Mr Dudwee
PostPosted: 22:41 - 06 Mar 2005    Post subject: Reply with quote
not sure. Embarassed
bought it 3 weeks ago secondhand and haven't checked that out, how would having non standard ones affect things? just know that both tyres have decent depth tread on them
WN
Gti
Bendy Groupie
PostPosted: 22:44 - 06 Mar 2005    Post subject: Reply with quote
Those could be race slicks meant for dry track use on there for all you know.....
Did you have the pressures checked or did the guy you bought it off tell you he did it?
Did he change the suspension set up in any way?
[M]
White Noise
Mr Dudwee
PostPosted: 22:58 - 06 Mar 2005    Post subject: Reply with quote
sorry i nearlly pissed myself Laughing its a yam divvy! but seriously no they are a general all purpose type tyre. i checked the pressures when i pumped the tyres up this morning, though it was don't on the pumps gauge and not a seperate guage. the rear damper was replaced but in a proper motorbike service shop (got the service reciept). from the looks of the owner don't think he woud have fiddled with the settings
Cheers for the input GTI
WN
Gti
Bendy Groupie
PostPosted: 23:09 - 06 Mar 2005    Post subject: Reply with quote
Don't know about that bike, is it a trailie type? if it is it isn't that suited to hard cornering but that's not really what your doing is it.
If it's not a personal question, are you a fat cunt?
It really does sound like under pressured tyres to me. What damage was done in your accident? Rear wheel could be out of alignment. Confused
[M]
owdamer
PostPosted: 23:11 - 06 Mar 2005    Post subject: Reply with quote
I had an xj600 years ago, not a divvy but one of the original late 80's ones. Cant say I ever had a problem with the back end, but the front used to feel like it was pushing & running wide if you tried to go a bit hard in the corners. I doubt its a problem with the bike as you could stick a half decent club racer on it & they would grind the footrests into oblivion without breaking into a sweat. If you've had an off then I would suggest that you're probably all tense when riding. Try to relax & the confidence will come back.
White Noise
Mr Dudwee
PostPosted: 23:28 - 06 Mar 2005    Post subject: Reply with quote
LMAO, na its not personal. i'm 6 ft 3 or 4 and weight about 11.5/12 stone
this is the bike FYI
https://www.bikez.com/bike/index.php?bike=891
not much damage to the bike was only a 15-20mph off, bent bars, snaped footpeg, broken mirror and a few other things
i want to do that!! Laughing
not that i will for a while yet!
cheers
WN
The last post was made 21 years, 162 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 2.53 - MySQL Queries: 13 - Page Size: 102.52 Kb
