Bike is bogging and dying under throttle now wont start.
supermotogree...
PostPosted: 21:58 - 07 May 2017    Post subject: Bike is bogging and dying under throttle now wont start. Reply with quote
Hello!
my bike bogged down and died on me last week whilst on my way to work. I sat with it for round 10 mins and finally got it going. I then had to ride back in first gear, feathering the throttle slightly as too much would make it just dye out agin.
ive recently had the carb off and cleaned it all out, I soaked my jet/pins in neat redex for around an hour whilst I sorted the carb. I then put a air line through to clear anything else out.
I linked up the bike battery to a car battery to jump it and it fired up straight away. I took the leads off and let the bike idle. which it did fine, it was a little high so I turned the idle screw down. I took it for a ride and literally 300 yards down the road it did the exact same thing it did to begin with. I sat with it for around half an hour and it rough idled and didn't want to move. if I touch the throttle the slightest it will just die out.
I'm not sure what else it could be, is it getting to much air or? it now wont start at all and just turns over. sounds like it wants to start but it isn't.
Any help would be muchly appreciated, it's a supermoto 125.
Teflon-Mike
tl;dr
PostPosted: 22:50 - 07 May 2017    Post subject: Re: Bike is bogging and dying under throttle now wont start. Reply with quote
Well that doesn't narrow things down very much! It's a 125.. is it a bike some-one has converted to a super-moto? Is it some obscure make that's badged the model as a super-moto? Help us help you a bit here!!! A BIT more precicely, WHAT is t, Make, Model, Year!.. does it have a umber-plate? Log book should gve the details needed!
ive recently had the carb off and cleaned it all out, ...... , is it getting to much air or?
Well, THERE is a good place to start. Do you have a workshop manual for the thing? When you started taking the most intricate and senstive bit of the bke to bits? When you put it back together, did you use new gaskets and seals? Did you set the needle, float, mixture screws to the settings in the book? Or just twiddle randomly?
If you disturbed gaskets, didn't clean faces or use new gaskets seals, then Y-e-r-s... GOOD change it's sucking too much air through the gaps! If you randomly twiddled mixture settngs, stuck the needle back in on whatever slot you guessed at, YUP, some very very good reasons the thing might misbehave.
Begging suggestion you didn't take the battery OFF the bike to charge it off the car.... therfore good change that the HUGE amps banged out by the car generator, at maybe 50% more volts, gave the bike's regulator a heart attack, and fried it....
[quote="supermotogreener125"]I took it for a ride and literally 300 yards down the road it did the exact same thing it did to begin with. I sat with it for around half an hour and it rough idled and didn't want to move. if I touch the throttle the slightest it will just die out./quote]
SO, whatever you have done... probably wasn't the real problem.....
Start from scratch; get the book; base line the issues; eliminate the obvious first by doing a FULL basic service; change the plug, check the plug cap/lead, if 4T check tappet clearances; if OHC check cam-chain tension; change the oil; check & clean air-filter; check the exghaust for holes, lost gasgets etc; REVISIT the carburettor! Undo whatever you hav done; put twiddle screws back to book settings, re-assemble with nice new seals and gaskets!!! Check the fuel hose; check the fuel tap; has the tap got an integral strainer on the inside? Is it clean and clear? Does the tap 'flow' fuel? Is it a vacuum operated tap? Check vac hose from manifold.... if fiddling with carb have you yanked the vac hose off, or split it shoving it back on, stopping it turn the petrol 'on'?!
Possibilities are legion;so start at the top, and start working logically rather than randomly; BY (and possibly BUY) the book; and work through the list.
jaffa90
PostPosted: 23:02 - 07 May 2017    Post subject: Reply with quote
As stated ( Does the tap 'flow' fuel?).
When it bogs down give it choke and full throttle and then remove the plug to see if dry or wet with fuel.
The last post was made 8 years, 266 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 40.5 Kb
