GPZ500s rear shock gone (ZX9R possible swap)+starting issue
john24ssj
PostPosted: 10:11 - 09 May 2017    Post subject: GPZ500s rear shock gone (ZX9R possible swap)+starting issue Reply with quote
Hello,
Want to upgrade the shock of GPZ500 I searched on ebay and can't find anything decent but found loads of ZX9R rear shocks on sale for £20 and was wondering if that would fit her bike?
And the other issue is bike has issue with starting sometimes, but it's something to do the gear box. With ignition on and pressing the starter button you can hear clicking noise but it's not the battery as it's fully charged and new. What I need to do is put it in gear and role the bike forwards to move the cylinder and then the bike will start just fine.
Any ideas guys?
Thanks Smile
Bikes: Honda CBR600Fi, Kawasaki ER5
B5234FT
PostPosted: 10:39 - 09 May 2017    Post subject: Reply with quote
The normal shock swap is the SV650 yellow spring unit which is also available cheap on ebay. Some combine with lowering links as the shock is a little longer.
https://www.ex-500.com/15-suspension-tires-chassis/3842-sv650-shock-swap-write-up-results.html
Sounds like a sticking solenoid or something
john24ssj
PostPosted: 10:49 - 09 May 2017    Post subject: Reply with quote
Looks cool, but seems to involve drilling other small changes
pompousporcup...
PostPosted: 10:54 - 09 May 2017    Post subject: Reply with quote
if you cant stretch the £200odd for a new replacement, the sv650 shock can be made to work with very little hassle. It will however raise the rear ride height a little which quickens the steering a bit.
If your gf is a bit on the short side then i wouldn't do it without changing dog bones to put the height back to the way it was.. it may just be easier to front the cash for a new replacement shock from wemoto or gpzzone.co.uk
second issue could be a suspect starter clutch (relatively easy fix) or possible side stand cut off related..although im not sure how rolling it forward would make that work.
B5234FT
PostPosted: 11:39 - 09 May 2017    Post subject: Reply with quote
Have you tried the SV shock?
I'm curious to try it along with these:
https://www.ebay.co.uk/itm/Kawasaki-Ninja-GPZ500S-EX-500-94-07-Lowering-Kit-Dog-Bones-Linkages-/190860213336?hash=item2c7027bc58:m:mtysL_uyvBIA2H7rKmGImXA
And these:
https://www.ebay.co.uk/itm/Kawasaki-GPZ500-GPZ-500-S-1994-1998-YSS-PD-Fork-Valves-/172320545174?hash=item281f1ad996:g:gn8AAOSw6n5XrEI4
but I've yet to speak to anyone in the UK who has actually done it!
PostPosted: 11:40 - 09 May 2017    Post subject: Reply with quote
Different length (1 7/8" ride height increase) and different mounts requiring bushes to be removed / drilled / re-pressed? And the mounts need ground down and the spring fouls the dogbones?
Funny idea of "stock" and "direct fit". Wink
Agreed there. Short with a screwdriver to check that it's not the starter motor, clean up the terminals and the fuse, and if it still acting up, blow a few £££ on a new solenoid.
B5234FT
PostPosted: 11:50 - 09 May 2017    Post subject: Reply with quote
Agreed, but little better exists without spending proper sums of money sadly, so as a budget workable solution for cheaps it's tempting.
PostPosted: 12:03 - 09 May 2017    Post subject: Reply with quote
The current 250 / 300 Kawasaki rear shocks fit I think (I hesitate to use the word Ninja).
The SV shock can be fitted and I did one a while ago. But they are a pain.
The shock is quite a bit longer. Normal bodge is to drill a hole further up the U shaped bottom mount of the shock, but an MOT tester might have an issue about modifying a shock this way. The mounting holes on the SV shock are smaller so both top and bottom mounts been drilling out. The spring is about 10mm wider than the stock shock and catches on the dog bones; fix I did for this was to source some longer bolts and use penny washers to space the dog bones out to clear. Finding long enough bolts of a high enough spec can be fun, and the ones I landed up finding had a coarser thread so the original (locking type) nuts couldn't be used, hence loctite used on them.
Katy
john24ssj
PostPosted: 15:48 - 09 May 2017    Post subject: Reply with quote
Katy
Founds loads of Kawasaki 250 rear shocks but only from US Sad
And I think I know what's the problem with GPZ starting. If I remember correctly I had the same issue on my ER5 and it was the starter motor brushes were gone.
PostPosted: 20:02 - 09 May 2017    Post subject: Reply with quote
No guarantee that it'll fit, but Ninja 300 shock, £70 from Germany.
PostPosted: 10:02 - 10 May 2017    Post subject: Reply with quote
So does it sound like the starter motor is spinning? It should make a whizzing sound if it's spinning but not engaged in which case suspect the starter clutch.
A starter clicking but not turning then starting when you roll the bike forwards in gear sounds like a mucky commutator or worn out brush on the starter motor.
Clicking means power is getting as far as the solenoid and the solenoid is moving so the idiot-switch lockouts aren't to blame.
Worth checking if it's the solenoid but rolling the bike forwards shouldn't make any difference to a dead solenoid. In my experience they either work or they don't.
So if it's spinning, check the starter clutch. If it's not spinning then does spin when rolled, the starter motor itself needs servicing.
john24ssj
PostPosted: 10:26 - 10 May 2017    Post subject: Reply with quote
Nice find thanks Smile reading US forums it seems that ninja 300 shock does fit the GPZ500s
@stinkwheel the starter is not spinning at all and I remember I had the same issue on my ER5 and it was the carbon brushes that needed to be replaced.
PostPosted: 13:56 - 11 May 2017    Post subject: Reply with quote
How old is the GPZ500? We had the same issue with the first one we had, and it was the first sign of the magnets coming off the flywheel (a very common issue with the early GPZ500).
Katy
john24ssj
PostPosted: 11:34 - 12 May 2017    Post subject: Reply with quote
Katy
It's the 1995 one
PostPosted: 17:01 - 13 May 2017    Post subject: Reply with quote
Should be a late shape (17" wheel) one so the flywheels are generally safe
Katy
john24ssj
PostPosted: 11:46 - 15 May 2017    Post subject: Reply with quote
Just to let you know guys:
Took the starter motor out and upon checking it, we found that one of the carbon brushes was fully gone. Replaced it with a new one and everything seems to be perfect now. No more starting issues.
PostPosted: 12:43 - 15 May 2017    Post subject: Reply with quote
Thanks for the followup, good to hear you got it sorted. Thumbs Up
The last post was made 8 years, 334 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.28 - MySQL Queries: 13 - Page Size: 100.34 Kb
