Nsr 125 coil earth and misfire!
Farmingstock
PostPosted: 14:06 - 09 May 2017    Post subject: Nsr 125 coil earth and misfire! Reply with quote
I have had a slight misfire on the bike at high revs for a while, it's noticeable but still rideable.
So I've tried the usual things, new plug, drained changed fuel, cleaned carb, changed needle positions (pin is now at the very top) but none have corrected the issue, piston changed less than 500 miles ago.
Plug seems to get blacked up and needs to be changed often, wouldn't start the other day due to plug!!
ALSO
Some one has put a direct wire from battery negative straight the coil, there is no earth in the green coil connection and I've tried tracing with multi metre but can't find the earth so must have a break in it somewhere.
Any ideas??
Mentacycle
PostPosted: 14:14 - 09 May 2017    Post subject: Reply with quote
Id grab a multimeter, set it to 200 range, and get testing the resistances...
Farmingstock
PostPosted: 14:23 - 09 May 2017    Post subject: Reply with quote
Where from? What on? Cheers
Mentacycle
PostPosted: 14:35 - 09 May 2017    Post subject: Reply with quote
Hi,
Id test your pulse coil, charge and charging coils resistances, battery voltage, kill switch, ignition switch, stand switches for a break or a short.
If possible try another CDI and see if the problem persists.
Wise advice can be found here: https://www.dansmc.com/troubleshooting2.htm
Farmingstock
PostPosted: 15:02 - 09 May 2017    Post subject: Reply with quote
Cheers will do,
With relation to the earth on the coil!!
The actual green earth lead just runs up to a plug witch goes to the ignition switch! There are two earths on this plug one is grounded the other isn't I'm guessing that this may be a faulty ignition switch?? Possibly when the key is switched on both earth are grounded making the coil grounded??
Mentacycle
PostPosted: 16:48 - 09 May 2017    Post subject: Reply with quote
There could be moisture in the kill switch, might do it good to open it up and clean it up...
Farmingstock
PostPosted: 19:33 - 09 May 2017    Post subject: Reply with quote
Kill switch works absolutely fine! I bypassed it and still the same outcome!
Mentacycle
PostPosted: 20:36 - 09 May 2017    Post subject: Reply with quote
Great, so that can be ruled out!
When you say 'at high revs' , how high do you mean?
Used in anger high revs?
What is your current plug gap?
iooi
PostPosted: 22:03 - 09 May 2017    Post subject: Re: Nsr 125 coil earth and misfire! Reply with quote
Any ideas??
Sort out the mixture..... Clearly running too rich. Most likely due to the messing with the carb. SO set back to std and work from there.
Farmingstock
PostPosted: 22:59 - 09 May 2017    Post subject: Reply with quote
It's speradik to be honest but mainly 9000 and above no specific rpm every time!!! Sometimes I can be mid bend and get back on the power tho and there is nothing, nothing, nothing, then just as I think I'm about to go into the hedge I get power!! Scary stuff at speed.
There is no mixture to adjust on the NSR125 and the carb has upgraded jets (delorto upgrade) due to exhaust, barrel, reed, upgrades and settings are as recommended air screw 2.5 turns out and tickover 1500rpm when warm, needle set at second from top (4settings) tried at the top but will not Rev freely at all!!
I have taken the carb off again and am having it vapour blasted and ultrasonic to make sure it is clean ordered new jets again and new iridium plug!!
iooi
PostPosted: 21:32 - 10 May 2017    Post subject: Reply with quote
Any other mods that may have a effect Rolling Eyes
As far as anyone would know from your OP is that it is a std NSR125... Now it has no end of mods...
FFS give people the full info, or help will be a waste of time Shocked
alains
PostPosted: 09:59 - 11 May 2017    Post subject: Reply with quote
most of the time it's a faulty choke
1rst check the cable for any sharp bend
2nd undo the screw on top and take out the piston
underneath it's a convex rubber which is very often worn
eventually change piston & spring
https://www.dellorto.co.uk/shop/dellorto-motorcycle-carburettors-parts/dellorto-vintage-carburettors-and-parts/vhb-vhbz-vhbt-parts/choke-piston/
https://www.dellorto.co.uk/shop/dellorto-motorcycle-carburettors-parts/dellorto-vintage-carburettors-and-parts/vhb-vhbz-vhbt-parts/spring-6/
afterwards adjust the mixture with the small screw (the one inserted) at 2 1/2 turns out , then set idle at 1400 rpm +or- 100 rpm using the big screw (the one with the spring)
clean the black/yellow connector on the coil (oxyde is your enemy)
Farmingstock
PostPosted: 19:44 - 11 May 2017    Post subject: Reply with quote
Alains
Thanks for your response
The plunger looks brand new but I will change the small Oring as that was brittle and broke when I took it off.
Any idea regarding the coil wire? I have traced the green wire from the coil to the ignition switch plug! This should be earthed, however it isn't?
alains
PostPosted: 10:31 - 12 May 2017    Post subject: Reply with quote
you may make an other earth (it wont be bad) but i would be more suspicious with the black/yellow wire at both ends (coil & CDI)
Farmingstock
PostPosted: 17:28 - 12 May 2017    Post subject: Reply with quote
Right
I've had the carb vapour blasted and ultrasonic cleaned. The jets are brand new delorto upgrade, air and tickover set, new br9iex fitted, new air filter foam fitted, power valve set bang on the line, oil pump was a little over so adjusted back a little.
Bikes still in bits (no fairings etc) so not been on a long run only up and down a private road and it's raining so the tarmac is slippery. But was spinning the back wheel in first and second when it hit the powervalve and sounds a little more ricey now!
I'll give it a decent run when it's dry and everything is tightened up!!
The last post was made 9 years, 39 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.05 - MySQL Queries: 13 - Page Size: 83.58 Kb
