Overheating in slow moving traffic?
Falco
PostPosted: 19:26 - 10 May 2017    Post subject: Overheating in slow moving traffic? Reply with quote
The bike is a CB500s (first bike I've had that wasn't air cooled, in summer).
Ended up leaving the lab a bit late today and got snarled up in rush hour traffic. 12 miles of filtering through solid traffic later I noticed the temp gauge on the bike was the highest I have ever seen it go (over half-way). Is this normal on a hot day in heavy traffic?
The bike normally sits at the 1st line on the guage all the time, but I've only had the bike since February so I have no idea how it acts in warmer temperatures. Once above 25/30 the temp dropped no problem. Is this to be expected in hot weather and heavy traffic or should I start check the fan/thermostat/other bits of the cooling system?
PS the coolant was flushed and replaced about 2 weeks after I got it.
I tell you what, mathematically, I'm having it
PostPosted: 19:42 - 10 May 2017    Post subject: Re: Overheating in slow moving traffic? Reply with quote
https://i.imgur.com/3CeMUn1.jpg?1
Yes.
And all the air burped out of the system? Any bleed screws to tinker with?
Nobby the Bastard
Harley Gaydar
PostPosted: 20:48 - 10 May 2017    Post subject: Reply with quote
Sounds like the thermostat has been removed and so it's running artificially low all the time.
Did the fan come on?
Triumph Sprint ST 1050
ackack
Only worry when it's in the red.
"fli hi mi angle"
RhynoCZ
PostPosted: 20:54 - 10 May 2017    Post subject: Reply with quote
That is a very well known misconception about liquid cooled engines. Undercooling is as bad as overheating. Wink
Falco
PostPosted: 21:29 - 10 May 2017    Post subject: Re: Overheating in slow moving traffic? Reply with quote
Yup, as per Haynes (run for 3 minutes with fresh, cap removed and coolant topped up to bottom of the neck of the pressure cap). No bleed screws that I am aware of. Certainly not mentioned anywhere with regards to replacing coolant.
Thermostat is definitely there (taking it off the first time I ended up taking the housing apart, rather than removing it from the frame), though it could be inoperable. Having said that, would it make a difference the over-heating? I assume the thermostat controls the fan operation?
I don't know if it came on, both ends of the commute have a longish run of 30mph+ runs so it's always cool when I stop.
Where on the gauge should the fan come on? If I have a rough idea, I can pull over on the commute tomorrow (if the ambient temp is hot enough) and check the fan operation.
RhynoCZ
PostPosted: 21:33 - 10 May 2017    Post subject: Reply with quote
There are no bleed screws, as far as I know.
The thermostat does not turn the fan on. Thermostat opens/closes the ''long'' cooling circuit. Once the coolant is warm enough it opens and lets the coolant go through the radiator. If, for some reason, the temp drops, it reduces the flow to/through the radiator, to keep the engine (the metal bits) as close to the ideal operational temperature as possible.
Being familiar with the 90's CB500, these bikes run very cool all the time. So the fan should kick in only when it really gets hot. To check that, just ride it, get it hot and then rev it a bit when stationary to see, when the fan kicks in. IF the fan kicks in and cools the engine down, then you have nothing to worry about. From my memory, the needle of the temp gauge was always below the 1/2 of the OK range (the range between the Cold and Hot range).
EDIT: This answers your question: When should the fan kick in? - https://youtu.be/DImqWE75KIM?t=8s Thumbs Up
Nobby the Bastard
Harley Gaydar
PostPosted: 21:48 - 10 May 2017    Post subject: Reply with quote
The fan should come on before the needle gets to the end of the guage.
if the needle doesn't get to the red / temp warning light doesm't come on, its not overheating.
Kawasaki Jimbo
PostPosted: 21:52 - 10 May 2017    Post subject: Reply with quote
I took the R1 on my first ever charity run to Addenbrooke's Hospital in Cambridge a couple of years ago, in December. I imagined we'd all roar up to and across the city like the Red Arrows but in fact we chugged along at 25mph with frequent stops. Pretty dull to be honest. The bike ran quite hot but there were no ill effects. I'm saying normal.
RhynoCZ
PostPosted: 21:58 - 10 May 2017    Post subject: Reply with quote
Superbikes are meant to be ridden at high speed, even the road legal ones. My ZX7R used to run very hot when I did the anual Christmass ride. Going slow in a very large group of motorcycles (200+) made the fan spin even in temperatures around 0°C. The moment I got upto speed again, the engine cooled down in a matter of seconds.
Falco
PostPosted: 22:28 - 10 May 2017    Post subject: Reply with quote
It's certainly never gone over half before today (so I'd agree it runs fairly cool). You reckon the fan should kick in at anything over half on the gauge? I'll check it tomorrow if the weather is hot enough to trigger it (it is supposed to be).
Laughing Well, if it works.....
Guess I am just wondering what it is going to be like at the height of summer....
Falco
PostPosted: 22:34 - 10 May 2017    Post subject: Reply with quote
Cheers for that! I'll give it a shot (hopefully the rusty/shitty state of the fan isn't indicative of problems)
RhynoCZ
PostPosted: 23:36 - 10 May 2017    Post subject: Reply with quote
Definitely check the fan functionality. It's always better to be safe than sorry. Thumbs Up
ackack
PostPosted: 09:09 - 11 May 2017    Post subject: Reply with quote
Smile very true but OP did say the needle was moving so we can assume some heat is being produced.
"fli hi mi angle"
Teflon-Mike
tl;dr
PostPosted: 09:57 - 11 May 2017    Post subject: Reply with quote
Remember there are TWO 'thermostats';
1/ a thermostat 'valve', which 'closes' to stop water circulating through the radiator when the cylinder is cold, and opens, as engine warms, to let the heat out, through the rad.
2/ A thermostat 'switch' most often in the radiator, rather than the head, which turns 'on' the fan, when the water in the rad is too hot, presuming it's not getting enough air-flow for the rad to do it's job.
THEN there's the temp-gauge 'sender', usually in the head or block, that changes resistance to make needle on the dash go up or down, depending how hot the block is.
Taking signal from separate sensors, in different places, it's not uncommon for the fan to kick in at apparently different temperature readings on the gauge, though should be fairly consistent.
Personally, I wouldn't pay too much heed of the temp-guage; it's not all that relevant to anything, and if it goes into the red, what are you going to do about it anyway? I'd be more concerned that the fan does, first work, and second does kick in, on the thermostat-switch....
I do know dispatcher's who would actually fit over-ride switches in parallel to the rad-switch, to manually turn the fan on 'early' when grinding through city traffic which I suppose may be of some worth if you do a lot of city snarl.... but otherwise mention, as the CB500 was a bike common with the dispatch brigade, and fan wiring 'may' have been bodgerised, in a similar way.
But, other than checking the fan works, by-passing rad-switch, and then trying to get the temp needle into the red, in 'controlled' conditions... like letting the thing idle for a while on the stand, after a good run, to see if it does go up and come on, when there's no air-flow.. I'd not really bother about it... far more important stuff to keep an eye on road-side than fret about a dial on the dash! If it gets hot enough to start 'fluffing' when you open the throttle, or missing and pinking, or chucking steam out the overflow vent... THEN I would start to worry! Otherwise, I'd rather have a bike with a blown head-gasket, than be SMIDY'd by a twit I failed to spot, trying to work out what the dial was doing, trying to listen if the fan kicked in!
Chris45
PostPosted: 11:51 - 11 May 2017    Post subject: Reply with quote
Yes.
I have a water cooled bike and can drive it all day on open roads in summer at speed and the needle never moves above quarter gauge.
Five minutes of filtering through Inverness city centre the other evening during the rush hour and the temp gauge was well up, with the electric fan running.
As soon as I was clear of the traffic and up to speed again, temp was back to normal. It's a good way of knowing everything is working fine really.
Chris
Inverness.
Honda CG125>Suzuki GT185>Honda CB 250N>Suzuki GSX400>Honda CX500B>Kawasaki GPZ305> Kawasaki GPZ550>Kawasaki GPZ500S+BMW 650GS
PostPosted: 12:39 - 11 May 2017    Post subject: Reply with quote
Actually, undercooling leads to overheating Wink
sl121011
PostPosted: 19:58 - 11 May 2017    Post subject: Reply with quote
Could be worth checking the wiring from the fan itself. IIRC, one wire from my old CB500 fan should have been connected to the radiator or somewhere very close to it (tucked away and not easy to see). Of course, that had long since corroded, was no longer connected and therefore the circuit was never complete... ...and the fan never came on!
Current - MT-03, CD200. Gone - CB500
MCN
PostPosted: 21:59 - 12 May 2017    Post subject: Reply with quote
Wash the radiator fins, external blockage will prevent air getting to the hot parts of the radiator to take the heat away.
Simply job to try before ripping the beast to bits.
ADSrox0r
PostPosted: 22:57 - 12 May 2017    Post subject: Reply with quote
Said it before and I'll harp on about it again; try sitting on a 6th gen VFR in slow moving traffic, then you know what hot is about.
As already alluded to though; if the fan kicks in at the right temp and gets it back down to book spec...... meh. Nothing to fret about, she's meant to work that way.
The last post was made 9 years, 87 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 116.67 Kb
