Can't get it up like I used to - (clutch question)
Snop Doog
PostPosted: 03:38 - 11 May 2017    Post subject: Can't get it up like I used to - (clutch question) Reply with quote
2010 SV650S that's got a throttle stop restrictor.
Used to be able to clutch it up in 1st and 2nd for a couple of seconds before I became a puss (also I know it's not good for the SV).
Nowadays if I pop the clutch (or launch at high-ish RPMs) the revs will "stay" at say around 8k as if the clutch hasn't fully disengaged and then as I pick up speed everything will return to normal. What do these symptoms sound like?
The clutch doesn't "slip" under normal riding conditions.
What do?
Arcane1729 This post is not being displayed because the poster is banned. Unhide this post / all posts.
Snop Doog
PostPosted: 16:20 - 11 May 2017    Post subject: Reply with quote
Arcane1729 wrote:
Thumbs Up (note the giggle is at innuendo in the title not your problem)
I'm scared that later in life the ladies will giggle at my problem Embarassed
Snop Doog
PostPosted: 04:49 - 12 May 2017    Post subject: Reply with quote
Arcane1729 wrote:
It's ok bro later in there will be no more restriction at all for them or you to worry about but your dick issue I think is not such a lucky affair I'm afraid.
And why have you restricted it in the first place? Nobody knows to check nor cares...
I appreciate your reassurance, thank you my mate Thumbs Up
Restricted for A2 - It's true, got stopped, got slapped with a £100 fine for my 7x5 plate but nothing was said about my 200mm asbo exhaust or my solid black headlight protectors. I should've just taken the plate off and got a £30 fine.
Teflon-Mike
tl;dr
PostPosted: 06:53 - 12 May 2017    Post subject: Reply with quote
The Answer is obvious:-
https://www.motorcyclespecs.co.za/Gallery%20%20A/Yamaha%20XV535%2088%20%201.jpg
Yamaha XV535 Viagra!
MC900
PostPosted: 17:43 - 12 May 2017    Post subject: Reply with quote
Ive never been able to get mine up...
Current Ride: Fazer 600 (02) & YBR125 (07)
notbike
PostPosted: 20:56 - 12 May 2017    Post subject: Reply with quote
The only solution is to downgrade to a 125 again so that you don't highside next to vans that leave small gaps.
Shhh!
The last post was made 9 years, 53 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.13 - MySQL Queries: 13 - Page Size: 59.82 Kb
