| Hahadumball |
 Hahadumball World Chat Champion
| Howling TerrorOutOfOffice |
 Posted: 11:15 - 12 May 2017 Post subject: |
Tight spots are where you'll find them. i.e anywhere in the length of the chain.
To add.
The manual or a label on the swingarm tells you how and where to measure from. i.e on the ST2 the measurement is taken midway between the sprockets whilst the bike is on it's centerstand.
A metal ruler in a fixed position - rotate wheel a couple of inches - mentally note measurements etc.
Using the tightest bit of the chain use the adjusters so it's within tolerance.
If you find that the slack bits of the chain are touching anything it's usually new chain time (usually change sprockets too).
A quick way to see if your chain is on it's way out is to get the rear in the air and try and pull the chain from the rear of the rear sprocket. If you can see more than half a tooth between chain and sprocket it's worn at that particular spot - rotate and repeat.
[spelling corrected] ____________________ Diabolical homemade music Bandcamp and Soundcloud
Last edited by Howling TerrorOutOfOffice on 10:02 - 13 May 2017; edited 1 time in total |
| Minty |
 Minty World Chat Champion
| Hahadumball |
| Nobby the Bastard |
| MCN |
 MCN Super Spammer
 Posted: 21:42 - 12 May 2017 Post subject: |
High folks.
Tight spot/s on a chain, as the man said, is a chain ready for the bin.
I had a chain on a bike that would whung, whung, whung, at motorway speeds. I knew the chain was gubbed but I was too tight (Fiscally) to change it.
It was dire neglect that cause it and no amount of fettling with oil and teflon spray would fix it.
New Chain sorted it.  ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| Matt B |
 Matt B World Chat Champion
| andyscooter |
 andyscooter World Chat Champion
The last post was made 9 years, 89 days ago. Instead of replying here, would creating a new thread be more useful? |
