yamaha yzf r125
bojan
PostPosted: 16:27 - 14 May 2017    Post subject: yamaha yzf r125 Reply with quote
So i have yamaha yzf r125 2011 it was working perfectly until today i started it up and my revs slowly droped until it shut downs. After that i couldn t start it anymore. So i pushed my bike to start it. It started normaly and next day i couldn t start it my batery is new display is working it s trying to start it but it can t start it.
arry
PostPosted: 16:32 - 14 May 2017    Post subject: Reply with quote
Be more descriptive. Won't start how? Turning over buy not catching? Not turning over at all?
It's got fuel, right?
When was last service / any work undertaken​ on it and who by?
Have you checked for spark?
bojan
PostPosted: 16:36 - 14 May 2017    Post subject: Reply with quote
ofcourse it has fuel
now my bike has 26000 kilometers sevise was done at 24000 in yamaha
when i try to start it it s making normal noise like it s try to start but i can hold the button forever it doesnt start
and i can here some noise under the gas tank
bojan
PostPosted: 16:38 - 14 May 2017    Post subject: Reply with quote
i cheked for spark it s okaj
it s just trying to start but it s not cathing
arry
PostPosted: 16:50 - 14 May 2017    Post subject: Reply with quote
Tank breather ok? Has the tank been off or disturbed recently?
arry
PostPosted: 16:51 - 14 May 2017    Post subject: Reply with quote
Definitely sounds fuelling related.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:04 - 14 May 2017    Post subject: Reply with quote
99% of the time a fuel issue turns out to be electrical.
Triumph Sprint ST 1050
Dave70
PostPosted: 19:17 - 14 May 2017    Post subject: Reply with quote
Two problems I encountered were the fuel pump failing and also water getting in through the top of the tank where the fuel pump fits into the tank. These caused similar issues to those you've described.
I know you say you have a new battery but, it may be worth checking it's not a dud, just in case.
Bozzy
PostPosted: 19:43 - 14 May 2017    Post subject: Reply with quote
OP says it started when he bump started it.
Sounds like a battery issue to me. My first port of call would be to test it. Just because the display lights up doesn't mean the battery is healthy enough to power the starter motor.
2004 SV650S >>> 2009 Street Triple R
PostPosted: 19:55 - 14 May 2017    Post subject: Re: yamaha yzf r125 Reply with quote
bojan wrote:
my batery is new
And why did you change it?
Did you test for a problem in your charging circuit?
The last post was made 8 years, 333 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 61.47 Kb
