Charging a new battery (Oxford Oximiser)
M.C
PostPosted: 10:14 - 19 May 2017    Post subject: Charging a new battery (Oxford Oximiser) Reply with quote
Foreseeable noob issue; bought a new battery, 'activated' it with the acid pack, connected the charger and it doesn't want to charge as the voltage's too low (below 3v).
The last battery I bought came ready to go, I stuck it on the oximiser and it charged. So I'm guessing I need a different charger?
rpsmith79
PostPosted: 10:17 - 19 May 2017    Post subject: Re: Charging a new battery (Oxford Oximiser) Reply with quote
Have you got a set of jump leads, just thinking you might be able to give it a little boost off some leads to get the voltage up ready for the optimiser to work
M.C
PostPosted: 10:38 - 19 May 2017    Post subject: Reply with quote
I do not. What's the cheapest charger that won't result in a house fire?
Kawasaki Jimbo
PostPosted: 10:43 - 19 May 2017    Post subject: Reply with quote
Assuming you got all the acid in and let it equilibrate, it sounds like it's a dud. Take it back.
M.C
PostPosted: 10:52 - 19 May 2017    Post subject: Reply with quote
Hmm, all the acid went in and I left it to settle overnight.
jaffa90
PostPosted: 11:03 - 19 May 2017    Post subject: Reply with quote
I agree, mine did not need charging.
M.C
PostPosted: 11:34 - 19 May 2017    Post subject: Reply with quote
Checked the battery with a multi-meter (probably should have done that first Embarassed); so the charger must be fooked. Only thing it could be is I'm using the crocodile clips, I'll try using the continuous charge attachment.
Edit: ^ seems it was that.
The last post was made 8 years, 218 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 51.03 Kb
