Chain oiler on Varadero 125
Lemaru
PostPosted: 13:40 - 20 May 2017    Post subject: Chain oiler on Varadero 125 Reply with quote
Hi,
Does anyone here have a chain oiler on a Varadero 125? For the life of me I cannot find anywhere good to mount one
Commuter_Tim
PostPosted: 14:26 - 20 May 2017    Post subject: Reply with quote
1st result on Googlé.
Mounting scottoiler to varadero 125
I ride a Bandit 600... badly.
Stephenniall
PostPosted: 14:39 - 20 May 2017    Post subject: Reply with quote
I had a scottoiler Vacuum on mine.
Mounted the resevoir under the seat, I drilled a small hole to let the pipe run down & two holes either side and zip tied it in securely.
It worked fine.
Lemaru
PostPosted: 18:22 - 20 May 2017    Post subject: Reply with quote
My bad, I should have said an oiler such as the Loobman or Totoro, which don't require any cutting of vacuum pipes or anything.
Most seem to attach these to the frame the rear peg bracket but there just isn't any room around the frame and nothing really to strap it to by the peg.
Nobby the Bastard
Harley Gaydar
PostPosted: 18:27 - 20 May 2017    Post subject: Reply with quote
The instructions that you've been directed to show a space by the battery.
All oilers require either wiring changes or access to a vacuum.
Triumph Sprint ST 1050
Lemaru
PostPosted: 18:46 - 20 May 2017    Post subject: Reply with quote
Umm no. You are totally mistaken there. Not all oilers require access to wiring or a vacuum at all!.
The Tutoro works by a weight moving to release oil... No vacuum or wiring require
The Loobman works manually by pressing a button to release oil. Again, no vacuum or wiring required.
Also the photo showing the space by the battery in the Scott oiler PDF is actually not a picture of a Varadero at all. The battery is under the side panel, not under the seat and doesn't have enough space beside it. But yeah, thanks anyway
Nobby the Bastard
Harley Gaydar
PostPosted: 19:29 - 20 May 2017    Post subject: Reply with quote
If you know so much about it, why are you asking for advice?
The loobman seems to need a connection of some sort from the button to the looby thing and anything that just uses a weight would be spewing oil when you aren't using the bike. I'm oooot....
Lemaru
PostPosted: 19:47 - 20 May 2017    Post subject: Reply with quote
I was asking for advice on where others may have mounted there's. As for the Tutoro, the weight actually stops the oil flow so how would it leak over the bike when it's not moving?
So in the same vein as your response, why reply to something you obviously know nothing about.
Nobby the Bastard
Harley Gaydar
PostPosted: 20:32 - 20 May 2017    Post subject: Reply with quote
You see on my sig, it says I have a Triumph Sprint ST 1050?
It has a scotoiler on it. It's the same one I took off my FZR1000 exup. I wasn't scared to mess with the carb on the exup and knew how to use google to find a vacuum on the ST.
Lemaru
PostPosted: 20:44 - 20 May 2017    Post subject: Reply with quote
Finding the vacuum isn't the issue, I know where to find it, as already shown in the Scottoiler pdf. However not everyone wants to use a Scottoiler. However I sure will sleep better knowing that you have one and that you know how to use Google. Thanks
Nobby the Bastard
Harley Gaydar
PostPosted: 20:45 - 20 May 2017    Post subject: Reply with quote
Thumbs Up Welcome to the enemy list, btw.
The last post was made 8 years, 226 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.18 - MySQL Queries: 13 - Page Size: 69.38 Kb
