Honda Jazz handbrake bad.
johnsmith222
PostPosted: 22:04 - 22 May 2017    Post subject: Honda Jazz handbrake bad. Reply with quote
Hi guys,
My mum's handbrake on her honda jazz has been bad lately, as the car rolls backwards on a hill. I drove the car while she was in the hospital for a week, and it's not just her being too weak.
I jacked the car up at the weekend, and while I noticed the discs are the originals that have done 35k miles, and they've got a bit of a lip on them, the pads look near-enough new.
I bled both rear calipers, as well as adjusting the handbrake free play from within the car (I know this is for adjusting the free play more than anything), and while things improved a bit, the car still rolls backwards.
I checked the handbrake would actuate the lever on the rear calipers for the handbrake.
Before I go ahead and get her to pay to replace the discs and pads (which I'll fit for her), I was wondering if you guys had any idea what the problem is.
If I replace the discs and pads, I'll take the sliding pins out, clean them up/lube them, as well as clean the calipers up, wind them back etc to make sure they're working ok.
Thanks for any help. Smile
EDIT: Thinking about this, perhaps her caliper sliding pins are mucky enough to prevent proper action using the handbrake, but the footbrake is able to overcome.
DrSnoosnoo
PostPosted: 07:46 - 23 May 2017    Post subject: Reply with quote
I'd perhaps give the calipers/pistons a clean up before biting the bullet to buy more, not that they're expensive.
Not worked on one but I know on ignis sports and MR2s the position of the piston when wound into place is important for good handbrake.
PostPosted: 09:40 - 23 May 2017    Post subject: Reply with quote
Why would the condition of the discs affect the handbrake. It's for use when the vehicle is static so they could be pitted and worn to fuck and still work. the natural wear on the pads will be more than disc wear and the handbrake should still work with low pads.
I'm much more inclined to believe cable, linkage, pins or whatever it is on a Jazz that needs looking at.
bugeye_bob
PostPosted: 11:41 - 23 May 2017    Post subject: Reply with quote
Edited ** This depends on year it seems after a bit more searching, sorry**
A quick Google seems to suggest they are similar to the rear VAG`s were they use the caliper as the handbrake, no separate shoes,
In which case Id remove the pads and work the pistons back in and out a few times, this may need a tool to rewind them rather then just force them back,
do this a few times and this with show if the caliper is working or seized, it will also reset the handbrake part, so may help,
remember to slacken off the cable adjuster at the front to get the full benefit of the adjustment at the caliper, you cant adjust the caliper end it is all done by the caliper mechanism inside.
piazza
PostPosted: 12:12 - 23 May 2017    Post subject: Reply with quote
This might be relevant, might not.. Laughing
https://www.dft.gov.uk/vosa/apps/recalls/searches/expand.asp?uniqueID=31C3634E54DCDFA7802574F00055803B&freeText=Blank&tx
Pukka
PostPosted: 13:34 - 23 May 2017    Post subject: Reply with quote
Im guessing its a mk1 (02-08).
Ours had the same problem when we got it. One of the pads was rusted solid to its lower clip . Clean and regrease sliders/clips sorted it. I make sure to do this at least once a year and hasnt been a problem since. Would definitly try that before throwing any money at it.
'98 Honda CB500S, '89 Yamaha FZR600 (Ongoing project)
PostPosted: 13:37 - 23 May 2017    Post subject: Reply with quote
I thought all Honda jazz drivers left the handbrake on all the time anyway?
Monkeywrenche...
PostPosted: 14:42 - 23 May 2017    Post subject: Reply with quote
you say that the cable moves the levers, do the levers return all the way to their stops when the brake is released?
2001 Aprilia RSV Mille R -dead, 2016 XSR 700-gone, 2018 Dorsoduro 900
dansp1
PostPosted: 16:49 - 23 May 2017    Post subject: Reply with quote
Cause if they don't go all the way back to the stops the handbrake mechanism won't self adjust, so back off the cables you adjusted and recheck
johnsmith222
PostPosted: 10:25 - 24 May 2017    Post subject: Reply with quote
I think you're right drsnoosnoo. It's worth a go to see if it sorts the problem before ordering more parts.
I wasn't sure if the discs being too thin would affect the hand brake, but you're right, that shouldn't stop it working.
It's definitely the same sort of setup as the VAG calipers, with the caliper used for both. Good tip on slackening the cable back off again too. I'll give it a try and see how I get on. Smile
piazza wrote:
That's something I'll need to look into, as it's a 58 plate jazz, so might be relevant. I dont think the ratchet mechanism is causing this problem though.
Pukka, you're right that this is a mk1 jazz. Seems like your fix might be what I'm after. I'll see if I can sort it at the weekend. Smile
I get that feeling too when I see them. It was good fun when I borrowed it for a while, driving at the speed limit in a 30, then giving it everything and losing them on the twisty nsl country road. Razz
Good point monkeywrencher. I can't be certain if they go back to their stops, so will need to double-check it.
Thanks for the help everyone! I'll let you know how I get on. Smile
johnsmith222
PostPosted: 18:43 - 24 May 2017    Post subject: Reply with quote
Ah well, it seems my mum has taken it upon herself to take her honda jazz to kwik fit without asking for my opinion, all because i casually mentioned her exhaust is blowing,while I was driving the car.
Around £600 for new back box, mid section, and front cat (which broke when they removed the other 2 sections.
It won't be OEM parts, and it seems this can be had online for a couple hundred quid.
Why do i bother wasting my weekend going over her car, checking things, ordering tyres online, if she goes and does that. Sad
BTTD
PostPosted: 08:19 - 25 May 2017    Post subject: Reply with quote
I know that feeling. Having spent time fixing bits and bobs for my mum that were a real pain to do, only to have her then pay someone a few hundred to sort something piss easy has really wound me up in the past. Especially when it's then done to a poor standard.
Hey ho, you do what you can. Neutral
Monkeywrenche...
PostPosted: 09:51 - 25 May 2017    Post subject: Reply with quote
of course it did Rolling Eyes they really are a bunch of cunts.
johnsmith222
PostPosted: 18:21 - 26 May 2017    Post subject: Reply with quote
Yeah, it's a bad feeling, especially when it's someone in your family. Don't get me wrong, I understand that buisnesses have running costs etc. But when I can get brand new parts for a reasonable price online, and have the tools to do it in a short time, it's unfortunate she didn't speak to me first.
Anyway, I will still help her with the other things on her car, so hopefully that will save her some more cost that she would have had.
Thanks. Thumbs Up
The last post was made 9 years, 172 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 88.4 Kb
