tips on improving mid-high end power.
sasuke
PostPosted: 12:25 - 07 Mar 2005    Post subject: tips on improving mid-high end power. Reply with quote
hi does anyone has any suggestions to the above for a 2 stroker 135cc bike? my initial suggestions were to remove the bolt to allow more flow to the exhaust and to change an after market air filter. would an after market air filter have any effect a small cc bike such as this?
i also had my plugs n engine oil changed.
craigT19
Jolly Green Giant
PostPosted: 20:46 - 07 Mar 2005    Post subject: Reply with quote
if you put a race type air filter on a standard engine set up it will run like a load of shite.
Best bet is to just accept its a 135cc, save your money for your test then buy a big bike and look into tuning, the sort of money you would spend tuning a 135cc bike wouldnt justify how little power u would get extra
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
cagiva gezzer
PostPosted: 00:32 - 08 Mar 2005    Post subject: Reply with quote
https://www.bangor.ac.uk/~bsuc15/newagainstolddyno.jpg
Gain from reducing the squish from 1.8mm to 1.05mm and increasing the base gasket by 0.2mm. Under £40 for everything.
"because one stroke isnt enough and four strokes waste two"
bish777
PostPosted: 14:48 - 08 Mar 2005    Post subject: Reply with quote
Put a pod filter on the carb, and shim up the needle so the mixture is richer, should give a bit of a boost.
GSXR1100J
The last post was made 21 years, 236 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 39.13 Kb
