gt550 overheating + 2 cylinders
Jay2903
PostPosted: 22:28 - 24 May 2017    Post subject: gt550 overheating + 2 cylinders Reply with quote
hey guys
I've been fixing this one for a while now. Thought I'd start a new topic because the problem has changed. Basically ive replaced the piston rings and a valve on cylinder 4 and its had new gaskets. This was becuase it had low comression on that fourth cylinder.
Two problems now
Its over heating
and only running on cylinders 1 and 4. No spark going to 2 and 3. Coils and plugs are fine.
Paddy Blake
PostPosted: 22:58 - 24 May 2017    Post subject: Reply with quote
Did you clean the carbs.?
How do you know the coils and plugs are fine.
I thnk firing order is 1/2/4/3 but check this then you can change
the HT leads around to fine if it is the coil/plugs.
Paddy Blake
PostPosted: 23:18 - 24 May 2017    Post subject: Reply with quote
The two middle carbs have different springs and needles so you don't
want to mix them up.
It's an old bike and the rubber connectors from carb to engine
could be cracked.
Jay2903
PostPosted: 23:32 - 24 May 2017    Post subject: Reply with quote
I thnk firing order is 1/3/4/2 but check this then you can change
carbs are clean. I've added bigger jets and pod filters though.
I switched around the cables that go to the coils and got a spark from 2 and 3.
Paddy Blake
PostPosted: 23:43 - 24 May 2017    Post subject: Reply with quote
Most likely electric.
The coil that didn't is not earthed or connected right.
I edited my post above for firing order.
Clean the frame where the coil goes and metal on the coil and see if that works.
Jay2903
PostPosted: 23:46 - 24 May 2017    Post subject: Reply with quote
[/quote]
Clean the frame where the coil goes and metal on the coil and see if that works.[/quote]
I'll give that a try
Jay2903
PostPosted: 12:37 - 25 May 2017    Post subject: Reply with quote
[/quote]
Yea it was a sketchy cable. You think the over heating is from an incorrect firing order ?
Paddy Blake
PostPosted: 23:08 - 25 May 2017    Post subject: Reply with quote
Your first post says it's not firing on 2-3 so fuel is not getting
burnt.
Smell the oil to check if is smells of petrol.
Did you change the oil filter at the same time ,if you don't then the oil will stay in the filter so you use less.
Most 4 stroke depend on the right level of oil for the crank
spinning to oil the cylinders and pistons.
Crank spins and throws oil up to these parts if it's to high or
low it won't get thrown up.
Also
Jay2903
PostPosted: 13:24 - 26 May 2017    Post subject: Reply with quote
burnt.
Also
Yea new oil filter. running on all cylinders now. Exhausts become boiling hot in a few seconds.
Jay2903
PostPosted: 14:13 - 26 May 2017    Post subject: Reply with quote
Also
I put exactly 3 litres
Jay2903
PostPosted: 16:05 - 26 May 2017    Post subject: Reply with quote
Could it be the oil pump ?
Jay2903
PostPosted: 19:04 - 27 May 2017    Post subject: Reply with quote
Or the fuel air mixture ?
Jay2903
PostPosted: 10:46 - 29 May 2017    Post subject: Reply with quote
Anyone ?
Paddy Blake
PostPosted: 17:29 - 29 May 2017    Post subject: Reply with quote
Is the oil light staying on when you start it.?
Spray some wd40 on the rubbers between the carbs and see is smoke comes out of the exhaust to check if its airtight.
Running lean will cause it to run hotter.
Jay2903
PostPosted: 19:13 - 29 May 2017    Post subject: Reply with quote
I'll give that a try. ive noticed that the oil level is over the line on the window even though i put exactly 3 litres. Is that a problem
Paddy Blake
PostPosted: 21:12 - 29 May 2017    Post subject: Reply with quote
Yes,if the oil is to high the pistons won't get oiled as in my post above.
Jay2903
PostPosted: 22:03 - 29 May 2017    Post subject: Reply with quote
but i put exactly 3 litres as instucted by the manual. Strange
Jay2903
PostPosted: 10:46 - 30 May 2017    Post subject: Reply with quote
[quote="Jay2903"]
Its got the right amount of oil now but its still overheating
PostPosted: 14:27 - 30 May 2017    Post subject: Reply with quote
If it's making the exhaust glow on idle and overheating then you better check the valve timing again. could be the carbs too but my guess is you're a tooth out on the cams.
Jay2903
PostPosted: 17:25 - 30 May 2017    Post subject: Reply with quote
timing is correct
Paddy Blake
PostPosted: 23:37 - 30 May 2017    Post subject: Reply with quote
I have a feeling that when you took the cams out some of the
valve shems moved out of place.
But is there a spark.
Check those rubbers as it's an old bike.
You say they're fine but you can't know for sure.
Read all the post in this thread incase you missed some.
Jay2903
PostPosted: 00:45 - 31 May 2017    Post subject: Reply with quote
- Carbs clean
- Rubbers from carbs to engine good
- timing correct
- Fresh oil , correct oil level, new filter
- running on all 4 cylinders
Paddy Blake
PostPosted: 17:17 - 31 May 2017    Post subject: Reply with quote
Good job. Smile
Jay2903
PostPosted: 17:51 - 31 May 2017    Post subject: Reply with quote
Paddy Blake wrote:
Good job. Smile
Still overheating though Mad
Paddy Blake
PostPosted: 20:35 - 31 May 2017    Post subject: Reply with quote
Many get the carbs balanced.
The last post was made 8 years, 250 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 121.34 Kb
