Hyperpro rear springs
F1.ash
PostPosted: 10:03 - 28 May 2017    Post subject: Hyperpro rear springs Reply with quote
I'm thinking of changing my rear spring, primarily to help with setting of correct preload. At the moment the adjuster on my V-Strom is wound all the way up and it's still 8mm outside of ideal setting.
Should I expect a Hyperpro spring to assist in this or is it more a like-for-like swap that's considered an upgrade?
Any advice appreciated Thumbs Up
Fizzer Thou
PostPosted: 14:31 - 28 May 2017    Post subject: Reply with quote
A friend chose a Hyperpro front and rear spring kit which,together with the correct grade fork oil as supplied,made a big difference to his Bandit 1200.The kit was a much cheaper option to a replacement rear shock and was easy to install.
The website for Hyperpro https://hyperpro.com/products/ suggests Performance Parts Ltd https://www.performanceparts-ltd.com/ as the UK importer and they should be able to suggest the correct spring for the weight and type of riding that you are contemplating.
When I replaced the rear shock on my R1 I quickly found that the front springs then felt inadequate.It is an idea to upgrade the front at the same time,although a little time then needs to be spent setting up the best spring preload and damping clickers Thumbs Up
Always have a 'Plan B'
PostPosted: 18:18 - 28 May 2017    Post subject: Re: Hyperpro rear springs Reply with quote
How much do you weigh is the key part of this (Well how much load do you carry is more accurate, top box, pillion etc.). How many miles on your shock will also impact it. If your shock unit is bust, putting a posh spring on it is just delaying the inevitable.
As Hyperpro springs are progressive they're not sold with a specific weight like a linear spring as the rate of the spring changes depending on how compressed it is. i.e. when it isn't compressed very much it takes a little force to compress, whereas when it is compressed a fair amount it takes a lot of force to compress.
Their springs are very good on OE units if they're not shot and you're not carrying massive loads.
F1.ash
PostPosted: 09:31 - 29 May 2017    Post subject: Reply with quote
Thanks for the replies.
Typical all in weight is 230lbs with everything on and everything fitted that lives on the bike permanently.
My bike has 8300 miles on it and has been looked after with a good service history.
F1.ash
PostPosted: 09:41 - 29 May 2017    Post subject: Reply with quote
I have it in mind not to be surprised if this is the case. I went for ride yesterday evening and the bike has the sensation of being higher at the back, ie not as compressed as much which is what I might expect, but the composure of it over certain undulating or rippled poor surfaces is not great. It clearly doesn't like having it's pre-load adjuster at maximum. It's like trying to stay on a horse if you know what I mean. It does seem to originate from the rear end but has you say, it's bound to highlight other shortcomings once it's changed out.
I'm no expert at bike suspension/handling, this is my first so I'm finding my way.
PostPosted: 10:37 - 29 May 2017    Post subject: Reply with quote
Doesn't seem like you should have the adjuster maxxed out with 103kg on it. What ideal are you trying to achieve, but still 8mm out of? Sag?
F1.ash
PostPosted: 20:50 - 29 May 2017    Post subject: Reply with quote
I have nothing to compare it to so I've no idea what I should expect. All I know is I can't set the correct sag, the adjuster is fully in and the ride seems hard at times. I'd also like some more progression in damping if it's possible and I'd also like some headroom on the adjustment in case of pillion etc.
The last post was made 8 years, 268 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.15 - MySQL Queries: 13 - Page Size: 56.32 Kb
