| toler85 |
 toler85 L Plate Warrior
 Posted: 17:27 - 28 May 2017 Post subject: Crack and damage in the crank case |
| V2 |
 V2 Nearly there...
 Posted: 17:30 - 28 May 2017 Post subject: |
a) Leave it be
b) Get it welded up
c) Buy new engine
| Mentacycle |
 Mentacycle Borekit Bruiser
| Polarbear |
 Polarbear Super Spammer
 Posted: 17:52 - 28 May 2017 Post subject: |
I'd paint over that and forget about it. ____________________ a.k.a 'Geri'
| Chris45 |
 Chris45 Nitrous Nuisance
| MCN |
 MCN Super Spammer
| kramdra |
 kramdra World Chat Champion
| Paulf |
 Paulf Nova Slayer
 Posted: 19:47 - 28 May 2017 Post subject: |
The damage lower down is obviously the result of a bunched chain and it's possible that the long crack is related to that but equally possible its from casting shrinkage. It's certainly no reason to cry doom, gloom, disaster and going by the state of the gear lever I'd say the bike isn't in the sort of condition that warrants spending out on new cases or engine anyway.
If it's leaking oil badly then you might want to do something but if it's just getting a bit of oil mist on the dirt leave it alone and top up as necessary. It's not going to explode on you. ____________________ a.k.a 'Geri'
| Paulf |
 Paulf Nova Slayer
| Chris45 |
| MCN |
 MCN Super Spammer
 Posted: 14:47 - 29 May 2017 Post subject: |
The crack is most probably only the outside of the 'bolt hole'.
The inside of the 'bolt hole' will obviously still be hail or the pressure from that long bolt would split the case open.
De-grease it and spray it Lada Stratus Silver.
Get on with your life.  ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
The last post was made 8 years, 274 days ago. Instead of replying here, would creating a new thread be more useful? |
