Tank dings
A100man
PostPosted: 15:48 - 30 May 2017    Post subject: Tank dings Reply with quote
Hi all
Anyone tried those dent pullers that use hot-glue and mushroom-shaped tabs to pull out tanks dings. Seem to have acquired a mysterious dent
on the current project. Alternatively I thought about making a bent rod to push it out..
kgm
PostPosted: 17:25 - 30 May 2017    Post subject: Reply with quote
They work with shallow dents but if it's creased the glue isn't normally strong enough, looking at welding and probably filling after for those, or bent road as you suggested. A rod can be awkward with the shoulders on many tanks.
If it's just a shallow dent (like hail dents you might get abroad) then you could try heating it with a hot air gun and spraying it with a compressed air can held upside down to cool it quickly. I had success with that method once. Obviously drain it properly beforehand...
RhynoCZ
PostPosted: 20:29 - 30 May 2017    Post subject: Reply with quote
I have used what you describe, OP. But only on cars = big sheet of metal. It does work, but can't do miracles. If your dent is too deep with sharp angle indent, then it won't work.
For instance, this is the ideal dent for this method (nice, rounded dent, no sharp breaks): https://www.youtube.com/watch?v=3PKkFTu_ZVI
NOTE: Degreese the place and leave the glue to actually stick to the tank (read the manual, I think you're supposed to leave it for 2-5 minutes, before you start pulling it). Any residual glue on the tank can be removed with a heat gun afterwards. OR, if you buy the kit, there is a sharp tool to remove the glue of the surface.
Word of wisdom, DO NOT be too eager. Go slow and check you're not pulling it out too much.
EDIT: Post a picture of your dent and I'm gonna tell you right away if it's doable with such method or not. Thumbs Up
A100man
PostPosted: 08:59 - 31 May 2017    Post subject: Reply with quote
Thanks - I'll take a pic. It's small, not creased or broken the paint but might be a bit 'sharper' than the one in the clip. I have a feeling the 'bent rod' trick would work best if I can get access..#
The last post was made 8 years, 269 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 40.18 Kb
