| iCraig |
 iCraig World Chat Champion
 Posted: 22:25 - 06 Mar 2005 Post subject: Getting a bike set up on a Dyno? |
Well since changing the exhaust on the GPZ, I noticed the downpipes glowing when I was running it the other day, which lead me to believe it was running lean.
So I thought I shall get it set up on a dyno properly and rejet it as I intend to fit a K&N Filter aswell.
So I was wondering what I should expect from the dynorun and how much am I looking at?
Any advice will be greatly received.  |
| mchaggis |
 mchaggis World Chat Champion
 Posted: 22:35 - 06 Mar 2005 Post subject: |
Don't forget you can have a gander at the spark plugs to check the mixture, a bit more quantitative than just seeing the downpipes glowing. ____________________ I must not be a troll...
Mmmm, Guinness
Discovering the delights of Hammerite and a 3/4" brush.  |
| stinkwheel |
 Posted: 22:44 - 06 Mar 2005 Post subject: |
From what I remember, Motad Nexxus pipes make them run a tiny bit leaner than standard but not so far as will do any harm. As has been said, check the colour of the plug electrodes. If you are going to be changing the filter too, a dyno run would be a good idea although I have never had one done either. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| instigator |
 instigator Super Spammer
 Posted: 00:39 - 07 Mar 2005 Post subject: |
Can't say I've done a dyno run on my bike either, having said that it didn't feel any different after k&n filter and a diff. exhaust system.
A run on the dyno to prove my bikes 33bhp was £37.50 excluding vat, and that lasted about 20 minutes or so. So expect about £50+ if the bike needs meddled with.
P.S Stand outside the dyno room, the gpz will sound great.  |
| cunni |
 cunni Spanner Monkey
 Posted: 13:46 - 07 Mar 2005 Post subject: |
It all depends what you have done and what your idea of a sorted dyno run is?!
If you want someone to tell you if it's lean and adjust it slighty, then possibly around £40-£60.
If you want to slightly tweak it to use the potential of the new exhaust, then you will need a re-map and that might set you back as much as £120!
If you really want to make the most of your bike, then you'll be getting them to add and set-up a Power Commander, which will set you back around £345 (ish).
You could just look into the idle setting on your bike or the carb. openings or jets or injectors (depending on what your bike has). ____________________ TL1000R Parts For Sale! |
| Mr C |
 Mr C World Chat Champion
| Kickstart |
 Kickstart The Oracle
| cagiva gezzer |
 cagiva gezzer World Chat Champion
 Posted: 19:17 - 07 Mar 2005 Post subject: |
My dyno runs cost me £10 for a mixture check and a couple of printouts.
Depends where you go and what the operator is like. My local place "road and track" lets me work on the bike while its all rigged up, thus saving me labour costs if i want to try different set ups.
Glowing pipes are cool!
https://www.roadandtrack.co.uk/images/pipes_r2_c1_f2.jpg ____________________ "because one stroke isnt enough and four strokes waste two" |
| Flip |
 Flip Super Spammer
| RealNinja |
 RealNinja World Chat Champion
 Posted: 09:43 - 08 Mar 2005 Post subject: |
Bykers tyre place have a dyno now, if you are looking to have it run, and set up.
Alternatively, you could use Rhencullen in Hinkley, who did my ZX7R. A full setup and 2-3 runs cost me about 120 quid (plus you get to drool over some of the tricked up race bikes they have being tuned ) ____________________ You will become my force of retribution. Where you tread, doom will follow. Go now and claim your destiny |
The last post was made 21 years, 162 days ago. Instead of replying here, would creating a new thread be more useful? |
