| lingeringstin... |
 lingeringstin... Spanner Monkey
| WD Forte |
 WD Forte World Chat Champion
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 16:17 - 03 Jun 2017 Post subject: |
It' a retard to advance system in the CDi; ie; the static timing is something like 30 Deg Before TDC; the CDi then 'advances' the timing by reducing the lag before triggering the plug.
If you check CMSL part numbers, they seem to use the same CDi on all the benly motors, as well as the small singles..... and I'm pretty sure that they are all the same Pt No as the CB125TDC 'full-power', that has a advance curve that will let them rev-out to 14Krpm!
AFAICT the presumed 'performance' or 'racing' ones flogged on e-bay are for the most part the bog-stock Honda CDi, ad if they have a twiddle-able pot, my best guess is that most likely either adjusts the base timing 'lag' or pulls/pushes the advance lag a little up or down the rev range... after all, unlikely any-one will ever get any of the push rod or OHC engines, and all but the 309 cammed 125 twin to rev anywhere ear as high as that CDi will allow!
Given the spark is coming from a simple mag-winding; the 'performance' CDis cant be giving the spark any extra amps for a beefier spark, all they may do s offer an alternatve advance.. so on a tuned single? If they have a push/pull pot? Yeah.. they 'might' be marginally useful to match curve to tuning, but otherwise? Not going to do much on thier own. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| lingeringstin... |
| Kickstart |
 Kickstart The Oracle
| lingeringstin... |
| 1198 |
 1198 World Chat Champion
| kgm |
 kgm World Chat Champion
| pepperami |
 pepperami Super Spammer
 Posted: 15:31 - 05 Jun 2017 Post subject: Re: orse |
| WD Forte |
The last post was made 8 years, 264 days ago. Instead of replying here, would creating a new thread be more useful? |
