| ADSrox0r |
 ADSrox0r World Chat Champion
 ........ Borekit Bruiser
| ADSrox0r |
| Pete. |
 Pete. Super Spammer
 Posted: 15:01 - 06 Jun 2017 Post subject: |
Personally I would lap the face with the size printed on it, then the next person won't get caught out. The main requirement is that they stay very parallel as the bucket turns in use. If you lap even a small taper (which you will without a jig) the shim won't rotate and you might get wear issues in the shim or the bucket.
We have a local bike shop that does exchanges for a few quid a shim. You might have too. ____________________ a.k.a 'Geri'
| ADSrox0r |
| Pete. |
 Pete. Super Spammer
 Posted: 16:43 - 06 Jun 2017 Post subject: |
There is no exact measurement, just in tolerance and out of tolerance, but I know what you mean. If I absolutely had to do it I would turn up a small holding block that the shim sits flush in and lap it on a stone.
Have you checked the shim sizes you have? You might be able to swap some about and only buy a few. ____________________ a.k.a 'Geri'
| Copycat73 |
 Copycat73 World Chat Champion
| ADSrox0r |
| Pete. |
 Pete. Super Spammer
 Posted: 17:07 - 06 Jun 2017 Post subject: |
Looks like you're not far from Malton you could try John at JW Motorcycles. If he doesn't have shims he might suggest where to get them.
Otherwise, a lick on a surface grinder would do the job. Local engineering firm? ____________________ a.k.a 'Geri'
| ADSrox0r |
| Copycat73 |
| Fizzer Thou |
| Pete. |
 Pete. Super Spammer
 Posted: 18:14 - 06 Jun 2017 Post subject: |
Thickest shim they list is 2.90mm though and he needs thicker. ____________________ a.k.a 'Geri'
| ADSrox0r |
| Nobby the Bastard |
| Pete. |
 Pete. Super Spammer
 Posted: 23:48 - 06 Jun 2017 Post subject: |
If his clearance is less than 0 shims are the least of his problems. He'd be looking at burned valves etc. ____________________ a.k.a 'Geri'
| Pete. |
 Pete. Super Spammer
 Posted: 04:38 - 07 Jun 2017 Post subject: |
An engine HAS to be running for a valve to get burnt. They don't pop like a fuse. ____________________ a.k.a 'Geri'
| ADSrox0r |
| Pete. |
 Pete. Super Spammer
 Posted: 05:08 - 07 Jun 2017 Post subject: |
Ah right yes I got the wrong end of the stick.
What you should do before pulling the head and doing valve work is a leak-down test. If that gives a good result just do the shims and crack on. ____________________ a.k.a 'Geri'
| ADSrox0r |
 Posted: 05:25 - 07 Jun 2017 Post subject: |
A little internet-fu reveals that Aprilia lists shims up to 4mm, the range being between 3-4mm so I think this is indicative of mine being 'normal' rather than original suspicions of 'bodged in bigger uns'. https://www.fowlersparts.co.uk/parts/5692864/pegaso-650-pegaso-650-pegaso-650-1992-1996-pegaso-650-all/valves-t
Typically though, I still can't get hold of any in stock unless I order from out of the country and pay exorbitant delivery fees. ____________________ Current bikes: '08 VFR 800 VTEC(yo) , '07 ZZR1400 Winter hack: '95 Aprilia 650 Pegaso Currently lusting after: RC30 |
| ADSrox0r |
| Pete. |
 Pete. Super Spammer
 Posted: 06:30 - 07 Jun 2017 Post subject: |
No, leak down is only done with both valves shut. ____________________ a.k.a 'Geri'
The last post was made 8 years, 252 days ago. Instead of replying here, would creating a new thread be more useful? |
