Random question from watching the TT...
PostPosted: 20:27 - 07 Jun 2017    Post subject: Random question from watching the TT... Reply with quote
On all the onboard shots where you see the clutch lever I notice every rider has the clutch cable adjuster 'wrong'.
The lock nut is up against the cable end rather than the lever perch.
Anyone know why? I'm assuming it for adjustment on the fly?
PostPosted: 21:07 - 07 Jun 2017    Post subject: Reply with quote
https://i.imgur.com/6xM31xC.jpg
Got vid-pix?
Kentol750
PostPosted: 21:13 - 07 Jun 2017    Post subject: Reply with quote
Are they using the clutch? Not if you look and listen carefully. Less chance of cable snapping when they do use it if it's as you see it.
Some bikes.
kgm
PostPosted: 21:16 - 07 Jun 2017    Post subject: Reply with quote
Of course they are. Maybe not for upshifts but they certainly do on downshifts.
Kentol750
PostPosted: 21:18 - 07 Jun 2017    Post subject: Reply with quote
Not on my tv. Downshift with no clutch pulled in. Watch again.
Some bikes.
M.C
PostPosted: 21:24 - 07 Jun 2017    Post subject: Reply with quote
John McGuinness was saying something about this with the new Honda, how he was used to using the clutch (on downshifts) before riding this machine. I would have thought quick shifters/slipper clutches were fairly standard but maybe not (across the field).
robertw95
PostPosted: 21:29 - 07 Jun 2017    Post subject: Reply with quote
It's more the autoblippers on most modern bikes now a slipper clutch still needs clutch on downshift. Anyone watching Moto 2 will know about the rider who won in mugello having front brake and clutch lever on the left hand bar and how he changes down gear
07 Dt125r, sv650s k8, zx6rr 04
redeem ouzzer
PostPosted: 21:32 - 07 Jun 2017    Post subject: Reply with quote
I don't think that it's a floating locknut. I think the adjuster is one piece and probably has a bit of sprung steel that engages with the "wheel" as a form of ratchet.
Be a REAL MAN!
Old Git Racing
PostPosted: 21:55 - 07 Jun 2017    Post subject: Reply with quote
It's an adjuster for the front brake travel above the clutch lever. As the brake pads go down you adjust it to stop the front brake lever coming back to the bar.
OGR
Kentol750
PostPosted: 22:11 - 07 Jun 2017    Post subject: Reply with quote
OGR,
thanks for enabling me to tell Mrs K what it does to the brakes. OP means the actual adjuster for the clutch lever is wound out away from where it 'normally ' is.
Some bikes.
ScottT
PostPosted: 22:18 - 07 Jun 2017    Post subject: Reply with quote
Got vid-pix?
Hutchy in todays superstock race.
https://i49.photobucket.com/albums/f260/ScottT2728/Hutchy2_zpspyrcpbhq.jpg?t=1496787357
iooi
PostPosted: 05:13 - 08 Jun 2017    Post subject: Reply with quote
If you watch Huttcy. You see he only used the clutch a couple of times. At start and at the finish (pit stop included) He also mentioned quick shifter.
As a bonus. He also has a rear brake ( thumb operated ) under the clutch. Which he was using one hell of a lot to keep front down and stop rear spinning up Thumbs Up
Suntan Sid
PostPosted: 08:03 - 08 Jun 2017    Post subject: Reply with quote
Not sure why but last night I was looking carefully at the on board shots from Hutchy's bikes, last night.
When he crossed the finishing line, to win the race, and was slowing down to get back into parc ferme, he went down the gears without the clutch, however he did use the clutch to get it down into 1st.
I bet the tyre technicians hate burnouts in the winners enclosure.
As a side note, assuming the BMW used a full tank of fuel over 2 laps, the bike's getting around 10 mpg!
AshWebster
PostPosted: 10:16 - 08 Jun 2017    Post subject: Reply with quote
Excuse my ignorance, but quick shifters and auto blippers?
is this just clutch-less shifting up and down?
does this mean that there's actually never any need to use the clutch?
or do you have to be in the right rev range when clicking up/down?
help me out :p
Honda cg125 J reg peice of shit ---> CB650F ---> 2016 CBR600RR
Ford KA ---> 93' MR2 ---> 94'MR2 ---> 98' Subaru WRX STI Ver 3 (track car)
M.C
PostPosted: 10:56 - 08 Jun 2017    Post subject: Reply with quote
FFS I've not watched it yet Crying or Very sad
Matt B
PostPosted: 12:35 - 08 Jun 2017    Post subject: Reply with quote
help me out :p
Quickshifters basically cut the throttle (bike under power) unloading the transmission and allowing a shift up without the clutch.
Autoblippers just give it a very quick pre-set rev or throttle blip (bike under deceleration/engine braking) unloading the transmission and allowing a down shift without clutch.
You still need a clutch to pull away and stop.
jjdugen
PostPosted: 12:38 - 08 Jun 2017    Post subject: Reply with quote
The tensioning spring against the adjuster ferule is plainly obvious.
M.C
PostPosted: 13:18 - 08 Jun 2017    Post subject: Reply with quote
Hmm I thought blipping was to help with rear stability (on an aggressive downshift).
PostPosted: 13:58 - 08 Jun 2017    Post subject: Reply with quote
Can you highlight it to make it super obvious?
Matt B
PostPosted: 14:20 - 08 Jun 2017    Post subject: Reply with quote
That's the job of a slipper clutch or back-torque limiter.
I see what you are getting at, but blipping the throttle in that sense is for when you are using the clutch to change down. Auto blip works much faster than that.
Mudshark
PostPosted: 14:54 - 08 Jun 2017    Post subject: Reply with quote
thought it would take me while to get used to the quicksift on the new bike, now the clutch is just something for the traffic lights
R1250RS
XT660X
pudder
PostPosted: 15:01 - 08 Jun 2017    Post subject: Reply with quote
Assuming this in red
1993 Kawasaki AR50 (In bits) - 1984 Suzuki GP125 (Sold, but still ridden) - 1954 Matchless G3L (Being restored) - 2007 Suzuki Bandit 650
chrisdubya
PostPosted: 15:10 - 08 Jun 2017    Post subject: Reply with quote
So does the autoblipper wok in conjunction with a slipper clutch? Or instead of?
PostPosted: 15:21 - 08 Jun 2017    Post subject: Reply with quote
OIC. Thumbs Up
wristjob
PostPosted: 15:33 - 08 Jun 2017    Post subject: Reply with quote
the extra adjuster on the left hand is for brakes.
so can adjust while still on the power with the right hand.
The last post was made 9 years, 163 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 125.5 Kb
