Rubber spray
Skudd
PostPosted: 00:38 - 08 Jun 2017    Post subject: Rubber spray Reply with quote
Is there such a thing and where do I get it from. Rubber spray to water proof the webbing in the jacket sleeves where they zip open. Mine unzip to the inner elbow and water is getting through the zip and then through the membrane. It is an alpine star jacket about 12 years old but in very good condition except for the sleeves.
BTTD
PostPosted: 06:08 - 08 Jun 2017    Post subject: Reply with quote
The only thing I can think of is Plastidip, but I have no idea if it'd work. I suspect it won't.
PostPosted: 07:05 - 08 Jun 2017    Post subject: Reply with quote
I've yet to find any waterproofing solution that actually works, except for wax impregnation on canvas. I can't see plasti-dip standing up to all the movement involved. Interesting question though, it'd be good to know if anyone has found a magic bullet.
Hawkeye1250FA
PostPosted: 07:28 - 08 Jun 2017    Post subject: Reply with quote
Scotch guard or some other nano hydrophobic spray should work - it may not make it 100% waterproof, but it will be decidedly better...
1993 RF400R - 2002 Bandit 1200 - 2012 1250 FA
Teflon-Mike
tl;dr
PostPosted: 08:13 - 08 Jun 2017    Post subject: Reply with quote
Tent water-proofing works on fabric pretty well.
Fabsil, I think is the stuff local camping shop sell. The aerosol seems a placebo; the small tins are half the price for 1/5th the quantity; I tend to buy the big, I think half gallon tins, every decade or so... or when I do the tent and use left overs for the rest of the gear. 'as and when', maybe every couple of seasons or so.
Zips? Err... yeah.... no.. no, and no again. Never found a way to stop them leaking. Zips usually have a backing flap that helps stop water pouring through, but the zip itself? If that worn lots of water gets through, it's probably pretty worn out.
On metal zips on jackets/jeans/boots/gloves, old hands used to suggest they should be oiled from time to time with a few drips of caster or sewing machine oil, a) so they zipped more easily, b) to help repel water from getting through the teeth.. MAY be worth a shot.
Otherwise, if it's a vent, and you are more concerned with keeping water from getting through when closed than air when open, I might be tempted to use gaffer tape over the zip, or maybe a strip of tent seam sealer... maybe even RTV?
Otherwise? Seems fact of life, modern kit isn't made to last, like it used to!
skatefreak
PostPosted: 08:38 - 08 Jun 2017    Post subject: Reply with quote
I've done a hiking bag and a tent ground sheet both with great results (but takes a while for the smell to dissipate).
Non anti bacterial silicone calk + white spirit.
Mix the two and paint it on letting it get absorbed into the fabric.
Result = flexible water proof layer that does not peel off as its impregnated in the fabric...
I'm not to sure about having it directly against your skin for long periods but it works like a fiend for bergen and ground sheets Thumbs Up
PostPosted: 10:28 - 08 Jun 2017    Post subject: Reply with quote
Interesting. What sort of ratio or consistency would we be looking for?
skatefreak
PostPosted: 10:46 - 08 Jun 2017    Post subject: Reply with quote
I generally aim for 1:3 ratio.
It does take a little patients to get the silicon to mix in homogeneously with the white spirit but it most certainly gets there and applies easily.
I've used it as seam sealer on my textile waterproof 'dungarees' although the fabric itself keeps splitting... probably as they're 8-9 years old now and used every time I ride on the road Thinking
mudcow007
PostPosted: 10:48 - 08 Jun 2017    Post subject: Reply with quote
on my canvas camper I use "Fabsil Gold" brush it on, then wipe it with a dry cloth.
It definitely works, but the fabric goes a bit more rigid.
I have to redo the camper every year
Someone mentioned you can also use brick sealer as its basically the same stuff. cant confirm though?
https://www.instructables.com/id/Easy-waterproof-clothing-and-about-anything-else-/
PostPosted: 11:10 - 08 Jun 2017    Post subject: Reply with quote
I've tried brick sealer, it didn't seem to make any difference to my leaking cordura / Sinaquatm sleeves.
It might have been bad sealant, but it doesn't seem to cure, which I imagine the silicone / spirit mix would do.
Evil Hans
PostPosted: 14:17 - 08 Jun 2017    Post subject: Reply with quote
My daughter has a toy hospital with some little patients. And some tiny doctors. Wink
I use fabsil, and that more or less does the trick. I buy the gallon tins and brush or spray it on.
neptune8
PostPosted: 18:51 - 08 Jun 2017    Post subject: Reply with quote
Here is a cheap tip to try.Close the zip, and rub along the teeth with a wax candle. treat it inside and out if possible. Limits the amount of water penetration, and lubricates the zip. Treatment may need frequently repeating.
Enjoy yourself, its later than you think
ScottT
PostPosted: 19:17 - 08 Jun 2017    Post subject: Reply with quote
Try something like Aquasure, its a bit like silicon sealant but its meant for repairing waders.
It sticks to anything very well and is fully waterproof, ive used it in the past to glue the soles back on my fishing boots, 5yrs later there still holding good.
Its about £7-8 for a small tube but will last for years.
Once you have used some put the lid back on and pop it in the freezer, when you take it out it just needs a couple of hours to thaw out then ready to use again, i had a tube in my freezer 3yrs and it worked fine when i came to use it again.
If it keeps water out of waders then it will keep it out of your jacket.
Skudd
PostPosted: 20:00 - 08 Jun 2017    Post subject: Reply with quote
Does it dry none tacky? As a coating but not as a glue?
Shinigami
PostPosted: 20:19 - 08 Jun 2017    Post subject: Reply with quote
rub/melt some wax into the fabric?
ScottT
PostPosted: 22:10 - 08 Jun 2017    Post subject: Reply with quote
Its not tacky at all when it dries, read some of the reviews about it on Amazon
https://www.amazon.co.uk/d/h1o/Mcnett-Aquasure-Neoprene-Repair-Adhesive-28g-Tube/B0030UP2DM
PostPosted: 06:50 - 09 Jun 2017    Post subject: Reply with quote
You have to get it good and hot in order for the wax to penetrate. Fine with cotton, not so great with Cordura or other plastics.
Skudd
PostPosted: 18:07 - 09 Jun 2017    Post subject: Reply with quote
Just ordered some to see how good it is. Will report back after trial.
FirebladeRuss
PostPosted: 18:14 - 11 Jun 2017    Post subject: Reply with quote
Fabsil is pretty good tbh. I use it on all my bike gear, and the garden gazebos!
Twitter is for people who can't STFU even when they're by themselves
PostPosted: 18:28 - 11 Jun 2017    Post subject: Reply with quote
Ah, I noticed today that my brick sealant is "solvent free" and named "eco[something]", i.e. it is doubtless fully conformant with every EU regulation, and doesn't do a damn thing.
PostPosted: 18:47 - 11 Jun 2017    Post subject: Reply with quote
Fabsil Gold. Thumbs Up
Stinky stuff and working well on the old bike cover.
stirlinggaz
PostPosted: 20:30 - 11 Jun 2017    Post subject: Reply with quote
Hi,
I use nikawax for waterproofing jackets etc.
Dunno if it's any use for what op wants it for, but they are good at giving out free samples (enough to do 2 coats or a tent)
Maybe worth contacting them?
cheers,
GSZ
The last post was made 9 years, 160 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 119.27 Kb
