how does oil defy gravity
pompousporcup...
PostPosted: 06:30 - 08 Jun 2017    Post subject: how does oil defy gravity Reply with quote
My mate has an oil leak on his zzr11. it puddles up on his cam cover pretty badly and also seems to run down onto his exhaust manifold and gets burned off.
Oil can be seen on the tops of his carbs, the outside of the airbox among other places.
There is no oil in the spark plug recesses.
We cannot see where its coming from and so far have done:
replaced the cam cover O rings.
cam cover gasket still needs doing.
rerouted the crank vent tube which normally goes into the airbox to an external bottle to confirm its not leaking out of the airbox.
there is oil literally everywhere and its a proper ballache to trace as it only seems to happen after his commute, which is an hour or so at 80+
The next bit ive told him to do it replace the cam cover gasket but struggling to think how an oil leak from that gasket would cause oil to puddle above the gasket and even reach the airbox and carbs 6-8inches above it.
any ideas welcomed.
RhynoCZ
PostPosted: 07:44 - 08 Jun 2017    Post subject: Reply with quote
Degrease the engine, start it up, sit next to it and watch where the oil is coming from? Oil creeps out when it gets hot and even ''climbs'' up various surfaces = especial metals.
Also, there might be more than just one vent in the engine. Is the head vented too?
pepperami
PostPosted: 08:17 - 08 Jun 2017    Post subject: Re: how does oil defy gravity Reply with quote
any ideas welcomed.
Oil goes upwards under pressure...... so is there an oil way that is blocked somewhere and that is causing pressure where there is not supposed to be pressure?
When was the last ime the oil filter changed ? A blocked/partially blocked oil filter could mean that returning oil is slower to get back into the sump than the oil being pumped around the engine and thus a back log/ pressure forcing oil to be in places it's not supposed to be.
Just an idea Thumbs Up
pompousporcup...
PostPosted: 08:32 - 08 Jun 2017    Post subject: Reply with quote
that is a theory Pepperami, an oil filter is on order. They're the paper style filter in the sump rather than an external metal filter.. whether they're more prone to clogging up i do not know but that can be ruled out at least.
No breathers, as far as we can see are blocked. A coat hanger through the breather pipes should confirm that 100%
Its difficult to get it to leak without caning it somewhere. I think he has already cleaned the engine a couple of times and run the engine for 20 mins staring at it for leaks with no success.
A major service is on the way for it as a matter of course
PostPosted: 11:58 - 08 Jun 2017    Post subject: Reply with quote
Fork seals?
Does it have an oil cooler?
pompousporcup...
PostPosted: 12:59 - 08 Jun 2017    Post subject: Reply with quote
fork seals are good, checked them myself.
It does have an oil cooler yes.
I have been having a think and am wondering whether the oil is leaking from the front of the cam cover (not unheard of on these engines, experienced it myself) but at speed, and under a higher pressure, the air passing the front of the engine is flinging the hot runny oil up over the cam cover with some of it going onto the airbox and carb tops.. its the only way i can see oil getting to those bits. It then lands on the cam cover and gives the impression it is coming from all sorts of places.
Wonko The Sane
PostPosted: 14:36 - 08 Jun 2017    Post subject: Reply with quote
My ZZR did this!
Can't remember what the issue was as I didn't fix it, think it was gasket related
karoshi
PostPosted: 16:21 - 08 Jun 2017    Post subject: Re: how does oil defy gravity Reply with quote
Wind. it'll be whipping round the fairings and producing some really odd dispersal patterns from wherever it's leaking.
As for places I'd look on a ZZR11..
I'd start with the oil cooler itself, it's right out in front so if it's weeping oil from somewhere it could be going all over the place.
Oil lines to / from the cooler, sump plug, oil filter pan seal, sump gasket, does his model engine have the oil line that goes up to the cams on the RH side of the engine?
Cam cover gasket, spark plug hole seals, does his have the emissions system plates in the cam cover?
After that I'd suspect witchcraft.. as it's a Z have you tried burning sage or sacrificing a chicken?
Smile
Well, I've wrestled with reality for 35 years, Doctor, and I'm happy to state I finally won out over it. - Elwood P. Dowd
The last post was made 8 years, 257 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 58.27 Kb
