| lingeringstin... |
 lingeringstin... Spanner Monkey
| stevo as b4 |
| lingeringstin... |
| lingeringstin... |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 23:19 - 06 Jun 2017 Post subject: |
I'd stick with the Magneto CDi.
As said not tried K-Start on a Benly; But they will 'bump'.... usually... if motor not a complete dodo.
I am a tad sanguine about kicker an CDi as they do seem to like a good crank speed to get started; but I suspect retarded cam timing and low compression on an older motor is likely as much to blame for that as the Magneto system.
Bug-bears would tend to be in the starter, when brushes start to go; or the free-wheel clutch on the crank, which on older motors can get a bit sticky and whiney and not always engage/disengage.
Worth noting they seemed to drop the Kick-start on the Benly motors entirely about the time they went 12v and CDi; and that the duel-start CG had CDi ignition using the same mag and CDi. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| lingeringstin... |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 07:50 - 08 Jun 2017 Post subject: |
Lol.. the pistons are tiny! Open a 125 twin! They are like a thimble!
When the Head-Gasket went on Snowie's Bluddi-Guzzi, (And I'd convinced her she didn't need to take the frame and transmission off to take the engine to bits!) The look on her face when she lifted the head and saw the size of slug in 750 V-Twin, was like she'd had a big black Chippendale drop his gegs in front of her!
Starter chain's are 'OK'.. pay heed to the adapter plate between the crank-case and mag case and the chain guide on it; it's only doweled into location and not clamped up until you bolt down the mag cover, and can be held 'off' by the tight fit around the starter knck.
Whilst the generator is 'inside out' with the stator and pick-ups in the cover; if it's not quite flat or lined up, you can have the starter chain ratling in the guides, but more pertinently, the ignition trigger may not be aligned with the trigger lug on the rotor, and in worst case, if the dowels are omitted or damaged, stator can sit skew in the rotor and possibly rub.
Head & Guides? Valves are tiny, & included angle awkward. I have had to use a small socket on the clamp to get enough 'reach' to get the compressor to bear just on the valve head, and the collet slot had to be thinned down a tad to stop it slipping off to one side or other. Magnet- wand is a real boon to get the collets out/in.
Valve-Guides I believe are non service replaceable; I have had a couple that have been cracked, from piston-valve contact; but I haven't yet had one that has failed the vacuum test and not bee held in with thumb over the seal end or not popped back when pulled against it.
More of a concern has been worn/pitted seats. Local M/C shop don't have cutters that small to re-cut or re-face the seats, and I haven't found one small enough on e-bay! Lots and lots of lapping has been required!
Watch the packing washers on the head end of the valve springs that stop springs eating into alloy of the head; they like to 'hide'! Easy to get a spring swapped and have one with two washers under it, and one with none! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
The last post was made 8 years, 266 days ago. Instead of replying here, would creating a new thread be more useful? |
