setting lever position / angle - how?
Wonko The Sane
PostPosted: 14:34 - 08 Jun 2017    Post subject: setting lever position / angle - how? Reply with quote
How would you go about working out the correct / comfortable angle the lever should be positioned at (I'm talking angle on the bar, not reach length)
Think I took my levers off a few years ago and put them back at the wrong angle and now have aching wrists.
Is there a sensible way to do it or is it simply trial and error?
CaNsA
PostPosted: 14:42 - 08 Jun 2017    Post subject: Reply with quote
I have the brake lever dropped forward, forcing me to roll off the throttle before grabbing the lever,
bamt
I do it just by sitting in my normal position, with my hands in a straight/neutral line with my arms, and that's where the levers should be.
kgm
PostPosted: 15:25 - 08 Jun 2017    Post subject: Reply with quote
I'd adjust it whilst sat on the bike to what feels comfortable to you. If you want the stock position some bikes have a punch mark on the bars which sits at the join between the upper and lower half of the housing. Not all have that though.
I know this picture shows the actual handle bar mounts but it's the same idea for the lever housings:
https://i1231.photobucket.com/albums/ee509/VWMX5Ray/1971%20Honda%20CB175K5/1971CB175K5Restoration015_zpse0214c39.jpg
Teflon-Mike
tl;dr
PostPosted: 15:46 - 08 Jun 2017    Post subject: Reply with quote
Normal seating position; hands on grips; lever should be just beneath fingers of a 'relaxed'' open hand, give or take a little to suit preferance.
If you have aching wrists/hands; they are either grossely out of place, or there's something 'else' like the span out of line, the cable is stiff-siezed, or the handle-bars are actually not quite 'straight'...
IS worth checking the bars; f they are individual clip-ons they aren't always fitted symmetrically; whilst on a conventional bar, only a slight twist or side-to side offset can have you holding them (and or even sitting!) slightly 'skew' and cramping up after a while; and not always visible. Took me ages to track down that the aches the 750 were giving me on longer runs was because the right hand grip was just a tad 'up' from horezontal than the left!! Worth checking forks in yokes whilst you are at it; slight twist of the top-yoke has similar effect.
Wonko The Sane
PostPosted: 16:09 - 09 Jun 2017    Post subject: Reply with quote
Thanks Tef,
It's the ZZR so the bars bolt on with a few allen bolts so in theory can't be that far out compared with clip-ons that clamp onto the fork leg. The forks have been out of the bike but were done properly by a mechanic I trust so I believe it comes down to the levers.
the ache is during the day when working, I get to sit and poke a keyboard and mouse all day which doesn't help, I rotated them down a little this morning and it's taken much longer today for my wrists to start aching (it's rare I ache on the bike) so we'll go from there bit by bit
kraggem, thanks for that suggestion, I'll take a look
The last post was made 8 years, 241 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 51.18 Kb
