Honda NS125, won't rev beyond 5k
mrpetrepp
PostPosted: 13:09 - 12 Jun 2017    Post subject: Honda NS125, won't rev beyond 5k Reply with quote
Hi all.
Recently had an issue where my stroker (NS125), would bog down anywhere between 1/2 - full throttle but now I've sorted it by finding the choke has been stuck on. Now I've another issue, the bike sets off nicely and pulls as it should but as soon as I get to 4k it splutters and sounds rough as well. I've checked the reeds for any cracks and I cannot see any light through them, I've adjusted the float bowl height and I've got it idling at roughly ~1500RPM.
I've the needle on the leanest setting. Could this be a lean bog?
Thanks for the help. New to strokers, so would like a bit of insight
Smile
stirlinggaz
PostPosted: 14:49 - 12 Jun 2017    Post subject: Reply with quote
Hi,
Whereabouts in throttle position is this issue happening?
& have you tried moving the c-clip on the needle? (4 notches iirc)
cheers,
GAZ
mrpetrepp
PostPosted: 03:19 - 13 Jun 2017    Post subject: Reply with quote
stirlinggaz wrote:
Hi,
cheers,
GAZ
It happens between half throttle and full throttle. It'll rev nicely up to about 5k, then will refuse to go any further...it sort of just splutters about. I currently have the c-clip on the highest notch which is the leanest I believe? I haven't tried it on the richest. I will give that a shot and get back to you.
cheers
The last post was made 9 years, 126 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.97 - MySQL Queries: 13 - Page Size: 35.41 Kb
