| matthews1892 |
 matthews1892 Derestricted Danger
 Posted: 12:41 - 12 Jun 2017 Post subject: front sprocket noise (video) |
hey guys,
notice this noise earlier and took off the front sprocket casing, teeth look fine to me yet this is as far as my mechanical knowledge goes, any ideas what the noise could be?
its a cbr125r 2011 18k miles new chain/sprockets in the past 6 months.
ive uploaded the video to youtube :
https://youtu.be/Jtr00J3nVPQ |
| Howling TerrorOutOfOffice |
| matthews1892 |
 Posted: 13:01 - 12 Jun 2017 Post subject: |
That my friend is the sound of a chain running over the sprocket.
Wait here a little longer and you'll get other replies.
Only thing I will add (totally unrelated to your video) as you mentioned new C&S is have you checked the chain tension. Some new chains stretch a little. ____________________ Diabolical homemade music Bandcamp and Soundcloud
The Harry Turner Project |
| pompousporcup... |
 pompousporcup... World Chat Champion
 Posted: 13:41 - 12 Jun 2017 Post subject: |
how dry is the chain? Oil up the rollers and see if the noise gets quieter
as above, that is pretty much the sound a chain makes as it turns with the sprocket. A dry chain will make it sound louder ime
How many miles were done in this '6 months' and do you lube your chain enough? Its surprising how quickly a chain or sprocket will wear when left to run dry for extended periods |
| matthews1892 |
| skatefreak |
 Posted: 14:10 - 12 Jun 2017 Post subject: |
new(ish) to bikes or just this one or just had something done and now all you can see/hear is 'somethings wrong'?
I would suspect you've only just 'noticed' the problem because your attention has been drawn to the drive train since work was done to it and now you've 'found a new noise' to worry about...
I'm a nightmare for this... My 2l turbo diesel's had the terminal top end rattle of impending doom (that no one else can hear for some strange reason) for at least 20,000 miles .
My R1's about to throw a rod (although everyone else say's it sounds lovely with a very mild top end tick (common on older yzf's)).
It's all about gaining experience and learning what 'stuff's supposed to sound like as well as managing personal paranoia (of you are so inclined).
On topic -> chain sounds fine... |
| pompousporcup... |
| sickpup |
 sickpup Old Timer
| skatefreak |
| Falco |
 Falco Traffic Copper
| sickpup |
 sickpup Old Timer
| Falco |
| sickpup |
 sickpup Old Timer
 Posted: 00:44 - 13 Jun 2017 Post subject: |
The standard sprocket part no. is JTF297.15, 297 is the pattern and 15 the tooth count so RB on the end must be the rubber bits.
New line for JT there. |
| MCN |
 MCN Super Spammer
| Falco |
 Posted: 12:12 - 13 Jun 2017 Post subject: |
| sickpup wrote: |
I'm surprised they haven't jumped on it before. Seemed nice, smooth and quiete this morning, but it's the first ride on a new chain, so I'd expect that anyway.
Looking at the old sprocket, I noticed it was a 14 tooth, this new one is 15 tooth (which appears to be standard). What difference (if any) will that make? ____________________ I tell you what, mathematically, I'm having it |
| Matt B |
 Matt B World Chat Champion
 Posted: 09:21 - 14 Jun 2017 Post subject: |
More teeth on the front basically means more top end speed and less acceleration.
Edit - you can plug the sprocket sizes into https://www.gearingcommander.com/ and compare stock to -1 on the front. ____________________ stinkwheel: He had an animated .gif of a cat performing fellatio. It's not socially acceptable. It can have real life adverse effects on other people. |
| Falco |
The last post was made 9 years, 114 days ago. Instead of replying here, would creating a new thread be more useful? |
