spark gs400
Jay2903
PostPosted: 13:08 - 12 Jun 2017    Post subject: spark gs400 Reply with quote
Hopefully the last post on this one.
Its a gs400 that im trying to get running. ive checked all the wiring + connections + grounds, battery is good, new brushes in the starter motor, switches seem fine. cranking voltage almost 10v. rectifier, pickup coils and stator checked/tested. New ignition coils + new fuse.
Theres two suspicious things. For the right coil I measured about 12v on the + and - cables that go to it.
On the left coil there was 0v for the + and 12v for the -
Second thing- the left ignition coil heats up after a few minutes.
Wiring diagram - https://s61.photobucket.com/user/Jay29031/media/gsx400_zps9n5bbmlw.jpg.html?filters[user]=145531479&filters[recent]=1&sort=1&o=1
my diagram - https://s61.photobucket.com/user/Jay29031/media/IMG_3027_zpsws7xpbui.jpg.html?o=0
Any help greatly appreciated
Jay2903
PostPosted: 01:39 - 14 Jun 2017    Post subject: Reply with quote
Anyone got any ideas ?
uberkron
PostPosted: 05:39 - 14 Jun 2017    Post subject: Reply with quote
I would guess your igniter, if not points have failed. What year?
i ride a zip 50 2smoke. It overtakes a hundred times a day.
bikenut
PostPosted: 11:35 - 14 Jun 2017    Post subject: sparks Reply with quote
Or could you increase voltage across battery when cranking by using the assistance of a good fully charged car battery??
Battery dependent ign system which may "drop out" due to insufficient battery "energy" when cranking.
As to a coil getting hot, is that the one that makes a spark. Do both coils make a spark?
How was "trigger" res values one compared with the other??
nuts about bikes
bikenut
PostPosted: 11:38 - 14 Jun 2017    Post subject: start Reply with quote
Is the starter button a combined starter/ign kill type??
nuts about bikes
bikenut
PostPosted: 11:41 - 14 Jun 2017    Post subject: start Reply with quote
Also could you increase voltage across battery when cranking with the help of a fully charged battery, ign system looks as if its battery dependent and may "drop out" due to insufficient "power" when engine is cranked.
nuts about bikes
Jay2903
PostPosted: 12:49 - 14 Jun 2017    Post subject: Re: start Reply with quote
Yea it is
Jay2903
PostPosted: 12:50 - 14 Jun 2017    Post subject: Re: start Reply with quote
I'm using the battery from the 550 with the charger connected to it on Boost/start mode.
Jay2903
PostPosted: 12:52 - 14 Jun 2017    Post subject: Reply with quote
no points
1984
Jay2903
PostPosted: 12:55 - 14 Jun 2017    Post subject: Re: sparks Reply with quote
Its the left coil that heats up, neither spark but the spark indictor flashes for a second when you hit the starter button.
The last post was made 9 years, 123 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.36 - MySQL Queries: 13 - Page Size: 61.93 Kb
