| MrCawdell |
 MrCawdell Derestricted Danger
| Commuter_Tim |
 Commuter_Tim World Chat Champion
| sickpup |
 sickpup Old Timer
| MrCawdell |
| MrCawdell |
| Commuter_Tim |
| Robby |
 Robby Dirty Old Man
| sickpup |
 sickpup Old Timer
 Posted: 09:27 - 16 Jun 2017 Post subject: |
| Commuter_Tim wrote: | Sickpup is known for getting people to play the guessing game, so I will attempt to interpret in case he's feeling playful... |
Its a thinking game not a guessing game but I was being straight forward there
| Commuter_Tim wrote: | I believe he means pad the worn area around the bolt out with a sliver of beer can. |
Precisely. You fill the space between the bolt and the bush with a rolled up tube of steel beer can.
| Commuter_Tim wrote: | Sometimes I forget that Sickpup is an old geezer, they can fix everything on a bike with a beercan and a cereal box.  |
| Commuter_Tim wrote: | Jokes aside, I gather he knows his bikes so probly worth a crack.
They don't disassemble on an MOT so they would certainly never know. |
Even for an MOT it is a perfectly valid repair. Unorthodox to todays way of thinking where everything is just replaced but valid nonetheless
| Robby wrote: | It shouldn't be a swingarm replacement job. Assuming the shock has an eye type fitting at each end, then it will have a bush at each end (that can wear) and a bolt through that bush on the swingarm and on the frame. |
These don't, the bolt rests on the swingarm hole.
| Robby wrote: | The wear would be in either the bushes, or the bolts, both of which could be easily replaced. |
Both are available as parts
| Robby wrote: | The fun comes in when you replace the bolts and bushes and it's still loose, because the build quality/tolerances are shit. This is when you shim it. |
I have a brand new top bolt and bush in the tool box that has more slop than one with 70,000miles on it. The tolerances are terrible on these.
All of this relies on the bottom bush being in good condition, if it isn't just get a engineering shop to replace it as it requires pressing out and the new pressing in. |
| Rogerborg |
 Rogerborg nimbA
 Posted: 10:42 - 16 Jun 2017 Post subject: |
Mmm, as I intimated in a PM, Kawasaki are notorious for this. My old GPZ500 had a sloppy shock linkage with just 4000 miles on it.
I know it came up as an advisory last year but that may just have been an overly cautious tester or one that was looking out for it on a Kwak.
I'd fire it through another MOT first before deciding if you need to sort it. ____________________ Biking is 1/20th as dangerous as horse riding.
| Ed Case |
 Ed Case World Chat Champion
| kgm |
 kgm World Chat Champion
 Posted: 18:30 - 16 Jun 2017 Post subject: |
My '10 plate ER6 with 16k has no play at all, I must have got lucky.. I recently discovered though that the lower mounting bolt was totally seized to the sleeve and the needle bearing wasn't in the best condition. I replaced them easily enough using a drawbolt set up for the needle bearing and top bush. Think I'll keep an eye on that and take it apart from a clean and grease occasionally from now on.
I don't think the guy who does my MOTs is very thorough, he just has a quick check round and makes sure all the lights/horn work then fires out a new certificate. Glad I don't have to deal with someone overly thorough  |
| MrCawdell |
| colink98 |
 colink98 Could Be A Chat Bot
The last post was made 8 years, 297 days ago. Instead of replying here, would creating a new thread be more useful? |
