AJS ECO-1 replacing headlight bulb
Bike Chat Forums Index -> Forum Feedback & Help
Hughmoz This post is not being displayed because it has a low rating (Off Topic). Unhide this post / all posts.
PostPosted: 11:09 - 25 Jun 2017    Post subject: Reply with quote
Workshop section, chap.
But yes, you can.
Stock Ching-Chong 35kW glow-worm.
https://2.bp.blogspot.com/__DYtEEjm5wE/SdPeCERUCgI/AAAAAAAAACY/Hi0Y4oAPCyA/s320/dim_lights.jpg
50W/50W 7500K bulb:
https://3.bp.blogspot.com/__DYtEEjm5wE/SdPeFoQbyVI/AAAAAAAAACg/jF32MofLYcU/s320/bright_lights.jpg
Keep an eye on the housing to check that it's not melting.
Hughmoz
PostPosted: 11:52 - 25 Jun 2017    Post subject: AJS ECO-1 Replacing Headlamp Bulb Reply with quote
I'm asking about using an LED BA20D and not increasing the the wattage of normal bulbs thanks.
PostPosted: 13:04 - 25 Jun 2017    Post subject: Re: AJS ECO-1 Replacing Headlamp Bulb Reply with quote
You'll want to increase wattage on ba20 to get brighter. LED will always be brighter than basic ba20, however you'd be better off with more wattage than going LED.
Hughmoz
PostPosted: 14:53 - 25 Jun 2017    Post subject: AJS ECO-1 Replacing Headlamp Bulb Reply with quote
Thanks, however, my bike has a plastic headlamp with a lot of connectors for the handlebar electrics in it and will not presumably react well to increased heat? If I put a higher wattage that will be a problem in terms of heat, hence my request re LED with a BA20D fitting. Why do you say that increased wattage is better than LED as a matter of interest? Halford's say that it is illegal to use LED's except in side lights and that you can use HID's, but, those have an adaptor kit which there is not room for within the headlamp space. I thought that LED's had a more focussed light as opposed to normal headlamp bulbs which have a spread light? Certainly a 35/35 watt normal headlight bulb is almost akin to riding blind in terms of seeing pot holes or anything else etc., although, other people can see you.
PostPosted: 15:57 - 25 Jun 2017    Post subject: Reply with quote
Oh, sorry, I didn't really read your question through the Off Topic red mist. Embarassed
From threads passim (in the Workshop section...) the jury seems to still be out on LEDs. There are some suggestions in that thread, but it might be a case of sucking it and seeing.
It's lumens that matter, but be aware that cheaper LEDs are likely to make fantasy claims about their brightness.
The last post was made 9 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> Forum Feedback & Help All times are GMT + 1 Hour
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 48.39 Kb
