Weights / Benches etc
colink98
PostPosted: 16:06 - 03 Jul 2017    Post subject: Weights / Benches etc Reply with quote
Hi All.
The lad has got all body concious all of a sudden at the age of 15.
Must be a girl or a boy or something.
About a month ago he said he wanted to start training and we have for the last 4 weeks been doing a small program 3 days a week.
This consisted of Squats/pull ups (aided), leg raises, push ups, sit up and dips.
to be fair the lad is trying hard each week and i promised if he kept it up that we would get a bench and some weights.
having a quick look on Amazon and don't know what to trust.
the cheap do everything units seem a bit low quality.
id rather spend on something simple but of quality.
a bar and weights is a simple thing
https://www.amazon.co.uk/TNP-Accessories-Barbell-Weights-60KG/dp/B00VD3DTBA/ref=pd_bxgy_200_2?_encoding=UTF8&psc=1&refRID=MP013EHVVKHEWPD4RZH3
but its benches...
worth noting that both the lad and i are not small.
both 6ft and 14+ stone.
so the bench needs to be able to support us and the weights.
this looks like a good bet
https://www.amazon.co.uk/We-Sports-Premium-Fitness-Workout/dp/B00D1W48IO/ref=sr_1_73?ie=UTF8&qid=1499094224&sr=8-73&keywords=weights+bench+with+weights
its not a vast sum of money but a yay or nay from someone with more experiences than me would be appreciated.
Ride it like you stole it.
mudcow007
PostPosted: 17:05 - 03 Jul 2017    Post subject: Reply with quote
look on gumtree/ ebay etc loads of quality brand secondhand stuff.
Prices are staying quite high as its fashionable to keep in shape now.
Ive always liked "York" cast iron weights
sensi5446
PostPosted: 20:45 - 03 Jul 2017    Post subject: Reply with quote
Best advice I can give is to tell him to keep up with the body weight training, push ups, squats, pull ups etc and possibly take up something like mauy thai which will help with any body issues and boost confidence.
He's to young to be lifting weights IMO, he's got plenty of time to pump iron when he hits his late teens early twenties.
Just to add, for a good bench check out somewhere like power house or fitness super store.
Hawkeye1250FA
PostPosted: 21:20 - 03 Jul 2017    Post subject: Reply with quote
Cant comment on simple weights etc... but I replaced my gym membership with this...
https://www.sweatband.com/vfit-herculean-cobra-lay-flat-multi-gym.html?gclid=Cj0KEQjw1ufKBRDYrqLzrY3dy88BEiQAPI_r4dNBQZxYLr6KiGr8xSNSGGIBlzNMup7LaJ7HyMRXY6IaAhjC8P8HAQ
And it's been great. Easy to use - and the bench folds away when not in use.
1993 RF400R - 2002 Bandit 1200 - 2012 1250 FA
stevo as b4
PostPosted: 23:53 - 03 Jul 2017    Post subject: Reply with quote
Kind of agree with the above, as teens can fuck themselves up by going too hard too soon with weights and lifting. If he's sensible I'd just start with some dumbbells and maybe fix some hand bars into the ceiling joists for pull ups etc.
Proper serious weight training and supporting diets should IMO start in your early 20's and your peak body condition should be present around the end of your 20's>.
If it's definition and fitness he wants more than size and shape, then nothing beats press ups, pull ups, sit ups, and hyperextensions done little and often. At the gym I'd probably start with rowing machines and a machine shoulder press first too.
colink98
PostPosted: 08:48 - 04 Jul 2017    Post subject: Reply with quote
Point taken.
I will stop and reconsider before doing anything else.
colink98
PostPosted: 08:50 - 04 Jul 2017    Post subject: Reply with quote
Cheers for the heads up.
will keep a book mark of that to consider.
DrDonnyBrago
PostPosted: 12:39 - 04 Jul 2017    Post subject: Reply with quote
If he does get in to weight training, a safe and effective home gym should contain a power cage, bench and a barbell. Anything else is optional.
Very versatile equipment and the cage is pretty much essential if he wishes to squat/bench press on his own, the spotter bars make failing a rep safe... Youtube is full of kids messing up on a squat or bench press with a heavy bar and stapling themselves to the floor or being trapped under the bar.
As for programme, 5x5 stronglifts is far from perfect but it is a good start.
dodsi
Dirty Carny
PostPosted: 13:45 - 04 Jul 2017    Post subject: Reply with quote
I would just say a cheap gym subscription if possible.
All equipment is then more top of the range, you are in a better environment from a safety aspect. And a cheap subscription can be £20/£25 per month which is a lot less to lose than investing in a bunch of gear in one hit.
BTTD
PostPosted: 13:52 - 04 Jul 2017    Post subject: Reply with quote
As already mentioned, 15 seems a bit young.
I thought it was because the body/bone structure is still developing, but I may be talking rubbish.
DrDonnyBrago
PostPosted: 16:17 - 05 Jul 2017    Post subject: Reply with quote
If you are still keen Colin, I'd suggest something like this for the rack and bench - beginner friendly and not overly expensive, still loads better than a normal bench or squat stands.
Rack (a few companies sell this with their own badges, all around £80):
https://www.ebay.co.uk/itm/MIRAFIT-Adjustable-Squat-Rack-Dip-Stand-Barbell-Weight-Gym-Bench-Power-Lifting-/331717188972?epid=1742246376&hash=item4d3be29d6c:g:gHQAAOSwA29Y44r6
Bench (you don't want the bar supports on the bench, pick whatever reviews well in your budget, this is just an example but should be fine (250 kg capacity)):
https://www.ebay.co.uk/itm/MIRAFIT-Fully-Adjustable-Folding-Gym-Weight-Bench-Flat-Incline-Dumbbell-Lifting/351625078304?rt=nc&_soffid=5019882608&_soffType=OrderSubTotalOffer&_trksid=p5731.m3795
Reasons:
> Can be used for squats and bench press - the spotter bars provide a level of "backup" should your lad drop the bar, get stuck during a squat or be unable to press the bar off his chest. Smaller and cheaper than a power rack.
> Can be used for dips, although you'd need to make it narrower (it is adjustable) if you had been using it for bench or squats. >Smaller and cheaper than a power cage whilst still offering most of the benefits over a conventional bench with bar support.
Note:
You'll want a longer bar to work with the supports being positioned outside of your hands (rather than between them like most cheap bench press outfits). A normal argos etc bar is 5 ft, you'd need 6 or 7 foot. Best bet is to buy a 7ft bar and plates used on gumtree. Two types of bar/plate exist, standard 1 inch and olympic 2 inch - refers to the size of the hole in the plate - olympic bars (thicker) are usually 7ft. Either is fine but you are more likely to find a used 7ft olympic set.
Fin
PostPosted: 22:29 - 05 Jul 2017    Post subject: Reply with quote
15 does seem a bit young but if he's 6ft and 14 stone then he's got weight to lose.
I'd always recommend decent 2nd hand stuff over any cheapy new stuff. When I was 15 everyone was aware of lifting too much or too hard could stunt your growth.
I'd say he should go for high reps low weight and more superset stuff.
colink98
PostPosted: 09:42 - 06 Jul 2017    Post subject: Reply with quote
We are going to be moving in the next month or two (if the buyer stops cocking about)
So we have decided to continue with the current stuff 3 times a week and re-asses when we are settled in the new place.
Jewlio Rides Again LLB
PostPosted: 23:03 - 07 Jul 2017    Post subject: Reply with quote
Got a JD Gym near by? Cheapest gym membership I found and is well stocked, benches galore. Generally only one of each machine, resistance, treadmills, bikes etc excluded. Plus classes are included in the fee.
Mpd72: I can categorically say i’m Brighter than that, no matter how I come across on here.
HAHAHA HAHAHA Blew Chilly MyCrowSystems
Robby
Dirty Old Man
PostPosted: 13:58 - 08 Jul 2017    Post subject: Reply with quote
I highly recommend some sessions with a decent trainer, particularly when starting off.
It's easy to work the big muscles that look good. I did this a lot in my late teens/early 20s, and it worked nicely. Then I dislocated my shoulder surfing, because whilst I had nice big biceps, the tiny little muscles in my shoulder weren't getting developed at all.
Now I'm older and don't care so much, so I have much smaller arms, but my shoulders don't pop out when I swim in the sea. That's from seeing a personal trainer who knows shoulders well. Surprising how much a 2kg weight can hurt if you use it right.
PostPosted: 20:46 - 11 Jul 2017    Post subject: Reply with quote
I've got a similar model rack to the one DrDonnyBrago posted and happy enough with it.
I also made a more substantial 'cage' that did the job well from spare wood/metal - total cost was about £2 for some more screws.
I'd definitely go second hand for most stuff - the weights especially, don't really have much to go wrong with them, being lumps of metal, so no point buying new.
I ever actually made a bit of money judiciously trading up weights to an Olympic set, buying carefully and selling with better descriptions etc.
The last post was made 9 years, 82 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 91.99 Kb
