| sparkywilliam... |
 sparkywilliam... Scooby Slapper
| Kris |
 Kris World Chat Champion
 Posted: 14:09 - 30 Jun 2017 Post subject: |
Hit the starter, then when she fires up hit the kill switch.
Do this four or five times then let it run and warm up as normal. ____________________ NSR125RR - ZXR750H1 - ZX9R E1 - GSF600S - GSF600SK3 - VFR400-NC30 - SV1000N - ST1100-R - CBR900RR-R - GSF1200SK5 - GSF600SK1 - VFR1200FA - GSXR1000K2 - ZZR1400 D8F
www.prisonplanet.com |
| redeem ouzzer |
 redeem ouzzer World Chat Champion
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 15:23 - 30 Jun 2017 Post subject: |
Have you turned it over by hand, to make sure the cam's not 180 about of anything daft ad valves about to get mashed by pistons?
Then, I ted to do oil-pressure spin up, plugs out, odd an old car battery on jump-leads to save the diddy bike one.
Then first fire the same way; avoiding prolonged cranking; whilst trying to get t to catch and burn off assembly lube.. again short bursts, to save the starter.
Once it's caught; it'll probably not stay alive too well, as it burns off; so I play it y ear and try not to let it rev or race, and may pull plugs and have to clean before it'll settle down, and I get a steady idle to warm up and burn off; when exhaqust smoke clears and it'll run without choke; I'll let it tick over for a miute or two, before letting it coole before pulling hot plugs and popping clean new ones, to tweek carb settings ad set base idle.
But main tip, if there is one, is to use car battery on jump-leads... I never expect them to play ball, and faffing about tryng to find a crossed coil connection or a misaligned trigger, or that the fuel tap's ot on, or the vac-hose is split, or or or.... can beg a fair bit of cranking, and kill a little bike battery. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| sparkywilliam... |
| stinkwheel |
 Posted: 17:28 - 30 Jun 2017 Post subject: |
If you're super paranoid, leave the rocker cover off and the plugs out, bung it in second gear and push it about until you see the oil coming up into the rocker box.
If you want to turn it over without it actually firing, just short across the solenoid terminals with the ignition off. This'll turn the starter over but nothing else.
In harsh reality, oil pumps on modern bikes are such that the oil will be up there within a second or two of firing it up as anyone who's bled the oil pump oin a dry sump bike will tell you.
Contrastingly, it takes 2m 30s of idling for oil to get from the oil tank to the rocker box on an enfield bullet. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| stevo as b4 |
| Pete. |
 Pete. Super Spammer
 Posted: 17:34 - 30 Jun 2017 Post subject: |
Just start it. Do you think that they go through all that crap at the factory or do they fill it with oil and hit the starter? ____________________ a.k.a 'Geri'
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 22:35 - 30 Jun 2017 Post subject: |
| Pete. wrote: | Just start it. Do you think that they go through all that crap at the factory or do they fill it with oil and hit the starter? |
According to a Kawasaki Promo-vid, I watched recently; they roll the bike onto a rolling road at the end of the line; it's motored up on the rollers, before fire; then goes through something like a five minute simulated road test, to check brakes and gears and throttle response etc, before final 'run' takes actual RW BHP figures.
Engines appeared to be sent to line all oiled up and ready to run, after a similar end of line bench test, but they didn't show what they did on the bench...without exhaust, I suspect it was only being motored.
With Japanese Corporate Bushido and career sepuku expected for any 'operator error'; they don't tend to get many "Ah! Now, why do I have four bolts and a gasket that doesn't seem to belong any-where?" moments, we get in the DIY world  ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| stevo as b4 |
| Shaft |
 Shaft World Chat Champion
 Posted: 00:10 - 01 Jul 2017 Post subject: |
| stevo as b4 wrote: | Yeah but if they are making 100 ZX10R's a day for example, I bet they don't, and can't rolling road test each bike for even 5mins.
I worked on the production line years ago for the then Midlands biggest manufacturer. I was in quality control at the end of the line near where the guy puts petrol in before they drive the cars off the line.
It was no more than 1car per hour we'd take off for detailed inspection, though several cars would have already passed through rectification bays for stuff like panel fit and imperfections in the paint.
Even fewer cars would get pulled off for random rolling road testing in terms of performance testing. Obviously as cars come off the line they are brake tested on a roller, but it's a 30second process at best.
They never bench test all engines either in most volume car production, can't see bikes being any different in volume production. |
If that was anything to do with BL/Rustin Over, I wouldn't admit to that - the sketchiest QC of any car I ever sold, up to and including TVR and Lotus! ____________________ Things get better with age; I'm close to being magnificent........
WooHoo, I'm a Man Point Millionaire! https://www.bikechatforums.com/viewtopic.php?t=234035 |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 01:07 - 01 Jul 2017 Post subject: |
| stevo as b4 wrote: | Yeah but if they are making 100 ZX10R's a day for example, I bet they don't, and can't rolling road test each bike for even 5mins. |
KAWASAKI History, by Discovery channe
Have a look; I think it was that one; show the final test around 29min in. OTMH I think they were making ER6's, and reckoned they made about one a minute; all fully tested at EOL.
As far as offering precedents for 'best practice' in QC offering the example of Longbridge or heaven forbid Brownhlls, is rather like suggesting the USA as a precedent for good gun control! Lol!
I was actually just oop-rowed at Looo-Kuss; but had joined after a while working for a German electrical 1st teir making switches and harnesses most notably for Toyota at Derby.. when the Japs said 100% test, they MEANT 100% test! Test rig actually had a key lock down on it, so if an indy switch failed, it would lock it to the rig, and start sounding klaxon and flashing beacons, and making the line lights flash, until a QC came and put the key in, and he couldn't restart the line until he got a code off the computer for entering the failure investigation report!
I came in one morning to absolute chaos; when the test-rig had shut down the line; three days of major meetings and international tele-cons later, and a junior production engineer spending 36 hours on air-liners to get 'parts' to fix the rig.... 'problem' having been bottomed out to the test rig computer's hard drive having reached capacity for saving test results!!! I went t work for Looocas! It was like a village cricket club social evening by comparison!
Actually.. come to think of it, DKL was a village cricket club social evening... that occasionally looked at light-bulbs! Seriously, I knew blokes who's promotions were entirely attributable to their batting average, rather than what they dd at work! "Yes, I KNOW he's an idiot... but we needed a good left field if we were to beat Acocks green!" lol! (I dont play cricket, probably why I never made senior management I guess!) ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| chickenstrip |
 chickenstrip Super Spammer
 Posted: 11:04 - 01 Jul 2017 Post subject: |
| Teflon-Mike wrote: | probably why I never made senior management I guess!) |
I can think of other possibilities  ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
THERE'S MILLIONS OF CHICKENSTRIPS OUT THERE! |
| sparkywilliam... |
| Tankie |
 Tankie Crazy Courier
| MCN |
 MCN Super Spammer
The last post was made 8 years, 272 days ago. Instead of replying here, would creating a new thread be more useful? |
