Not enough clicks on rebound adjuster
MarkJ
PostPosted: 12:34 - 14 Jul 2017    Post subject: Not enough clicks on rebound adjuster Reply with quote
Hi all, bought a K7 GSXR1000 track bike, works great except on both the front front forks I can only wind the rebound adjuster out 4 clicks or so. Standard settings is meant to be 6 out, so it's probably only got a third of the adjustment it's meant to have.
I ran it at Cadwell and it's working as you'd expect with a bit more rebound resistance so the forks are fine, just not enough rebound.
Has the fork cap been wound on too far? It's a GSXR 1000 K7
redeem ouzzer
PostPosted: 13:18 - 14 Jul 2017    Post subject: Reply with quote
It's been assembled slightly fuzzy so the adjuster is a bit high or low on the damper rod and you can't get the full range of adjustments.
Be a REAL MAN!
The last post was made 8 years, 273 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 30.92 Kb
