need a quick fix promblem solving
broomy12
PostPosted: 11:23 - 09 Mar 2005    Post subject: need a quick fix promblem solving Reply with quote
i have a honda ns 125r and its delevoped a problem it starts up ok and seams to rev fine then i pull away and then it starts to die and it seams like its bering starved from fule but the fule filter is clear, the air filter is ok and i cant seam to find ne more problems with it cam some one help i would be very greatfull thanks.
Broomy
PostPosted: 12:44 - 09 Mar 2005    Post subject: Re: need a quick fix promblem solving Reply with quote
Quick translation
broomy12 wrote:
I have a honda NS125R and it's delevoped a problem. It starts up ok and seems to rev. fine, then I pull away and then it starts to die.
It seems like it's being starved of fuel but the fuel filter is clear, the air filter is ok and I can't seem to find any more problems with it.
Can someone help? I would be very gratetful, thanks.
Broomy
It could be any number of things. Including (but not exhaustivley) Blocked tank breather, coked up exhaust, blocked fuel tap, blocked needle valve and worn piston rings.
Have you messed with anything immediatley before this happened? Did the problem start abruptly or has it come on gradually?
map
Mr Calendar
PostPosted: 12:53 - 09 Mar 2005    Post subject: Reply with quote
As starting fine and only problems when moving off suspect main jet on carb may be blocked or need adjustment.
If problem with bike moving off under load then possibly electrical or the coked exhaust as stinkwheel said (had that Rolling Eyes). Check the carb first (easier and cheaper) then maybe exhaust.
HTH Smile
broomy12
PostPosted: 13:09 - 09 Mar 2005    Post subject: Reply with quote
It has happend before. sept it when away and i dont know why. the carb looks fine. o and before it cuts out it back fires. i dont know if that makes any matter worse or easyer to figure out what the problem is. did nothing with it before it started doing this all thats changed is the spark plug after this had happend before. it will pull away but then after about 20 seconds or so it dies back fires then goes dead. thansk for the replys as well there v handy.
Broomy
alains
PostPosted: 19:08 - 09 Mar 2005    Post subject: Reply with quote
check the level of the float chamber , and the valve .
broomy12
PostPosted: 13:49 - 10 Mar 2005    Post subject: Reply with quote
im guesing this means taking it all apart he he he. how fun im glad i bought a manual.
Broomy
The last post was made 21 years, 220 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.49 - MySQL Queries: 13 - Page Size: 48.43 Kb
