Idle screw on a mikuni carb, which way is which setting?
simon1221
PostPosted: 14:44 - 09 Mar 2005    Post subject: Idle screw on a mikuni carb, which way is which setting? Reply with quote
Basically im lookin for a:
Screw in -> richer / leaner
Screw out -> richer / leaner
Type of answer.
If it helps it is closer to the airbox, rather than the engine Rolling Eyes
PostPosted: 14:55 - 09 Mar 2005    Post subject: Reply with quote
Arrow Idle screw which alters the height the throttle valve sits at (and therefore the Idle speed):
Screw in (clockwise) = higher revs.
Arrow The pilot or mixture screw which alters the fuel:air mix at tickover:
Screw in (clockwise)= richer.
Don't confuse the two!
Shouldn't really make a difference anyway, screw the mixture screw in and out by fractions until you get the highest rev speed then adjust the rev speed to tickover using the idle screw. It is more a 'by ear' thing than an 'on paper' thing, especially with an older engine.
simon1221
PostPosted: 15:24 - 09 Mar 2005    Post subject: Reply with quote
I meant pilot mixture screw.
It almost stalls at low revs when doing corners for some reason.
I did alter the fuel level in the carb, will this be it?
PostPosted: 16:56 - 09 Mar 2005    Post subject: Reply with quote
Probably, altering the float height will affect pretty much everything to do with the carb.
I was talking to a couple of guys the other day who were messing with their classic racer. They were bumping the float height up slightly to compensate fo the fact that their current throttle needle was too thin and making it run a bit rich and the next size up was a bit too fat.
The last post was made 21 years, 229 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.7 - MySQL Queries: 13 - Page Size: 40.44 Kb
