Helmet size query...
SkaDad
PostPosted: 19:07 - 24 Jul 2017    Post subject: Helmet size query... Reply with quote
Hi folks
So bought my first helmet. Fit really snug and couldnt move my head around.
Trouble is after fitting the pinlock, the visor got stiff and now the whole helmet moves up when I try to open visor. Now a two hand job and have to hold helmet steady. Does this just mean there is a visor / pinlock problem, or more likely I have bought wrong size helmet and it is a little too big..?
Evil Hans
PostPosted: 19:30 - 24 Jul 2017    Post subject: Reply with quote
Possibly a bit of both.
Sure you've refitted the visor correctly? Is the pinlock catching on anything?
SkaDad
PostPosted: 19:41 - 24 Jul 2017    Post subject: Reply with quote
Its like the helmet and visor didnt leave a space for the pinlock so now with the pinlock thing in - its like a seal sticking visor to helmet...
PostPosted: 20:01 - 24 Jul 2017    Post subject: Reply with quote
Where the helmet seals against the top of the visor? Seems plausible, my pinlock has been scraped to buggery against the rubber seal. I don't have a solution, just sympathising.
Alpineandy
PostPosted: 20:33 - 24 Jul 2017    Post subject: Reply with quote
What helmet is it.
Is the pinlock correct for that helmet?
The above comment isn't necessarily the truth and anyone that says it is, is only correct if it's the truth or they're bigger than me.
SkaDad
PostPosted: 12:15 - 25 Jul 2017    Post subject: Reply with quote
It's an MT Kre Sv, the pinlock came with it so presume correct. Sent company a message - will just leave off for now.
angryjonny
PostPosted: 14:01 - 25 Jul 2017    Post subject: Reply with quote
Rule I was taught is that you should just about be able to get the fingertips of one hand in between your forehead and the helmet liner, above the visor aperture. Even a well fitting helmet will probably move around a bit - it shouldn't just be able to roll off your head though.
colink98
PostPosted: 14:18 - 25 Jul 2017    Post subject: Reply with quote
are you saying the pin lock part of the visor is catching on the inside of the helmet when you are raising the visor forcing the whole heltmet to move up ?
in which case did you put the pin lock in upside down ?
Ride it like you stole it.
supZ
PostPosted: 14:24 - 25 Jul 2017    Post subject: Reply with quote
doesn't the mechanism have any adjustment?
normally there are a few degrees of movement to readjust tension on the visor.
depends on the helmet of course though.
CBR954RR - Daily toy
CBR600RR - Trackbike
RjMaan This post is not being displayed because it has a low rating (Confusing). Unhide this post / all posts.
Tracer1234
PostPosted: 10:06 - 21 Aug 2017    Post subject: Reply with quote
RjMaan wrote:
Don't worry most of the helmets are like that. It is designed in a way to have no space between head and its inner walls. You can use the rear view mirrors to look behind.
Two for two!
Both posts of yours that I have read so far have left me thinking WTF. Are you deliberately posting confusing nonsense?
Riding: Yamaha MT-09 Tracer Occasionally Riding: 08 Suzuki SV650, Potato: 2011 Yamaha YBR Custom.
Used to ride: 2015 Yamaha MT-09 Tracer (smidsy) 09 Triumph Street Triple (P/X'd) 08 Yamaha YBR (Sold)
CBT 04/14. A: Mod 1 & 2 13/04/15
SkaDad
PostPosted: 13:54 - 21 Aug 2017    Post subject: Reply with quote
I was thinking the same - someone trying to get up their post count in order to access forum functions..? Not sure how this forum works but seen that elsewhere...
As an update - now I am getting out and riding more,I realise (a) there are a sum total of zero times where I need to open the visor one handed when riding, and (b) helmets are designed to be removed off the top of the head so movement that way when pushed is inevitable... While the pinlock does make the helmet excessively stiff - its not the end of the world and the helmet fit is fine.
NJD
PostPosted: 21:49 - 21 Aug 2017    Post subject: Reply with quote
If by first helmet you mean first motorbike and first time on the roads then in fairness I'd probably want to keep my hands on the bars at all times as well.
I crack mine open at the lights, when it rains (because current helmet pinlock has its limits) and whenever else is needed. It's not as scary as it sounds and one thing I got taught while training for A2 was going round in circles in the yard one handed (right hand of the bars felt abnormally scary). When your stopped use your right hand and when you're on the move use your left (although I have a central opening mechanism and if yours is on the left only, like most, its a bit of a pain).
When you need to crack it open depends what speeds you're going and conditions you're pootling about in. I find rain on sub 30mph roads, or 30mph roads, a pain in the rear because you're not going fast enough to get the air flow (depends on helmet as to how well it deals with it).
RE: Future helmet size testing - make sure you do all the tests to see how loose it is when the helmet is undone (ie: not buckled up) in front of a mirror. Tell bike shop man to sod off if you feel like you're being pressured into buying one. Returning a helmet (like not an exchange for a different size) is a pain in the arse.
The last post was made 8 years, 156 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 76.11 Kb
