| johnsmith222 |
 johnsmith222 World Chat Champion
 Posted: 21:46 - 30 Jul 2017 Post subject: Rusty Arches - Saab 9-3 2007 |
Hi guys,
I was looking for your opinions on my rear wheel arches, which are rusting quite badly on my Saab 9 3 1.9 TiD with 112,000 miles on it. I purchased this car for £2300 18 months ago, with no sign of arch rusting then.
My car also needs a DMF and clutch fitted (will do myself on driveway), usual service items, and likely a timing belt/waterpump change (I will check these next weekend or so).
I would fit the DMF, but tbh these rusting arches are stressing me out, and I was looking for some help as what to do. I am thinking if I start rubbing paint off, then I'm going to find holes.
I have a number of options. These are what I think I can do:
1. Pay for a professional body repair to the rear arches
2. Attempt to repair it myself
3. Let it rot.
I have never had the rear arch liners off, and so I've never been behind to see what's going on. I have ordered myself some G101 cleaner, and I plan to get behind the arches and clean it as best as I can, to try and slow down the progression of the rust.
If I was to attempt a fix, I was thinking of masking off the area, getting a wire brush attachment for the drill, and get the paint/rust off. I have also been looking at hydrate 80, or the gel that converts/inhibits rust. Then I'd be looking at which primer is best (I heard a particular type is best for preventing rust, but can't remember which). Then I'd spend some time sanding, then building coats of black paint (any recommendations as to where to get a good match?).
Then for the clear coat, I'm not so sure... I'm aware of the hazard of isocyanates in clear coats, but will need to look into what mask etc I need. Also I only have a driveway, so I'd be working witht he car outside :/
I live in Scotland, and they put down a lot of salt at the winter time, so I think this is something that needs sorted before then.
I have added photos so you guys can see and give your opinion.
Many Thanks for any help.
https://imgur.com/a/HeDPA |
| Bikeless |
 Bikeless World Chat Champion
| arry |
 arry Super Spammer
| johnsmith222 |
| johnsmith222 |
| stevo as b4 |
| M.C |
 M.C Super Spammer
| johnsmith222 |
 Posted: 19:56 - 31 Jul 2017 Post subject: |
| stevo as b4 wrote: | Does the car mean alot to you in a sentimental way or something? You have a fairly left field undesirable brand of noughties car and it's also a high mileage diesel with the usual diesel issues.
Reason I ask is that there's genuinely not that many 2000> family cars that have any real enthusiast following yet, so cost vs value will be terrible for all your repairs and doing proper bodywork if it needs more involved work like new metal welding in etc. Also for alot less than £2300 you'd likely get another family sized comparible car that has several years of use and abuse left in it.
I've got a 1994 car, and though very rare now I'd still have to think twice before having major bodywork or serious rust issues sorted if it needed that sort of work, as they arnt worth enough to spend quite a few ££££ on bringing back rotten bodywork yet. If they were at Escort cosworth value then of course it'd be worth it, but even as a big enthusiast at this point in time I'd have to say no. |
Hi Steve,
To be honest the car doesn't mean anything to me sentimentally, and while I like it a lot and how it drives, I don't think buying it was the best decision at the time.
I feel the value has dropped far enough, that it's perhaps not worth selling, and might as well go down with the ship, rather than sell it and take substantial loss on it, for the time that I've owned it.
This is especially true as the clutch and flywheel have gotten worse over time, and now this rust is a cosmetic issue, as well as the whole diesel regulation problems etc.
In my head, I was thinking of keeping this car for a minimum of 4 years (now 2.5 years remaining) but perhaps that might not be so realistic.
I don't really care too much about how the car looks, but dont' fancy fitting a clutch and flywheel on a car that's going to start failing MOTs due to rust. I always see older rusty bmw and mercedes about, so maybe it's slow enough that I don't need to worry about the rust and just let it get on with it.
We both checked those arches meticulously before we bought it, but we didn't check behind the wheel arch liners. Otherwise it was a good car.
To be honest, I'd rather have something like a toyota auris or something. Thing is the running costs haven't been much more than my clio so far for this saab, excluding the clutch and DMF to change.
Then again, I do really like the car I have, excluding the rusty arches and clutch/flywheel. |
| Shaft |
 Shaft World Chat Champion
 Posted: 23:53 - 01 Aug 2017 Post subject: |
There's only one way that's being fixed, chop out the rot and let in new metal - are there repair panels available for them?
You can bodge it by grinding it back, using some snake oil rust inhibitor and filling in the lacework you'll be left with, but it will be busting back though in under a year, worse than before.
And I'm with arry, somebody has been there before, you're fighting a losing battle. ____________________ Things get better with age; I'm close to being magnificent........
WooHoo, I'm a Man Point Millionaire! https://www.bikechatforums.com/viewtopic.php?t=234035 |
| johnsmith222 |
 Posted: 09:12 - 03 Aug 2017 Post subject: |
| Shaft wrote: | There's only one way that's being fixed, chop out the rot and let in new metal - are there repair panels available for them?
And I'm with arry, somebody has been there before, you're fighting a losing battle. |
Thanks shaft, maybe someone has been behind before to repair it before.
If a bodge won't really slow things down and just cost more money in the long term, maybe I should just leave it until it fails an MOT, then as you guys have suggested, bodge it to pass. That or get myself a welder and learn how to fix it.
I now have a dilema. My clutch and flywheel are getting worse (they have been bad since I got the car but was going to change it anyway).
Do I spend the £300 on it to change the clutch, flywheel and slave cylinder? (parts only on my driveway). I wouldn't hesitate to do this, if the car wasn't rusting badly at the rear arches.
I was hoping to get another 4 or 5 years out of the car, but don't know if that's doable.
Also, I see plenty of BMWs from the 90s with similar rust or worse driving about. Mainly 7 series (although I get they're top quality), and 3 series. Can I expect my rusty car to last similarly.
Also, there's an absolute bucket of a 1992 saab 900 at my work, with holes the size of fists everywhere. I checked and it has a recent MOT!!!! :o
If bodging the arches bought a year or two extra, even if I had to do the job again, then that would definitely be worth it for me. |
| doggone |
 doggone World Chat Champion
| johnsmith222 |
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 16:24 - 03 Aug 2017 Post subject: |
I can see another 2-3 years, maybe 5. But you've got to get to work this instant and it's a never ending fun. I drive a 22 years old car (winter = salt) and I fix every chip in the paint job and I wash the car properly right after the winter season ends, including the undercarriage.
Now, inspect the car for rust, if you don't know what to look for, ask a experienced mate.
CHEAP FIX:
Looking at your pictures, I would remove the paint to have a look under it. If there are no holes through, then clean it properly and spray it with a filler spray (or even car putty = takes some time and extra effort), then colour (ask local paint shop, you don't need much of it OR buy generic green paint in a can) and after all that put a coat of clear lacquer over it.
STILL QUITE CHEAP:
Grind off the paint, prepare the place, then give the car to a profesional. After that do your own paitnjob (the same as above = clean it + filler + colour + clear lacquer)
EXPENSIVE:
Let the professionals do it all. I would not bother. The preparation work and paint job are the most expensive parts of the process.
Why should you start right now?. You see, right now you have exposed metal (+rust) and the cracked paint job on the arches actuall allowes water (+salt) to stay there for longer than it should, making your issue even worse = the rust ''grow'' quicker.
IF you fix it, you will (unless something goes wrong) see your car do another 5 years. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
The last post was made 9 years, 60 days ago. Instead of replying here, would creating a new thread be more useful? |
