| cowie86 |
 cowie86 L Plate Warrior
| P. |
 P. Red Rocket
| arry |
 arry Super Spammer
| UrbanRacer |
 UrbanRacer World Chat Champion
 ..... Quote Me Happy
| cowie86 |
| P. |
 P. Red Rocket
| cowie86 |
| arry |
 arry Super Spammer
| cowie86 |
| P. |
 P. Red Rocket
| cowie86 |
| DrSnoosnoo |
 DrSnoosnoo World Chat Champion
| grr666 |
 grr666 Super Spammer
 Posted: 14:38 - 31 Jul 2017 Post subject: |
I jumped our scoot after it's winter layaway from our Suzuki Swift and amazingly everybody involved survived including
both vehicles. ____________________ Currently enjoying products from Ford, Mazda and Yamaha
Ste wrote: Avatars are fine, it's signatures that need turning off.  |
| cowie86 |
| DrSnoosnoo |
| cowie86 |
| cowie86 |
| Kawasaki Jimbo |
 Kawasaki Jimbo World Chat Champion
| raystone |
 raystone Two Stroke Sniffer
 Posted: 18:45 - 31 Jul 2017 Post subject: |
I've had a very similar problem. The battery read 12.5v, so I thought it's not the battery.
The kicker was when I turned over the motor, the starter motor all ran off fine, but the voltage actually dropped to 6v or so. That's way, way too low.
So, you've said the 12.5v do not change when the starter motor engages, that's a bit strange – it should start jumping around a bit (depending on multi-meter). Make sure you haven't clicked the HOLD button on the multi-meter, it may just hold the highest reading!
I put my money on the battery, too. Halfords does have them, and you may even have a chance to return them, I asked nicely and had my scooter parked right in front of the shop. The guy said I should try if it starts with the battery he sold me, if not, I'll be able to return it. |
| Kickstart |
 Kickstart The Oracle
 Posted: 18:50 - 31 Jul 2017 Post subject: |
When you turn the ignition on, do you get the neutral light / etc on?
When you press the starter button do you get any clicks? The starter relay should click (it is in effect an electrically operated switch). If it doesn't click then use the multimeter to check if the relay is being triggered.
The relay will have 2 big wires going to it, one to the battery and one to the starter motor (you can carefully bridge these to check the engine will turn over, but be careful!). It will also have either one or 2 wires to it (or it might have a whole bunch of wires if it controls the rest of the electrics). If it has 2 wires then one is probably power (probably switched on when the starter button is pressed); check one is earthed and one has power when the button is pressed / not pressed. If it has one wire then it is probably an earth that is switched when you press the starter button (ie, the relay gets power all the time from the main feed from the battery, and the relay operates when the small single wire is earthed).
Katy ____________________ Traxpics, track day and racing photographs - Bimota Forum - Bike performance / thrust graphs for choosing gearing |
| andy_uk |
 andy_uk World Chat Champion
| RodYork |
 RodYork Scooby Slapper
 Posted: 21:05 - 02 Aug 2017 Post subject: |
I don't know if this is too late- but could you not just ring up a local school to you & ask to borrow one ____________________ Bike trip through Europe! https://www.youtube.com/watch?v=Z2yTtFPM7Xc |
| arry |
 arry Super Spammer
| Robby |
 Robby Dirty Old Man
The last post was made 8 years, 148 days ago. Instead of replying here, would creating a new thread be more useful? |
