| ScottT |
 ScottT Scooby Slapper
| Commuter_Tim |
| Teflon-Mike |
 Posted: 23:16 - 30 Jul 2017 Post subject: Re: Repairing a sprocket |
Some old Brit-Biks had rear sprockets cast integral with the hub, that may be a little difficult to replace, '-b-u-t' I believe that there have been specialists who have been milling them off and shrinking on new 'ring' sprockets to salvage the hubs for many years......
Talon Sprockets in Coventry used to boast that they would make specials to order for 'anything', and I suspect they still do...
So I am very skeptical of your aspersion that
| ScottT wrote: | finding one is impossible. |
And suspect that it is simply beyond the possibility of e-bay and google flu, by make/model/year... Give us THAT clue at least, though.....
But my start point would be to google Talon, and not expect e-bay chinky bit prices..... they used to say that if they didn't list it f you took or posted them the old one, they'd make to pattern! And that was when blokes in boiler suits with a woodbine hanging from thier mouth measured stuff with micrometers! With CMM and CNC's these days, I doubt they find it even that difficult! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| P. |
 P. Red Rocket
 Posted: 04:42 - 31 Jul 2017 Post subject: |
Is the make of bike a big secret? The more info you give the better answer you'll get. ____________________ a.k.a 'Geri'
| Ste |
 Ste Not Work Safe
| MarJay |
 MarJay But it's British!
| ADSrox0r |
 ADSrox0r World Chat Champion
 Posted: 16:56 - 31 Jul 2017 Post subject: |
IF (unlikely) you can't find one, they are usually a standard pitch and number of teeth (uless they are REALLY old, like pre-war).
You can buy blank ones.
Then all you need is to get the middle machined correctly. I seem to recall some companies just wanted you to draw round the old one. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| ScottT |
 Posted: 18:47 - 31 Jul 2017 Post subject: |
Sorry for not replying earlier, the bike in question is a 1931 James model C12.
They were only made for 2 years and so far my research has throw up there are two 1931 versions and one 1932 version left in the UK!
There might be others but from people in the know all i'm hearing is there are 3 of them, so ebay is not much use, i could spend a few years wandering around auto jumbles with my original sprocket to compare, but who has the time for that?
A few other bikes used the same Albion gearbox, but again finding spares is an issue.
So far my options are:
1.Weld new teeth on.
2.Machine the sprocket down and fit a outer ring with new teeth.
3.Or have a company make me one from scratch.
I asked because i just thought someone might have been in a similar situation and might be able to tell me about companies that will do options 2 & 3 as some of you have mentioned, thank you.
I probably should change my avatar, the beemer went 6mths ago
The bike in question.
https://classic-motorbikes.net/wp-content/uploads/2015/10/11564.jpg |
| pompousporcup... |
 pompousporcup... World Chat Champion
 Posted: 18:52 - 31 Jul 2017 Post subject: |
wow, that was unexpected
option 3. |
| MarJay |
 Posted: 19:08 - 31 Jul 2017 Post subject: |
Yeah option 3.
John Hemmings Engineering ____________________ a.k.a 'Geri'
| grr666 |
 grr666 Super Spammer
 Posted: 19:10 - 31 Jul 2017 Post subject: |
| ScottT wrote: | Sorry for not replying earlier, the bike in question is a 1931 James model C12.
This post was unexpected rating needed. ____________________ Currently enjoying products from Ford, Mazda and Yamaha
| lingeringstin... |
 lingeringstin... Spanner Monkey
| ScottT |
 Posted: 20:19 - 31 Jul 2017 Post subject: |
Love the idea of having a boss made so i can bolt new sprockets on, but there just isn't the room. The sprocket is on the outside of the gearbox and the clutch is outside that, a rough guess would say i've got 2-3mm maximum clearance either side of the chain.
I'm not bothered about upsetting purists or have it exactly right, i just want to ride it, changing sprockets is going to be a long time away, with a rigid rear end there is minimal chain stretch plus when new it produced 2hp so its hardly likely to be chewing chains & sprockets (thats why i mentioned welding new teeth, i think they would last a year or so). If its lost half hp every 10yrs it will be producing minus 2hp now
Though having said that, when new it had a cast iron piston, mine at some point has been replaced with an aluminium one from the sports model.
Going off my other bikes mileage i guess when i'm using this i'll probably only do 300 miles a year, 500 max so a new sprocket should last a few years. I'm not in a rush to get it ready March next year is my target just really got some engine work to do and it will be sorted.
For the people who only know about modern bikes, on this i can change the ignition advance/retard on the move, i can also change the fuel/air mixture also on the move, full engine mapping at my fingertips!!! Lol. Plus it has a dry air cooled clutch like Rossi's bike, except his isn't made from corks!
Hand gear change is 1 forward, 2 back. |
| lingeringstin... |
| ScottT |
| Teflon-Mike |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 06:15 - 01 Aug 2017 Post subject: |
I can't add anything constructive, but that is cool as fuck.
have you tried talking to Talon? They've always been very helpful IME. ____________________ My Flickr |
| recman |
 recman World Chat Champion
| Wafer_Thin_Ham |
The last post was made 8 years, 143 days ago. Instead of replying here, would creating a new thread be more useful? |
