Ticking noise but an unusual one! I need help! Video include
Artens
PostPosted: 22:14 - 01 Aug 2017    Post subject: Ticking noise but an unusual one! I need help! Video include Reply with quote
VIDEO OF THE SOUND
https://youtu.be/4y1sudRXe3g
So im lost. Cbr 125 rw7 fuel injected. Done piston ring and head gasket change and cam chain tensioner adjuster to a manual one a few weeks ago. Havent touched or adjusted the valves tho. The sound arrived just in 1 day- straight away. So i took rocker cover off to inspect it. So. What happens is - when the INLET valve is CLOSING, just before it closes it makes a TICK. Doesnt matter how fast the engine runs, the tick noise even appeared when i was turning the engine really slowly. When the engine is at idle - I have few descriptions for that sound - sounds like diesel - or sewing machine. I am studying mechanics but this is just out of my league. Also - rocker arm doesnt seem loose and the tick only happens when the inlet valve closes. ( didint notice power lose.)
Anyway, any help will be appreciated, thank you so much for reading,
Arturas.
Artens
PostPosted: 09:34 - 02 Aug 2017    Post subject: Reply with quote
Up
Artens
PostPosted: 01:43 - 03 Aug 2017    Post subject: Reply with quote
Got help from other forum. Everybody ignores here. Meh. If anyone will get same kind of sound and after adjusting valve clearance the sound wont change - it could be weak valve springs that needs replacing - that happened to me..
yen_powell
PostPosted: 06:19 - 03 Aug 2017    Post subject: Reply with quote
I feel bad now for not typing 'I don't know' when you first posted.
I did wonder if perhaps you were tutting without realising as you were doing it.
XT1200Z and a DR350 in bits
stevo123
PostPosted: 20:14 - 04 Aug 2017    Post subject: Reply with quote
The valve is thankfully a simple component which always helps! I would look to remove the valve spring and check for crack(s), I can not think of anything else that would make a noise in that area
The last post was made 8 years, 145 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 43.59 Kb
