Motorcycle cutting out when engine gets hot
ARS125
PostPosted: 18:34 - 05 Aug 2017    Post subject: Motorcycle cutting out when engine gets hot Reply with quote
Aprilia RS 125 derestricted.
Spark plug blown so i fitted a B9EG plug (it was all Halfords had in stock).
Took it out for a 40 or so mile ride today and i had to pull over and let the engine cool several times.
At approximately 65-68c the engine cuts out and loses all power. Once it cools to 60c or below it starts again normally.
Is this caused because i should really have the B10 spark plug in the derestricted bike? I know that the 2 stokes shouldn't be run too hot but you can take them a fair bit over 70c usually right?
Bike is running lean as its only got 100 miles on the new engine. Maybe less.
As a side note, my hearing is absolutely fucked. Is this common with the RS 125? in the search for a noise isolating helmet Shocked
Copycat73
PostPosted: 18:57 - 05 Aug 2017    Post subject: Reply with quote
what plug does the hand book say ?
caveat emptor
ARS125
PostPosted: 19:37 - 05 Aug 2017    Post subject: Reply with quote
B9EG - restricted RS125
B10EG - derestricted RS125
I have the B9EG in the desrestricted RS.
Its weird. Bike runs spot on until it gets to 68+ then it cuts out. Soon as the temperature drops the engine starts first time again.
Power value kicks in as it should at about 8k revs.
Copycat73
PostPosted: 07:04 - 06 Aug 2017    Post subject: Reply with quote
go to a big motorbike dealer and buy B10EG .. don`t buy of evil-bay or any other sh1t on-line .. if you must buy on-line use https://www.wemoto.com/
caveat emptor
PostPosted: 10:16 - 06 Aug 2017    Post subject: Reply with quote
The 10 plug is slightly colder than the 9 you are using which means it will transfer heat away from the electrode a bit faster. That's why the de-restricted bike needs the next number up.
It's got nothing to do with the engine over-heating. Most probably that is due to running lean, not something you want to do on that bike.
ARS125
PostPosted: 10:19 - 06 Aug 2017    Post subject: Reply with quote
Already have a B10EG ordered in at my local garage. Ordered it in the same day as i fitted the B9EG, the garage just takes fucking ages to get parts in. Hopefully ready for this afternoon.
My thought is that the B9EG is a cooler spark plug and hence fails to work at the higher temperatures that the derestricted RS reaches. So with a bit of luck the new plug will sort it.
Gonna have a look for corroded or loose wires today because my headlights stopped working. My main beam flash lights work but not using the switch.
I'm not very mechanically inclined but the RS gets you learning quick Laughing
Copycat73
PostPosted: 13:17 - 06 Aug 2017    Post subject: Reply with quote
I am correct in assuming that...
the engine is a four-stroke liquid cooled single cylinder with electronic injection and 4 valves. Euro 4
with a Double overhead camshaft - DOHC
assuming this is the case and it is NOT a 2 stroke example .. since I`m not knowing what the year of manufacture is..
what is the current millage ?
and when was the last time the valve clearances was done ?
caveat emptor
cb1rocket
PostPosted: 13:22 - 06 Aug 2017    Post subject: Reply with quote
It's a 2 stroke, 4 stroke don't have power valves
smegballs
PostPosted: 13:36 - 06 Aug 2017    Post subject: Reply with quote
https://2static.fjcdn.com/pictures/What_1ce6d2_6050699.jpg
Copycat73
PostPosted: 13:48 - 06 Aug 2017    Post subject: Reply with quote
0oops Laughing
had forgotten about them ... whats this power band ... do they come in different colours Rolling Eyes
PS.. the 2017 model is a four stroke item...
caveat emptor
smegballs
PostPosted: 14:03 - 06 Aug 2017    Post subject: Reply with quote
Sick
Now that is real heresy. Should have had the decency to retire the line and launch a new model...
Copycat73
PostPosted: 14:08 - 06 Aug 2017    Post subject: Reply with quote
smegballs wrote:
Sick
no need .. all the competition is four stroke now ...
unless you want a scooter ... well that's what google says .. personally I`ve never looked at a 125 for over 18 years Neutral
caveat emptor
ThatDippyTwat
PostPosted: 14:29 - 06 Aug 2017    Post subject: Reply with quote
That's the RS4, not the RS. 15BHP, same lump is in a few bikes.
Copycat73
PostPosted: 15:00 - 06 Aug 2017    Post subject: Reply with quote
oh I give up Doh!
..... gonna look at Africa twins on the net.com. now
PS.. check the compression on that 125 ....
could be lookin at rings and maybe a re-bore... won`t know till you lift the head & block off..
caveat emptor
PostPosted: 15:21 - 06 Aug 2017    Post subject: Reply with quote
Copycat73 wrote:
oh I give up Doh!
Thank fuck for that.
PostPosted: 17:02 - 06 Aug 2017    Post subject: Reply with quote
The way I'd like to see this arcane issue addressed is with a picture of the bike plus a tin of custard.
ARS125
PostPosted: 21:27 - 06 Aug 2017    Post subject: Reply with quote
Its had a new engine fitted with less than 100 miles on. According to the previous owner its good to run them in lean?
So the bike cutting out at higher temperatures has nothing to do with the plugs?
Compression should be fine being a new engine?
ARS125
PostPosted: 21:28 - 06 Aug 2017    Post subject: Reply with quote
Did you just say a tin of CUSTARD? Shocked please explain why i would upload a tin of custard? lol.
But sure, if you want some pics i will upload them in the morning, its a little dark and the headlights ain't working Rolling Eyes
PostPosted: 22:16 - 06 Aug 2017    Post subject: Reply with quote
No of course it's not good to run an engine in lean. Lean running produces higher temperatures, the exact opposite of what you want. Until the parts have bedded in you need to keep the engine temperatures down.
The last post was made 8 years, 248 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 109.09 Kb
