| speedingmotor... |
 speedingmotor... Two Stroke Sniffer
 Posted: 11:53 - 07 Aug 2017 Post subject: CG125 rumbling after tire change. EDIT |
Hello
I recently did some other work and put new tires on my CG125 1979, changed the handlebars and took off the front fork and reinstalled it. and it sat without a full reservoir of oil for a few months (!) when i got the tires and handlebars back on, the clutch was stuck engaged. I was able to disengage it but now there is some rumbling from the lower part of the bike, I dont know
1) if i have misaligned the tires. ( i dont think so I have measured the distance
2) i have put the front end together wrong and/or there are problems with the bearings/bushings
3) if i have damaged a part of the clutch (possibly the release bearing)
4) maybe something else happening?
when i am rolling down the road if i squeeze the clutch its pretty quite, there is alot of vibration when under load, and at different revs of rpm.
Q: Could i drain the oil out take off the case and have a look at the clutch and see if there is a problem. what should i look for? Would it be neccessary (advisable) to take off the plates and have a look at the whole mechanism?
Thanks so much ____________________ https://www.youtube.com/watch?v=zojEIR_SGSk
Last edited by speedingmotorcycle on 09:58 - 08 Aug 2017; edited 1 time in total |
| MCN |
 MCN Super Spammer
 Posted: 15:35 - 07 Aug 2017 Post subject: |
https://hondacg125.awardspace.com/
Font of CG125 ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| speedingmotor... |
 Posted: 16:16 - 07 Aug 2017 Post subject: |
Thanks MCN , I know that website. I was just wandering if someone wanted to chime in RE the vibration and rumbling, and if it was worth it for a novice to dive into the clutch and have a look, or if it might be something else.
 ____________________ https://www.youtube.com/watch?v=zojEIR_SGSk |
| speedingmotor... |
 Posted: 18:00 - 07 Aug 2017 Post subject: |
for info this is my front sprocket, should it have this much side to side play? i think so ?
https://youtu.be/VXjnJXTXXwY
i opened the crankcase cover and checked the clutch, the clutch release bearing didnt look super messed up, but i didnt have the tool to take off the centrifugal filter and then the plates, maybe its worth giving that a shot?
thanks bcf family ____________________ https://www.youtube.com/watch?v=zojEIR_SGSk |
| MCN |
 MCN Super Spammer
| speedingmotor... |
 Posted: 09:46 - 09 Aug 2017 Post subject: |
The vibrations are only present when the clutch is engaged, so i am thinking it is from the lower part of the motor, i just dont know if it could be other pieces that are messed up. ____________________ https://www.youtube.com/watch?v=zojEIR_SGSk |
| Darby Gloss |
This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
 Darby Gloss L Plate Warrior
 Posted: 10:15 - 09 Aug 2017 Post subject: |
hi, I am a new here, nice to see u, and do you want you buy produces with high quality and inexpensive, there are a lot ofjammer blocker you can see and I believe you can find a good one. |
The last post was made 9 years, 16 days ago. Instead of replying here, would creating a new thread be more useful? |
