Bike compatibility
FazerRider
PostPosted: 23:01 - 11 Aug 2017    Post subject: Bike compatibility Reply with quote
Hi peeps,
I have just recently been re introduced to the world of biking after 28 years, and have just passed my bike test in June, now I own an imported FZS 600 Fazer on a '03 plate, I would like to know, if there are other bike parts that are compatible with it, like fairing, fuel tank anything else, etc.
FazerRider
PostPosted: 09:33 - 12 Aug 2017    Post subject: Reply with quote
I have already joined foc-u.co.uk
I have not had a response to any posts I have posted, and no one uses the chat room that is on the site, but does'nt matter now, as the questions I asked on foc, have been answered here, so all good Thumbs Up
UnspeedySam
PostPosted: 13:45 - 12 Aug 2017    Post subject: Reply with quote
Most of the parts from the first generation FZS600 will fit, as your bike is just a facelift of that. Pretty much only the plastics changed I think.
Some bits off the Thundercat and R6 of similar age will also fit. Also the rear brake off the TRX850 fits with some modification, which is supposed to seize up a little less often...
What do you need?
Hahadumball
PostPosted: 14:34 - 12 Aug 2017    Post subject: Reply with quote
vtr fairing fits the fzs 600 with light modification...
boxeye fzs fairing fits foxeye and other way
fzs 1000 rear caliper fits with light filing on the standard fzs hanger
trx caliper fits with modding but more ballache than its worth
change the rear caliper asap if you plan on riding it in rain or winter.
braided lines help massively
thundercat engine does not fit.
oem filter is best.
you cannot (its not worth) jetting
+1 front sprocket takes away the feel of thrashing it everywhere
the torque arm for the rear caliper mount point on the swingarm is shit.. after a lot of winter use and not cleaning properly
https://i.imgur.com/jx7pF4X.jpg
my first when i got it and then when i was almost done with it
https://i.imgur.com/jv8aTLp.jpg
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
Amber Phoenix
PostPosted: 15:25 - 12 Aug 2017    Post subject: Reply with quote
Much stuff is interchangeable with other Yammy bikes.
All but front fairing, headlights and associated brackets from older FZS600's will fit yours. But note, yours has better mirrors, bigger tank, front suspension preload adjustment, different grabrail and better pillion pegs.
Some stuff is same as FZS1000: e.g. mirrors, headlight cluster. Rear brake caliper fits with very minor mod (and well worth doing).
Some stuff is same as Thundercat: e.g. rear wheel.
Some sundaries are common across many Yamaha bikes, e.g. clutch plates.
Best plan, is find the piece you're after on Fowler's, get the part code and Google what else it's for. Just note last 2-4 digits can vary to indicate colour variations.
Beginner Biker Adventures Blog
Yamaha FZ6 S2 2007
The last post was made 8 years, 274 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.45 - MySQL Queries: 13 - Page Size: 48.64 Kb
