agv helmet visor coating on the inside?
Hahadumball
PostPosted: 09:29 - 20 Aug 2017    Post subject: agv helmet visor coating on the inside? Reply with quote
cleaned my new agv visor on the inside and outside and noticed some weird coating inside peeling off..
any ideas what this is?
anti fog insert?
https://i.imgur.com/N5JPa0h.jpg
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
MCN
PostPosted: 23:36 - 20 Aug 2017    Post subject: Reply with quote
Protective Film prevents scratching before sale.
Peel off.
Buy Pin-lock kit and fit.
Or buy pin-lock visor.
No pin-lock is dire. If you ride in inclement weather's.
Hahadumball
PostPosted: 11:56 - 21 Aug 2017    Post subject: Reply with quote
hmm seems to work for anti fogging, breathing out hard on it last night and not an ounce of fogging
UrbanRacer
PostPosted: 12:04 - 21 Aug 2017    Post subject: Reply with quote
Did you use Flash bathroom cleaner or something?
I've had several AGV lids and a few extra visors and never seen anything like this.
I regularly clean both sides of my visor too with warm water and sponge.
RhynoCZ
PostPosted: 13:58 - 21 Aug 2017    Post subject: Reply with quote
I'm with Liam, what did you use to clean it?
I clean my visor with fresh water only, and if it requires a bit more, I use hand soap. The worst thing to use is a dish detergent, bath room detergent and other stuff of this sort.
Hand soap makes the process a bit quicker.
Hahadumball
PostPosted: 00:03 - 22 Aug 2017    Post subject: Reply with quote
fresh warm water and fairy liquid on a sponge, wasnt rough either
UrbanRacer
PostPosted: 10:59 - 22 Aug 2017    Post subject: Reply with quote
rpsmith79
PostPosted: 12:10 - 22 Aug 2017    Post subject: Reply with quote
DrSnoosnoo
PostPosted: 12:26 - 22 Aug 2017    Post subject: Reply with quote
I'll bite. Why is Fairy Liquid worse than hand soap?
Monkeypony
PostPosted: 12:38 - 22 Aug 2017    Post subject: Reply with quote
Because salt.
Current bike - 2018 H2-SX, 2004 SV1000s, 2016 Aprilia RSV4 RF, 2017 Sherco SERF 300, 2003 Suzuki DRZ400 (stolen - AY53 JUU)
DrSnoosnoo
PostPosted: 13:00 - 22 Aug 2017    Post subject: Reply with quote
Monkeypony wrote:
Because salt.
Why?
Formerly known as
P.
PostPosted: 13:03 - 22 Aug 2017    Post subject: Reply with quote
BCF vs Scientist.
https://media.giphy.com/media/TrDxCdtmdluP6/giphy.gif
Monkeypony
PostPosted: 13:04 - 22 Aug 2017    Post subject: Reply with quote
DrSnoosnoo wrote:
Why?
Because fairy liquid is full of it, and it can cause scratches to plastics and paintwork.
Apparently...
Personally, I only clean my visor with furniture polish.
But I wash my chain with WD40.
DrSnoosnoo
PostPosted: 13:26 - 22 Aug 2017    Post subject: Reply with quote
Apparently...
So dissolved salt in fairy liquid is equally as abrasive in all combinations? I would suggest some warm water with fairy liquid (now the salt is even less concentrated) and a soft sponge would have no ill effect. Perhaps we should advise to use deionised water? What with the amount of sodium and chloride ions present in tap water? I bet he was in a hard water area too, even worse!
I may sound argumentative but it's good to question "don't do".
Monkeypony
PostPosted: 13:31 - 22 Aug 2017    Post subject: Reply with quote
Quite correct. Any harmful effects would likely take years to be visible, but folks do worry so.
Regardless, furniture polish is still the best thing to clean a visor with Thumbs Up Laughing
DrSnoosnoo
PostPosted: 13:33 - 22 Aug 2017    Post subject: Reply with quote
Very Happy
Double PS - there's salt in hand soaps too but shhhh don't tell anyone.
And with polish, the dirt present which gets lifted by the degreasers etc, is also abrasive. Unless you can wipe it all away in once smooth wipe, this will have a slow effect.
OTOH, I only ever use a bit of dish soap and warm water on some kitchen roll to clean my AGV K3 visor and haven't had this coating wear away in this fashion.
MCN
PostPosted: 13:55 - 22 Aug 2017    Post subject: Reply with quote
The salt is sodium and is dissolved in the detergent.
It improves wetting.
But since most salts are corrosive they can harm sensitive surfaces.
I do not think dish detergent would eat a coating like that so easily.
Some science-ish stuff:
https://chemistry.elmhurst.edu/vchembook/558detergent.html
Coatings are more likely damaged by alcohols or other spirits.
I used Hein Gerike Lens Cleaning Spray on my Pin-Lock. Unbeknowenst to me there is an anti-fog coating on the inside of the pin-lock insert. The Hein Gerrike cleaner destroyed the coating.
I think the offending culprit was the Isopropyl alcohol in the spray.
I also had a Posh pair of Uvex wrap-a-round safety specs that I used a 'specs-cleaner' to clean.
I noticed that the tint disintegrated a few days using the work's cleaner.
I contacted Uvex who asked what cleaner I used?
And they said, 'Uvex cleaners are designed to clean but not destroy the coatings of their specs.' Sad
Hahadumball
PostPosted: 17:56 - 24 Aug 2017    Post subject: Reply with quote
been made apparent that fairy liquid is shit, but its ate into the anti fog coating in 1 wash?
winz
PostPosted: 20:44 - 24 Aug 2017    Post subject: Reply with quote
Pol, does this mean you're riding again or still a cripple?
Current Bikes: BMW K1200S
Previous: Honda CBR929RR, Honda CBR1100XX, Honda CB600F
Hahadumball
PostPosted: 13:59 - 26 Aug 2017    Post subject: Reply with quote
i is riding, back is still mega spazzpain but is ite
The last post was made 8 years, 174 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 109.34 Kb
