Help with bike maintenance
Davemc37
PostPosted: 21:28 - 23 Aug 2017    Post subject: Help with bike maintenance Reply with quote
Ok so I bought my first big bike last month and it's the first bike I've had in over 20 years. Between being away at the weekends and working long days I've not yet had the chance to do anything to do it yet including washing it although I have done a very quick and probably rubbish clean and lube of the chain.
The question is what should I be doing and how often to keep the bike running smoothly conscious that I haven't so much as looked at a spark plug in 20 years.
born again biker with a mere 23 year gap between bikes.
UnspeedySam
PostPosted: 21:34 - 23 Aug 2017    Post subject: Re: Help with bike maintenance Reply with quote
What bike is it and when was the oil last changed? If you don't know, I'd get the oil, oil filter and maybe air filter and spark plugs (depending on condition) changed.
Chain tension is one a lot of people neglect, so check that. Maybe lubricating the throttle and clutch cables if they seem a bit dry.
If you don't know when the valve clearances were last done that's probably worth looking into getting done (probably not a job to be tackling alone to start with).
M.C
PostPosted: 22:24 - 23 Aug 2017    Post subject: Reply with quote
Read the owners manual (if you have one), buy a Haynes manual if one exists for your bike. Pumping the tyres and lubing the chain (assuming not shaft drive) is all you have to do in the short term. Check the oil level occasionally as well.
Evil Hans
PostPosted: 22:41 - 23 Aug 2017    Post subject: Re: Help with bike maintenance Reply with quote
Davemc37 wrote:
30 years since my first bike. 3 weeks since my full license
You took nearly as long as I did ...
Kentol750
PostPosted: 22:48 - 23 Aug 2017    Post subject: Reply with quote
You bought (What bike?) last month, was it in use? If so, just maintain it to your capabilities. If not, do as above have suggested and then get a competent mechanic check it over. Watch and ask what he does and learn what you can do safely.
Some bikes.
PostPosted: 22:59 - 23 Aug 2017    Post subject: Reply with quote
It's a 2012 Suzuki V-Strom 650. Wink
By the power of the internet, I give you the workshop / service manual for your bike: https://www.v-strom.co.uk/downloads.htm
Do you know a guy called Adam Aarons or a girl called Suzie Fuller?
Kentol750
PostPosted: 23:09 - 23 Aug 2017    Post subject: Reply with quote
Oh, well done Ste. (Coughtwatfucksmartarse).
Shouldn't need much doing apart from riding then.
Some bikes.
The last post was made 8 years, 163 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 51.94 Kb
