| stinkwheel |
 Posted: 16:10 - 31 Aug 2017 Post subject: How would you check camshaft end-float in an OHV engine? |
When I come to fit new cams in my enfield 500 bullet, I'm supposed to set the end-float between the canshaft and the timing cover to between 5 and 10 thou". I can buy shims to achieve this.
I'm just not entirely sure how I go about measuring it given you can't physically get at them when the cover is bolted down.
Is it a case of putting the cam in the crankcase, measuring the distance the outer cam sprocket face is from the crankcase mating surface, doing the same again with it in the timing cover. Then adding those distances to the compressed gasket thickness, subtracting the clearance and that gives me the required shim thickness (that I split 50:50 each side of the cam)?
Or is there some sort of deformable material (plastic?) I can put in the gap, bolt everything together then pull it out and measure the thickness it's been squidged to?
https://lh3.googleusercontent.com/R6A6LpZXdSfOptdQag4k6jrJV5-spBQBwpTzJpr2lagEr8_y-wIzfRY6XeKTamtxW_m6HQpxRS6rOdQlPctIa5wPwEmenD-axkqgyPV0vqbBNOLWSRb6Wv658fXAYi6F_QJum-AMNQ=w815-h611-no ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| lingeringstin... |
 lingeringstin... Spanner Monkey
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 16:49 - 31 Aug 2017 Post subject: |
Stuff called 'plastguage'.. or similar principle improvisation... Used to be 'the' thing for measuring squish clearances on 2T silly-heads....
Stuff comes in thin strips; you cut a short length off and put it into the hole you want to measure; clamp up the cases (or turn the crank-shaft) to squash it, and the take the case off again.. real plastiguage comes with a paper chart, you lay the squashed strip on and how much it's squidges out tells you how thick the gap it was squidged into was....
Alternatively, having carefully removed squidgy stuff, you measure how thick it is after being sqashed into gap with a vernier caliper...
Though alziemers may be kicking in, 'cos I haven't used the stuff for perhaps three dacades.. you sort of get the idea!
If I had cause now, I'd probably improvise with a ball of plasticene, making sure the faces squashing it were well oiled, and measure how thick it was after being squashed with digiometer!
PS remember to alow for gaskets if you clamp up 'dry' or not. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Triton Thrasher |
 Triton Thrasher Could Be A Chat Bot
| Pete. |
 Pete. Super Spammer
 Posted: 18:20 - 31 Aug 2017 Post subject: |
Stick a dial gauge against the end of the cam and give it a push and a pull. Watch gauge. ____________________ a.k.a 'Geri'
| stinkwheel |
 Posted: 19:20 - 31 Aug 2017 Post subject: |
Umm. I think some people are misunderstanding the crux of this question. Or I didn't explain it very well.
When the cams are fully fitted, you can't get anywhere near them, you can't even see them, never mind touch them or measure anything.
They are entirely enclosed by the timing cover. Both ends are in blind holes. I wouldn't know if the end float was 1 ot 100thou" when that cover is on.
I was wondering about blu-tak, not sure how it behaves when squashed down that thin though.
There should be a picture at the bottom of my post above? You can see the cams in there (the furthest right thing is the exhaust cam) and the cover that goes over them. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Tankie |
 Tankie Crazy Courier
| virus |
 virus World Chat Champion
 Posted: 20:54 - 31 Aug 2017 Post subject: |
| Tankie wrote: | Plastigauge spreads to a known width for a known clearance gap , to read it you just place a measurement gauge you get with the kit up to it |
This.
Assemble with plastigauge in gap, disassemble and measure plastigauge with 'ruler' that comes with it to find out what your end float is when assembled.
Its commonly used for sizing up bearing shells by bolting the crank up onto some plastigauge and seeing if theres the right gap there.
John ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
| Robby |
 Robby Dirty Old Man
| Islander |
 Islander World Chat Champion
 Posted: 11:43 - 01 Sep 2017 Post subject: |
Another vote for plastigauge here.  |
| Triton Thrasher |
The last post was made 8 years, 140 days ago. Instead of replying here, would creating a new thread be more useful? |
