| stevo as b4 |
| pepperami |
 pepperami Super Spammer
| MarJay |
 MarJay But it's British!
| Robby |
 Robby Dirty Old Man
 Posted: 09:20 - 01 Sep 2017 Post subject: |
Yes, your method will work. I wouldn't use stainless bolts though.
Stainless has three big pitfalls when used in aluminium alloy cases:
1. It causes the alloy to corrode more quickly. Aluminium oxide (corrosion) has around twice the volume of alloy, so the bolts get very tight.
2. Stainless is harder than mild steel, but more brittle - at least in the grades typically used for cheap-ish bolts. This means it snaps off more easily, and with less warning - often as a consequence of point 1.
3. Stainless is pain in the arse to drill. So when points 1 and 2 have happened, and you need to drill it, you have a much harder job.
I would either remove the existing bolts and clean them up then reinstall, or replace with new mild steel (preferably plated or galvanised) bolts.
For the sort of home project that I expect you would enjoy, because I know I would, you can buy home plating kits on ebay. So the original bolts can be cleaned up with acid or electrolysis (metal kitchen sieve to hold the bolts and avoid wiring each one up in electrolysis) and then plated.
As a very lazy man, I prefer to clean things using chemistry than wire brushes. |
| Islander |
 Islander World Chat Champion
| stevo as b4 |
 Posted: 16:57 - 01 Sep 2017 Post subject: |
Cheers folks for the input and advice, and the wisdom about stainless bolts too.
I can probably just take out and clean up or replace the 3-4 bolts with the issue, and I'll do them in the old one at a time method so hopefully won't have any issues with air leaking or warping of the faces.
Robby, your actually right and have given me a good idea of what to get myself for Christmas too. If a diy cleaning and plating tank is not too huge, then yeah I'd really like to have a go at renovating my old bolts. I've got 2spare engines and a another bikes worth of bolts I could put it to practice on.
Would be nice to do more in house restoration on some bikes too, like paint spraying (have a compressor and a hvlp gun already). Wheel building too, as that would save a packet on a cheap and cheerful off roader resto project.
Out of interest, what types of plating can you do diy, I.e is there a choice of plating solutions available for diy set ups?
Oh and final question is, how does titanium compare with stainless for corrosion resistance in alloy castings? Is it better or worse? |
| Islander |
 Posted: 17:05 - 01 Sep 2017 Post subject: |
Titanium? Why?
Imagine one becoming seized for some reason. Now imagine trying to drill it out...
Passivated steel.  |
The last post was made 8 years, 139 days ago. Instead of replying here, would creating a new thread be more useful? |
