Quick carb question xs500
Jay2903
PostPosted: 16:23 - 01 Sep 2017    Post subject: Quick carb question xs500 Reply with quote
I just finished fitting all the bits from 2 carb rebuild kits to the carbs on my xs500. I put a vacuum on one side of the carbs but when I push the throttle arm the sides don't rise.
Do they have to be filled with fuel or does this test just not work on these carbs ?
(Keihin carbs) [/list]
Tankie
PostPosted: 16:36 - 01 Sep 2017    Post subject: Reply with quote
If you have used pattern part kits for the rebuild your probably opening a can of worms.
I don't know the carbs ,but if they are C.V carbs the slides are lifted by air pressure when the engine is running
Jay2903
PostPosted: 18:12 - 01 Sep 2017    Post subject: Reply with quote
https://i61.photobucket.com/albums/h67/Jay29031/Mobile%20Uploads/51C412F0-B5D2-4C5D-8535-6DA627894650_zpsyvhlk3cs.jpeg
I was wondering if a bad seal between parts 97 and 98 would cause this ?
Jay2903
PostPosted: 18:13 - 01 Sep 2017    Post subject: Reply with quote
That's what I'd assumed
A100man
PostPosted: 07:46 - 02 Sep 2017    Post subject: Re: Quick carb question xs500 Reply with quote
Do the slides lift easily by hand (finger)? A bent needle will impede motion. Also damaged diaphragm on a cv (I think)..
temeluchus
PostPosted: 09:33 - 02 Sep 2017    Post subject: Reply with quote
Attach a photo on bcf as your photobucket has run out.
How are you 'attaching' a vacuum?
Provided the diaphragms are not torn and are not perished, and the slides move with firm push of a finger, it should be fine.
Jay2903
PostPosted: 13:43 - 02 Sep 2017    Post subject: Reply with quote
Yea they move fine. (Steel diaphragms). I attached the vacuum the same on a spare set of carbs and they moved up and down normally.
Jay2903
PostPosted: 13:44 - 02 Sep 2017    Post subject: Re: Quick carb question xs500 Reply with quote
Needles are new, steel diaphragm. They move fine
Jay2903
PostPosted: 13:45 - 02 Sep 2017    Post subject: Reply with quote
I thought maybe a bad seal between 97 and 98 ?
The last post was made 8 years, 123 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 58.63 Kb
